Model: LG 42LN5110 Panel: LC420DUE SFR1 The problem happend after replacing the backlights with abrand new set from ShopJimmy
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Thank you for your response , I just visited the electro help blog but I still don`t find relevant info to my problem. But why you are so sure that it is the T`CON board ? the video is complete except for this difference in black level on the two halves of the screen.
The Problem finally solved after I removed the two TCON flat cables, swapping them then reattached and surprisingly the picture is back to normal and the problem is solved .
