Projector problems Hi, I have a 3m MP7730 projector that keeps going into standby mode. I switch it on and it works fine, it warms up and after 10 seconds of projecting the lamp switches off and the projector goes into standby mode. There is a lamp indicator that keeps flashing.. and the instruction manual says that the indicator flashes when the lamp is too hot. But the projector won't stay on for more than 5 minutes and it doesn't seem over heated. Any ideas? Thanks, Maria
  • 1 more comment
  • David-IB Dec 02, 2007
    I have an MP610 which turns on for a few minutes then the "Temp" (temperature) light comes on. Then a few seconds later the fans become a little louder (faster?) and then the bulb turns off and when the unit has cooled down the fans go off and the power turns off.
    It is outside its 12m warrenty, so I took the top off it. The fans are both moving freely, and appear to be working fine. There doesn't appear to be much heat coming from the fans before it cut off - the air hardly got warm.
    I started up the projector with the top off (hoping it might run cooler that way) but the same cycle occurred.
    I disconnected it from the mains, I took the metal cover off the circuit board, (which required only disconnecting three screws incl one which was securing an earth connection) in the hope that I would find a variable resistor to re-adjust the temperature sensor (assuming this had gone wrong). I found nothing but solid-state circuitry, unsurprisingly.
    I screwed the cover back on (including the earth wire) and turned it on again, and now it is running without cutting out. Why? I didn't do anything!
    It has now been running for several minutes and the air from both fans is fairly warm (but not hot).
    What caused this? Will it happen again? What should I do if it does happen - take it apart and put it back together again?
  • Anonymous Dec 26, 2008
    the lamp keeps going out after 10 seconds
  • Doan Quang Hung Mar 13, 2013
    Thank you
  • 3 Answers
After 2 years I finnaly solved the problem. There was a flaw in the lamp´s temperature circuit. A technician disassambled my BENQ PB8253 unit and fixed the problem. Charged me US$ 75.00. I´m in Brazil.
Hope this can help.
Posted on Sep 14, 2009
  • 563 Answers
Hi David IB
I've had teh same experience with a BenQ MP720 ( just the XGA version of your Projector )
I queried this with BenQ Engineer in Dubai and he said that it sometimes works exactly like a short on the machine.
If I could give you a tip , If it happens again don't put back the metal cover of the Mainboard it solves the problem 100%
Posted on Mar 27, 2008
Help with standby power problem on 3M Replacement Lamp Kit EP7640ILK Projector Lamp for MP7640I ... ...standby mode with the power light flashing again.
the lamp for 3M 7640
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Mar 14, 2012 | 3M Replacement Lamp Kit EP7640ILK...
Why does the projector keep going to standby mode?
If the lamp usage time has passed 2 000 hours (when LAMP POWER has been set to NORMAL), the projector will switch to standby mode after approximately 10 minutes of operation. The resetting procedure should thus be completed within 10 minutes.
1. Insert the power cord plug into the wall outlet and then
press the MAIN POWER switch.
2. Press the POWER button so that a picture is projected onto
the screen.
3. Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
4. Press the ENTER button, and then press the F or G button
to select LAMP RUNTIME.
5. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, "LAMP RUNTIME
RESET." is displayed and select OK.
6. Turn off the power.
This will reset the cumulative usage time for the lamp
unit to zero.
Mar 12, 2011 | Panasonic PT-AX100U-EC DLP Projector
Miss operation to launch "Control
When the control panel lock ON of the projector so that the projector can be operated only with the REMOTE CONTROL.
If you loos your remote control then keeping the POWER key on the projector control panel pressed for 10 seconds turns the projector ON when it is in standby mode, and turns the projector to standby mode when the power is on. If you press and hold the MENU key for about10 second when the power is on the lock will be released and "panel key lock" is automatically set to "OFF"
Feb 23, 2011 | Sony VPL-CX70 Multimedia Projector
When i turn on the video projector and send me this message"the panel keys are locked "
Your projector key panel locked you have two option to operate the projector
1 . Use remote control press MENU the menu window displayed.
use DOWN ARROW key and select SET SETTING.
press ENTER
use DOWN ARROW key to select PANEL KEY LOCK.
press RIGHT ARROW key to OFF the panel key lock
press ENTER and then press MENU key to exit the menu.
now you panel keys are working
2. If you loss your remote control then;
When the key panel lock is ON keeping the power key on the projector key panel pressed for 10 seconds turns the projector ON when it is in standby mode, and turns the projector to standby mode when the power is on. If you keep pressing the MENU key for about 10 seconds when the power is ON, the lock will be released and "panel key lock" is automatically set to OFF.
Feb 05, 2011 | Sony VPL-CS7 Multimedia Projector
Changed my projector lamp yesterday, it work for about 4hours and went on standby. its now on a stanby mode and all effort to switch it on has not been successful. Please help me
Is your projector connected to a source? ( Computer, DVD, or any device) make sure the connection is tight/properly plug in so that the projector will recognize the device attach to it and override the standby mode.
Hope this helps, thanks for contacting Fixya. Please keep us posted of issue. Cheers!
Dec 09, 2010 | Panasonic PT-AX200 LCD Projector
After 2 mins on the bulb goes out
Need to change bulb and reset the lamp timer. When was the last time you clean the air vent filter. Clean it and reset the air vent filter cleaning timer
Aug 10, 2010 | 3M EP7630LK Projector Lamp for MP7630,...
The projector is going into standby mode 30% of the way into the presentation. This is not my projector so I'm guessing at the setup. Can you help. I'm using my laptop with a PowerPoint presentation,...
check the settings. sometimes there is a shut off timer if it isn't used for a specific amount of time. you can turn that setting off in the menu (if it has it). otherwise, it may be overheating and needs to be cleaned out with canned air.
Jan 13, 2010 | 3M MP 8730 Multimedia Projector
3m projector mp 8020
i think you problem is that the s-vhs output on the labtop is not enabled.
My old labtop needed restart with the projector on, and also had a switch to set in the bios.
So take a look in you manual for the labtop.
Have you tryed the projector on a dvd player or something like that, just to bee sure the projector works fine?
best regards michael
miguelovitch amplifiers
Dec 03, 2007 | 3M Projector lamp Projector Lamp
Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Oct 13, 2007 | Toshiba TLP S30 Multimedia Projector
1,362 people viewed this question
