Samsung SCX-4100 All-In-One Laser Printer Logo
Posted on Jul 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hardware I/O error under XP
I have the same problem, print and copy works fine but evey time I try to scan I get a hardware error message. The OS is Windows XP SP2 and there are no other USB peripherals attached to my PC. I am using the scan thru program that comes with device drivers.
Tareq Bin Mostaq Mostaq
Level 3:
President:
  • Samsung Master 1,449 Answers
  • Posted on Jul 23, 2009
Samsung Master
Level 3:
President:
Answers
1449
Questions
31
Helped
614555
Points
3628
It is problem your printer scaner driver
The printer works fine from Windows including Scanner.When using photocopy from printer panel does not work.
If you are not getting any error messages, I suspect you definitely have a printer hardware problem, especially if it prints fine from Windows. Best to contact Canon's technical support with this one
2answers
System freezes evey few munites no error messages
Possible error or some registry files are missing from the program.
You may have to scan for a virus in the system or reinstall the OS once again
Want copy ---comes up unrecoverable scan---ties up machine for 5-10 minutes---LEXMARK 5600-6600---IT also makes a knocking sound. until red light goes off and green light comes.on---1st time happened...
Unrecoverable scan error is a hardware problem. Features affected by this error are scan, copy and fax. Recommended action is to contact Lexmark technical support for assistance.
1helpful
I have a MacBook Pro connected via USB to a Kodak ESP 5 A-I-O. I've been having problems getting the scan function to work at all. So I upgraded the ESP 5 firmware & drivers to the latest available for...
Hi. To make sure that the product hardware is functioning correctly, use the product to make a photocopy. If you cannot make a copy, this solution will not help resolve the issue.
Solution 1:
Follow these steps to restart the product and the computer. NOTE: Make sure that the product connects directly to an electrical outlet and not through a surge protector or power strip.
  1. Shut down the computer.
  2. Press the Power button to turn off the product.
  3. Wait 10 seconds.
  4. Restart the computer.
  5. Press the Power button to turn the product back on.
  6. Try the scan again
Solution 2
1. Replace the USB cable.
2 .Try the scan again.
Solution 3
Fully uninstall and resintall the software and driver of Kodak printer
Workaround:
Try installing the printer to Windows XP environment just to prove functionality and test incompatibility issues. Might be your printer is icompatible with MAC OS. This will also prove if printer is working or not.
1helpful
HP Photosmart C4580 wont scan
It seems that scanner glass is not glowing or may be bulb are not moving properly.
you can try these thigs:
1)Turn ON the printer unplug the powe cable from the back of the unit; wait for 30secs; replug the power cable.
2) Try this to check teh funtionality of hardware Load letter or A4, unused plain white paper into the input tray.
  1. Press and hold the Cancel (c01235250.gif ) and the Start Copy Color buttons at the same time.
  2. Release both buttons. The self-test page prints.
3) Now check if its copying or not?
It will work fine(if your printer scanner glass is fine)
You can also try scanning from computer(if installed)
the location of file would be=
c:\program files\hp\digital imaging\bin
here locate for file "hpqscnvw" hit it and try to scan
Best of luck
Samsung CLX-3175FN Scanning Error
I think the laser part should be unplug in Data cable and power then plug again ..
HP OfficeJet 555 Printer (hardware) failed to install
Greetings,
Here is the link to the Hp driver page for your printer - Download the drivers and then reinstall them - This should resolve ther issue.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=57742
Hardware malfunction
From the error report, it sounds like you have a bad memory chip (RAM).
If it's under warranty, contact Dell for a replacement.
If it is out of warranty, go to a vendor that sells RAM and replace it (such as www.crucial.com)
Scanning Problem
Are you getting any kind of pop ups when you try to scan?
What kinds of AntiVirus Software are you using.
What operating system are you using: ex. Vista; XP Home; XP professional?
Answer these questions and maybe I can help you
Scanner 3770 hardware problem
Hi, it is possible that your scanner has a transport locking lever or knob underneath which might have been keeping the carriage locked in place. Try checking and release if there is one. Hope this works for you. Pls post again how things turn up. Good luck and kind regards.
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
