Onboard USB 2.0 hard locks system.Reverting to 1.1 mode solves it
Hello, thank you for taking the time to assist me. I am a very experienced computer user and built a custom rig based around the AsRock 775Dual-VSTA motherboard, which features on-board USB 2.0 ports. Whenever I try to transfer data from or to a device (such as an external Hard Drive, MP3 player, digital camera...), the system will freeze within a few seconds to a minuet. This is a brutal hard lock, the mouse pointer will not move, nothing responds and even the NumLock light stays lit no matter what. Data corruption can result wherever a file was trying to be stored (cause only part of the file gets over). A hard reboot is the only recourse. I have also noticed that intensive software such as games will be unstable and crash every 10mins to an hour or two, even if no USB device is connected save my mouse and keyboard.
The really interesting thing is, when I disable the 2.0 support and rely on legacy 1.1 mode, all problems are solved completely. In fact, my system has never freezes or crashes when 1.1 mode is in effect. SO, why is my system doing this? Faulty hardware? Bad configuration? I have the correct drivers from the manufacture's website and have tried drivers directly from VIA (this board has a VIA chip set). Nothing seems to work. Could there be a Windows service interfering with this? I am grasping at straws here and no, I do not want to just go and buy a cheap USB PCI card, I want what I paid for already to work properly. Thank you again!
  • pixelite25 Jul 20, 2009
    Well, my BIOS is already up to date (v3.10). When 1.1 mode is enabled instead of 2.0, no problems occur, so I doubt other hardware in my system is a problem. Thank you for the suggestion none the less!
    President:
  • 828 Answers
AsRock motherboard having trouble even it another thing to happen like Hard Disk Failure but we know our HDD is fine...
Heres what you do, update the BIOS of your motherboard, www.asrock.com.
This time all the settings on your motherboard hardware are working properly. Good luck!
Posted on Jul 20, 2009
Hi, I have a Nokia 5800 (S60V5), I have being experiencing the following, 1. When the phone is in standby mode, 2. There is "no network" or sometimes "sim registration failed" 2....
Hi sir, 1) It asks the pin code since you or others set it in the settings-> security setting->PIN code request. If its ON state, You have to change to off mode. That time it will ask you the pin code. If you don't know the pin try with 1234 or 12345. Remember don't try more than tree times. It will get locked.Or Call the service provider for of your SIM from other mobile and get the PIN code from them.
2)If its restarting again then the problem is with the mobile OS(software). It can be solved only after changing the OS. For that you have to go to a Mobile Service Shop.
Mar 01, 2011 | Nokia 5800 XpressMusic Smartphone
Please can you give steps to disable the onboard usb controllers to use the CPI USB Card. I've installed the PCI Card after the onboard stop working
2.4.2 USB Configuration
The items in this menu allows you to change the USB-related features.
Select an item then press <Enter> to display the configuration options
USB Function [Enabled]
Allows you to enable or disable the USB function.
Configuration options: [Disabled] [Enabled]
Legacy USB Support [Auto]
Allows you to enable or disable support for USB devices on legacy
operating systems (OS). Setting to Auto allows the system to detect the
presence of USB devices at startup. If detected, the USB controller legacy
mode is enabled. If no USB device is detected, the legacy USB support is
disabled. Configuration options: [Disabled] [Enabled] [Auto]
USB 2.0 Controller [Enabled]
Allows you to enable or disable the USB 2.0 controller.
USB 2.0 Controller Mode [HiSpeed]
Allows you to configure the USB 2.0 controller in HiSpeed (480 Mbps) or
Full Speed (12 Mbps). Configuration options: [HiSpeed] [Full Speed]
BIOS EHCI Hand-off [Disabled]
Allows you to enable support for operating systems without an EHCI
hand-off feature. Configuration options: [Enabled] [Disabled]
NOTE!!!
