Question about Panasonic AG-DVC7 MiniDV Proline Camcorder
Cleaning Internal Connections
I have seen more than one suggestion regarding cleaning internal cable connections to fix known problems. Since I am very handy at such things I would like to do my own repair on my AG-DVC7 camera but cannot locate a service manual online for download. If anyone has experience in the proper disassembly method on this camera I would greatly appreciate some hints on how to proceed. I'd much prefer to know exactly how to open this thing up the right way without having to figure it out on-the-fly!
I am a video engineer (EE). I soaked the flexible cable with 90% isopropyl alcohol applied with an eye dropper where the ribbon cable goes into the reel table / spindles. Also, where they make a right angle to connector points. This has worked for a year so far.
Posted on Jul 24, 2008
Actually I got it done this evening when I got home. I carefully started pulling screws that appeared to hold the left case side on, and I got lucky and got all the correct ones on the first try. After removing and reseating all of the ribbon cables the camera works perfectly again!
Posted on Nov 20, 2007
Convergence issue, Unable to adjust through remote control the Blue cross sections do not move at all suspect problem could be a PCB, checked all internal connections etc
Hi jasonmonika ,
Try turning off your Tv for a couple of minutes with the power cable plugged off. plug it all back in and see.
if that does not work, then i would suggest for you to call the service center for you TV and ask them to help resolve your issue. Usually the suggestions would be to check all internal connections but i see you already have.
this is all i can recommend, i hope this helps.
Mar 28, 2011 | Samsung SP55W3HF 55" Television
Problems with monitor
1. Please check the signal cable connections; make sure it's tight and secure.
2. Please check if there is any missing / bent pin in the signal cable.
3. Please connect the monitor to a different computer to eliminate a possibility of video card (in your computer) problem.
4. try going into the menu on the monitor to find a degauss option it should work
May 24, 2008 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
It does not read cd's or dvd's when inserted in the tray?
this may caused by
  • Dirty Lens
  • Faulty Internal Mechanisms
  • Corrupted Data transfer
  • Dirty Lens- Your Drive's Lens may have become dirty and you need to clean the lens.It is usual that the lens become dirty time to time. You can clean the lens by the cleaning Disc which can be purchased separately from a nearby computer shop.
  • Faulty Internal Mechanisms - all internal movements are powered by a small electrical motors and belts. If any of these are not working as it would, then Drive may not work as expected. You may need a expert hands to clear this problem.
  • Corrupted Data Transfer - If all the internal parts are working properly but data cable is not connected properly, then too drive may not read any discs. you can reconnect the cables.
Mar 23, 2011 | Pioneer DVR-107D DVD±RW Burner
Intermmitant transmission on a Motorola xtni radio
Intermittent transmit can be caused by:
1) Bad or poorly charged battery. (try a known good battery and see if the problem clears up)
2) Poor connection to the battery. (clean all contacts with a pencil eraser)
3) Bad PTT internal button, radio would need repair.
4) Bad antenna. Check for breaks in the rubber covering.
5) Other internal problems requiring repair.
Best regards.
Mar 09, 2011 | Motorola XTNi Two Way Radio
How to change the internal battery on an s149 stopwatch printer
Go to this link for your instructions. The title page is in Kanji, but the instructions are in english...
Good luck and don't forget to vote.
Oct 12, 2010 | Seiko S149 Stopwatch/Printer
Hi, My Seagate 500 GB Internal hard disk (Barracuda 7200.11) suddenly became non responsive (not detected by BIOS), Is there a way to make it responsive?
Please check the internal connection of your motherboard to your hard drive. Try reconnecting the cable connecting the hard drive to the motherboard. It usually fixes issues with undetected devices.
Btw, this model has a known issue, turns bad easily turns bad.
Just a suggestion, try using different models or a different brand.
Hope this helps! :D
Sep 08, 2010 | Seagate Computers & Internet
Xbox is showing one red light in the lower right hand spot. How do I fix this
The Specific Type of hardware failure can be determined by the error code displayed on the screen.
If the screen is blank or you would like additional information follow the instructions for determining the secondary error code in the section below
E64: (not yet known)
E65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc.
E67: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error.
E69: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E71: (not yet known)
E73: (not yet known)
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. (could also be a problem with the encoder chip)
E76: (not yet known)
E79: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
Sep 24, 2009 | Microsoft Xbox 360 Console
Jerky/Pausing DVD playback on 27" Akai DVD/TV Combo
I have seen many issues with these internal dvd players, I will recommend that you pick up a nice inexpensive walmart dvd player and hook it in to the red. green blue connections, that is really the best solution, the players in all these units fail within 4 years. hope this helps have a great weekend
Apr 05, 2009 | Akai LCT2701TD Television
Main Display Window
Hello Gully, the flat cable between the front panel and the radio. If you want I can give you the part number but the replacement of this cable is not simple. Best regards, Arpi
Feb 27, 2007 | Sony CDX-M8800 CD Player
White screen
First, always try it on multiple types of computers (different video cards), and multiple cables. Then, open it up and make sure the internal connections are solid. Finally, consider putting in a new inverter. This has been known to fix all-black and all-white monitor problems.
Dec 02, 2006 | Dell E173FP 17" LCD Flat Panel Monitor
Panasonic AG-DVC7 MiniDV Proline Camcorder Logo
225 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
