Question about Panasonic KX-FL511 Plain Paper Laser Fax
Gets busy signal
When someone tries to fax us they get a busy signal and the fax won't go through. I have to unplug the power from the fax machine and plug it back in then the fax will come through. Is the fax broken or is there a quick fix?
    Novelist:
  • 208 Answers
You may simply have a bad phone line from the machine to the wall jack. If the connection is getting flakey it will cause it not to connect.
You could have a sticking relay on the fax modem circuit board.
Also you could just need to reset the machine via the manufacturers directions on how to clear the memory or reset the machine to defaults.
Another question is , do you have any other pieces of equipment on the phone line with the fax? Such as a credit card machine or other device that may be causing the problem. If you have more than one item on the phone line, try plugging only the fax machine into that line and see if that works.
Is there an extension phone built into the machine also? Make sure its not causing a problem either.
That problem has a multitude of issues.
You could also have a phone line problem. If your line voltage is low, line current low or you have alot of DB loss, it can cause that issue.
Sorry I can't narrow it down to one specific issue, but that one has lots of possibilities.
Posted on Dec 05, 2007
My Brother MFC7340 Fax Machine will not send faxes it has a busy signal always and a busy signal when someone tries to fax me.
You need to reset the memory, since previously you have dialed some number, which is not able to connect. So restart the printer. Unplug the printer for 10 minutes and plug back the power to the printer.
Hope this helps.
Shane
Apr 04, 2011 | Brother MFC-7340 All-In-One Laser Printer
Can not get a dial tone. Phone appears to be off the hook. How do I trouble shoot it?
Unplug the phone line from the fax machine. Wait at least 1 minute then call the phone number that goes to the fax machine from another line such as a cell phone. Make sure you get a ring and not a busy signal. If you get a ring then hang up the phone. Plug in the fax machine again and call the fax number again. If you get a busy signal then either your phone if off the hook, the switch that is actuated when the phone is placed in the cradle is bad or your modem in the fax machine itself has gone bad. Another thing to try is unplug the fax machines power cord for 30 seconds then plug it back in. I have seen the modems get "locked up" and keep the phone line open. Unplugging will sometimes reset this and get it working again.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
We cannot receive faxes. Gives a busy signal.
Unplug the phone line from the machine. Wait a few minutes then try calling your fax number from a phone while leaving the phone line disconnected from the machine. If it rings fine from the phone, then re-install the phone line to the fax machine. Try making the call again. If you now get a busy signal then the modem in your fax machine has gone bad and is holding the line open. Make sure when installing the phone line you are placing the cord into the "line" port on the machine and not the phone port.
Good Luck and thank you for using Fixya.
Mar 18, 2010 | HP LaserJet 3050 All-In-One Printer
When I dial a fax number I get a busy signal even though I know that the number is not busy because I have dialed it on my outside line and it works. This has happened repeatedly. I have unplugged...
Since you mentioned that you have an outside line, do you have to use a code to dial out normally? Try plugging in a phone to the line for your fax machine, and attempt to dial the number for the other fax machine using the phone. You should reach the fax and hear a high pitched sequence of tones. This is the other fax machine trying to establish a connection. If you still get a busy signal, try calling the owner and letting them know that their fax machine is not accepting incoming calls.
Feb 22, 2010 | Brother IntelliFAX 770 Plain Paper Thermal...
Trouble faxing
Check the fax line with a regular phone and dial a fax number to listen for fax tones.
May 31, 2009 | Samsung SCX-5115 Fax Machines
Fax line is busy
check the hand set is correctly seated on its cradle.
Check the Hook button on the front of the machine.
Disconnect the fax machine from both the phone and power lines for several minutes, reconnect and try again.
UserGuide.pdf">http://static.compusa.com/pdf/canon-FAXPHONE_L80-UserGuide.pdf
I have included a copy of the users manual in case you are missing yours.
Hope this helps
Ed
May 19, 2009 | Canon FAXPHONE L80 Laser
Have dial tone, but can't fax
It sounds like the modem is bad a possible electric serge
Jan 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Can't recieve a fax.
Unplug power cord. Plug back in. Call your fax machine from cell phone and listen for fax tones.
Sep 17, 2008 | Brother IntelliFAX 3800 Plain Paper Laser...
Fax problem
unplug the fax from the phone line. call it from you cell.if you hear your phones ringing in the house, plug the fax machine back into the jack. [you should still be on your cell phone] if the line goes dead or stops ringing, there is a short with the fax machine or wire to the jack.if you hear a busy signal without the fax plugged in, unplug everything you have plugged into phone jacks thruout the house. call your # again.if you hear ringing on your cell phone, plug everything back in one at a time.[again while still on your cell phone] if it was one of the phones plugged into a jack, when you plug the shorted phone back into the jack, the line will go dead again. that phone or cord is the problem.
if still rings busy when everything is unplugged, then call your phone company. it can be an inside wire or jack problem, or the problem is outside your home.
hope this helps
wg
Feb 05, 2008 | HP Officejet 5610 All-In-One InkJet...
Panasonic KX-FL511 Plain Paper Laser Fax Logo
102 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
