Question about Sony 1GB Memory Stick PRO Duo Memory Card
I have sonycybershot (10x optical 8.1 mp) and sony memory stick pro duo 1 gb. when i try to put memory stick in camera it says reinsert the stick. where could be the problem. please help
  • 44 Answers
Did you insert it in a correct location...?
Posted on Jul 20, 2009
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
DSC-H2 will not accept memory card
The DSC-H2 works with Memory Stick Duos, not with Memory Stick PRO Duos.
Nov 26, 2013 | Sony Cyber-shot DSC-H2 Digital Camera
I have a Sony Memory Stick Duo Adapter with 1 GB Memory Stick Pro Duo insert. When I put in my DCR-TRV18 camera and switch it to Memory, I get Memory Stick Error on the screen
On many cameras , the picture format that you can save on memory stick is not the same that you can have by recording on tapes. It should be the same on your handycam.
You can increase memory stick to at least 2GB, that is what sony reccomends, you can test a 4 gb to 16 gb at the shop, if it works , then buy it.
However, the quality of movies grabbed on memory stick, should be far less than the one of movies recorded on tape.
Dec 27, 2010 | Sony Handycam DCR-TRV18 Mini DV Digital...
The pro duo memory stick cannot be used by my camera or read to see the photos
Make sure that contacts are clean on memory stick and reinsert it in camera.
Dues camera show any error sign when memory stick is inserted?
Did you tried memory stick in any other Sony camera?
Let me know to diagnose the problem.
Thanks.
Jul 11, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
What memory stick works in the DCR-TRV340 Sony Handycam?
Mine says msa-4a. the duo sticks won't work. You will the larger older memory sticks
Apr 26, 2010 | Sony Handycam DCR-TRV340 Digital Camcorder
Sandisc 4 GB memory stick PRO Duo not working
According to the users manual, the camera does not support above 512 MB cards, however I noticed that there is a firmware update which might address the issue. Go to www.sony.com and support, electronics. Put your model number in the selection box and you'll be taken to the drivers download page.
Feb 14, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Memory Stick error
Hello!
Following types of memory sticks are compatible with the Camera model DSC-V1:
Memory stick: 32/64/128 MB
Memory stick Pro: 256 MB/512 MB/1 GB/2 GB.
Mark 2 Memory stick Pro: 1/2 GB.
However, in order to use Memory Stick Duo or MagicGate Memory Stick Duo media with the Camera, a dedicated adapter (MSAC-M2) must be attached.
Follow the steps given below to troubleshoot the Camera that is not recognizing any compatible memory sticks:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C186797
Furthermore, you may try resetting the Camera to the original factory settings by pressing and holding the Reset button for 30 seconds.
If the issue persists even after performing all the above mentioned steps then the Camera is required to be diagnosed and serviced.
Aug 22, 2009 | Sony Cameras
When I upload images some get corrupted and some says DrawingFail
drawing failed indicates that the pictures were not properly written to the card by the camera. It might be due to some problem in camera, but most likely is a problem with the memory card or the speed of the memory card. I'd suggest to use a professional memory card for cameras with 8+ mega pixles resolution.
Jul 07, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Maximum Memory Stick size I can put into my Sony DSC-N1
Unfortunately, there is no way to change the internal card reader in the camera to accept higher density memory cards. You can find the memory stick compatibility list here: https://esupport.sony.com/perl/support-info.pl?&info_id=12 . Scroll down to the Cybershot N Series camera list. The maximum capacity memory stick is 4 GB memory stick pro or M2 Memory stick Pro. For the Memory Stick Duo, it looks like those have a maximum capacity of 2 GB.
I hope this helps.
Apr 14, 2017 | Sony Cyber-shot DSC-N1 Digital Camera
Sony 1GB Memory Stick PRO Duo Memory Card Logo
181 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