Do not disable the BIOS EHCI Hand-Off option if you are running a
Windows® operating system with USB device
hope above given details with give you a detailed description as you desired.
good luck
Feb 04, 2010 | ASUS P5LD2-VM Motherboard
I have an external 500 GB HD. I try to plug it in to my laptop and the light on the front just flashes. The laptop doesn't recognize the HD, and there is no sound coming from the external HD
For that make sure usb cable works fine.
Try with different usb cable.
Also connect usb cable in different usb ports of computer.
Right click on my computer then click on proeperty then hardware->device manager.
Then click on sign of usb controllers then uniunstall all usb drivers 1 by 1.
then restart computer.
Then check.
If still not recognized then when you power up the computer press F8 key then enter in safe mode.
then check.
in normal mode again.sometimes harddisk need to start in safe mode .
Let me know if you need more assistance.
thanks.
Nov 05, 2009 | Western Digital My Book Essential Edition...
I dropped it after it was hooked up to another computer with a different operating system now whenever i plug it in to a computer it is displayed on the computer screen as removable disk not a hard drive....
This is quite normal in my opinion, most USB drives are installed as removable devices, because they can be removed anytime from the system, right?
The difference is that for removable devices the system optimizes writing for quick removal, for example turns off write cache to write immediately to disk, and also shows an option to "eject" the drive, which in this case means "let go of the drive", checking that no files are open on it.
Oct 24, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
My PC does only has 1 user account and ther is no
You can always remove the hard drive from the system and put it in another computer to retrieve the files. Something must have corrupted your user account settings. I've noticed some systems when they were installed that people never paid any attention to the login screen during installation but you might try logging in as Admin or admin with no password. This works once in a while. If when you put the hard drive in another system it won't let you open the "Documents and Settings" directory (if it's XP) because you're not logged in as that user, you'll have to put it in a system with Windows Vista. Vista will allow you to take control of the directory and let you access this part of the drive.
Oct 01, 2009 | Computers & Internet
External Hard disc isnot recognized by PC
Dear Sir,
Here is the Procedure for Connecting External Drives to Computer.Several brands of computer does not recognise external drives when connected to USB expansion slots,and Slots of front panel,So connect your Ext HDD to back side onboard Slots.Because there is a lack off USB power surge voltage to detect a large capacity exteral drives.Some time it is does not recognise by many computers,when USB power surge voltage is low.
I think it helps,
If you find any difficulty post a feed back we were happy to assist you
have a nice day.
Good luck
Sep 17, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
My USB is not responding
Please buy new one, your USB has experiencing permanent Crash on its entire system that is why your computer is always telling you that Not Responding due to failure in installing the complete driver from your USB to be recognize by your system.
Thanks
Aug 17, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
External hard drive
refresh the USB ports:
1. Right click MY COMPUTER
2. Select PROPERTIES
3. Select HARDWARE
4. Select DEVICE MANAGER
5. Select UNIVERSAL SERIAL BUS CONTROLLERS
6. Right click on each USB CONTROLLER and select Uninstall
7. Uninstall all entries
8. Reboot your computer
9. As your computer re-boots it will reinstall all USB connections it detects
THEN, when all other USB items have been configured and connected by the system, you then should try connecting your USB drive
Let me know....
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 09, 2009 | Computers & Internet
My 4gb kingston pendrive is not recognize by any computer
Hello
For Solving your problem do the following
1. Check that the USB is connected properly to the mother board
2. USB 2.0 Drivers are loaded
3. See that the Pendrive is properly connected
Let me know that your problem is solved and rate me as Fixya!
Sep 12, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Hello, i have a western digital 500gb my book hard drive. had a problem with pc yesterday. when booted up, lots of the programs started opening themselves and i had difficulty shuting it down. turned off...
You have experienced a system emergency shutdown. In otherwords, your computer crashed. You can:
1: reinstall your operating system.
2: use a OS recovery disk to reboot the system.
3: send the computer to a data recovery specialist.
4: return the computer if the warranty is still valid.
Good Luck!
Jul 05, 2008 | Computers & Internet
Computers & Internet Logo
160 people viewed this question
David Payne
David Payne
