Question about Pinzon Pasta Maker
How can I clean a dirty pasta maker?
What is the best way to go about cleaning a very dirty pasta maker?
How can we clean this thoroughly without watere? Just cannot get it clean without spending 2 hrs with a toothpick.
I use a steel bristle brush. Unfortunately, there is no way around the time consuming tiny cracks and crevices.
Jun 07, 2013 | Kitchen Appliances - Others
How to clean the dryed pasta from Imperia Electric Resturant RM220 Pasta Machine Cylinders
I use a toothpick and toothbrush which is gentle and will not damage the plates and you can poke the toothpick through the holes.
Mar 15, 2013 | Imperia "Pasta Machine Rm220 Motorized:...
Manual for farberware pasta maker, how to use, clean and some recipes. lost my manual.
Viante has a Pasta machine that is almost exactly the same as the Faberware 100 pasta machine. I used the cleaning instructions and the recipes from the Viante Manual and they worked perfectly.
Here is the PDF format http://www.vianteusa.com/manuals/Viante_Pasta_Maker_Manual.pdf
Jul 09, 2011 | Kitchen Appliances - Others
I need to get an instruction manual for the Farberware Pasta Maker FPM 100. Thank you.
Farberware manuals do not seem to be available online. Try contacting Farberware Customer Service at the following site:
http://www.farberware.com/customerservice.html?hm=Y&ct=N&anw=N
For pasta makers try the e-mail address for Kitchen Accessories. Send your model number with your request for a manual.
Thank you for using FixYa!
Apr 30, 2011 | Salton Pasta Maker Video Recipe Book Bonus...
While making pasta there was a loud cracking sound . the machine stopped . no order was noticed . shut off . cleaned machine . retried to start .nothing happened.
DID YOU CHECK THE "MALE" PIECE ON THE HOPPER BACK THAT FITS INTO THE MOTOR
IF CRACKED OR NOT IN ALL THE WAY THE MACHINE STOPS
Jan 30, 2011 | Ronco Automatic Popeil Pasta Maker
Manual or electric pasta maker?
maybe u dont need a new pasta maker maybe u should just hand cook it
Jul 16, 2009 | Electrolux 178741 - Automatic Pasta...
Ronco Popeil Pasta Maker Problems
After using the Ronco Pasta maker for a few times I discovered a couple of problems, the main problems are that it's a bit slow, took as much time as it does for handmade pasta.
The second problems was that cleaning the dies was a pain!
Jul 16, 2009 | Ronco Automatic Popeil Pasta Maker
How to clean the Ronco Popeil Pasta Maker?
The Ronco Pasta maker is a bit of a pain to clean. I normally take the whole thing apart and put it in the dishwasher and that does a good job with most of it. Occasionally I will need to run it in the dishwasher twice. The middle piece has to be cleaned by hand. You can finish it off in the dishwasher after you clean out the junk in the middle part.
The dies are the real problem when it comes to cleaning this unit. You need to get a small wire to flush out the holes otherwise the dough dries inside the dies and they are very difficult to clean out. Just running it through the dishwasher will not work. I either use the wire or I boil the die for 20-30 minutes then put it in the dishwasher.
Pasta machine with no instructions
Check out this link, its all there. I use a food processor instead of hand mixing, its faster.
http://www.fantes.com/imperia.html
Have fun!
Mar 24, 2008 | La Pavoni Imperia Pasta Maker-Maunal (for...
Pinzon Pasta Maker Logo
249 people viewed this question
Top Pinzon Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pinzon Kitchen Appliances - Other Expert? Answer questions, earn points and help others
