Using Plasma as a monitor? Screen is to the right.
I just hooked up my computer with vista to my Plasma tv (HP-S5053 50'') and the left side is back and I can't see the right side. The screen is to far to the right. I have tried everything. I cant adjust the screen enough to get it right any solutions?
    Problem Solver:
  • 4 Answers
Try changing the Refresh frequency to a higher one (in the Display properties)
Posted on Jan 04, 2011
The screen appears to be too small for the desktop display. If I want to see the left side of the screen I have to move the arrow over to it, and then the right side of the screen disappears. Basically, I...
Hi Jessica.
You have you graphics card resolution set too high. I assume you are using some version of Windows. If so, right click the desktop and left click properties (Windows XP), click the advanced tab and reduce the slider to 1024 x 768 and apply the settings. If using Vista or Windows-7, right click desktop and left click screen resolution and select the above setting. This shoud correct the panning issue and give you your entire screen back. Hope this helps and good luck.
Jan 27, 2011 | Acer V193w LCD Monitor
Hooking laptop to tv says invalid format on my
After it is all hooked up. You must go to main computer screen, then right-click on main windows screen,
You will see box #1 and box#2
Take the #2 box, click and hold mouse button and drag to the Left Side of #1 and let go of mouse. Get it as closely matched up to the #1 box without crisscrossing them. Just set it directly next to the box.
Then click enable this monitor and/or apply button.
Then ok,
Now your monitiors should all automatically connect and turn on.
Feb 28, 2010 | LG 42LC2D 42 in. LCD HDTV
Small green line on right side of screen
This is an easy fix using the Philips remote control that came with your tv. On the center of the remote is a dial that has left right up down controls. Stand in front of the tv and using those controls you can recenter the screen and get rid fo the green line. I had same problem when we hooked up hd satellite reciver to philips 37 plasma
Feb 18, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
I connected my hp laptop to my pioneer plasma via svga cables. When i select my pc input using my tv remote it says "plasma display no input signal". How do I fix this?
Hello. You have to go into your Display Settings, in your HP Laptop, and chose the Dual Screen/Monitor Setting & make sure you check the "Extend my Windows Desktop onto this Monitor" Box. If you are trying to view your Internet Browser on your TV - you will need to Click on and Drag your Browser to the Right... of off your Laptop Screen and onto your TV Screen. This will take care of your problem!
Jan 11, 2010 | Pioneer PDP-5071HD 50 in. Plasma HDTV
Connect tv to computer
Be sure to enable the second screen through the windows display settings. Right click on the desktop background and select personalize (VIsta) or Properties (XP). Click on the settings menu (lower down on Vista, a tab on the right for XP) and look at the monitor setup. After you are connected via cable to the TV, go there, click on the second screen and select "enable this monitor", "extend desktop onto this monitor" or something of the like. Oftentimes it will not do it if you are not already physically plugged in so ensure that you do that first.
Aug 26, 2009 | HP Pavilion Elite M9150F Desktop PC
Sony PFM-42B1 with black bar in 720p
yes, stop using a plasma TV as a computer monitor. Using the TV this way is an invitation to phosphur burn which these are very prone to. The issue you describe is due to the limitations of the TVs scaler circuit to properly center the image in 720P.
michtech
Feb 13, 2009 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Thin red line in middle of screen on nec 42 inch plasma monitor
I had the same problem -red, vertical bars along the right side of my Samsung 42" Plasma- and this is what fixed it: Removed unterminated cable.
I had hooked up an HD video camera to the set about two weeks ago. While I disconnected the camera I left the other end of the connector cable plugged into the T.V.. As I've since learned from friends who work in television, this is what's called an "unterminated cable" -meaning one end is unconnected. It can lead to problems with electrical interference and appears to have been the problem in this case; When I disconnected this cable from the T.V. the red bars went away.
So, check your cables. Make sure everything is properly connected and get rid of anything that might be picking up interference.
Dec 27, 2008 | NEC PlasmaSync 42PD3 42" Monitor
Monitor goes to sleep mode quickly without video cable
right click on desktop - click properties - click screensaver tab, and dropdown menu to none. this turns off screen saver. For power/hybernate....
start - control panel - power options. Change all pull down menus to "never"
Problem solved.
Dec 22, 2008 | HP vs15 15"LCD Flat Panel Monitor
Red line on screen
Hope this makes sense.
Sep 29, 2007 | LG 50PX4DR 50 in. Plasma TV
Televison & Video Logo
Top Televison & Video Experts
