Question about HP Bestec ATX-1956D 200w HP Part No 0950-4106 (ATX1956D) Power Supply
No Power out put.
I use a multi-tester to check if there is power-output but no movement on the tester.
  • Robert Tapiador
    Robert Tapiador Jul 20, 2009
    Hmmm to risky to try.
  • Edward Denis Martinez
    Edward Denis Martinez May 11, 2010
    try to short the power cord that connect to your board... use a soldering led to short it... the wire is color green and color black.. plug it... if the fan is running then there is no problem on you atx.
  • 44 Answers
Short the color green and black of your atx... use a metal wire.. don't wory it won't harm you... just unplug all the connection that is connected from you ATX.... short the said wire then plug your ATX to the outlet.. if fan is running then there's no problem on your ATX.. if not then you need to replace a new one...
Posted on Jul 20, 2009
How can i test the power switch on my Hoover Windtunnel bag less upright that just stopped working suddenly? I have a multi tester but don't know how to use it.
With unit disconnected from all power connect the multi tester to the two terminals on switch after putting the tester in the resistance mode. Flick the switch and see if you get continuity and break continuity condition. If you do the switch is good and your issue is elsewhere.
Mar 28, 2017 | Hoover Vacuums
My X350 will not power up
if you have multi tester check if there's a power output to the battery..or check battery connector....
Jun 02, 2014 | Walkera QR X350 Quadcopter BNF WALQRX350
My Net Gear wont power on.
check your wall outlet if there is a power output by using multi tester, if there is a power, then plug the power supply of your net gear wireless and check it with your multi tester if there is a power output.
Mar 22, 2010 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
No hot water can't even take a shower
If there is only cold water coming out from the water heater, there is no doubt that your RTO water heater
is defective.
1. Shut the power supply going to your heater off.
2. You can check on it, by opening it up.
3. Trace the wires coming from the power supply.
Using a multitester, check the continuity of each
line. Set the tester to Ohms 1 x 10. Put the multi
tester probe to each end of the electrical line, one
line at a time. The pointer must point to zero.
Otherwise, it must be replaced.
4. Test the heater coil for continuity. One of the multi
tester probe must be placed at the common termi-
nal. Put the other probe to the other terminals. The
pointer must be at zero, otherwise, you can
replace the heater unit, since this is already
busted.
Nov 24, 2009 | RTO American Heat Tankless Electric Water...
I need fuse location for windshield washer on 2006 Jeep Commander
Normally all fusebox are properly labelled (labelled as washer or accessories) But to be sure, you can check all the fuse for busted ones, by running a continuity test for each of the fuses, using a multi-tester. Set the multi-tester to Ohms 1 x 10 or 1 x 100. Take the fuse one at a time and put the probe one to each fuse contacts. The reading should be
zero for good one and no movement for busted ones.
Nov 04, 2009 | 2006 Jeep Commander
GE Monogram won't start after the maid has cleaned it (no lights and the fridge is warm)
Could either be bad compressor, power supply or relay.
I first would check relay with ohmmeter/multi-tester.
then I would check power to and from compressor with a voltmeter/multi-tester
And then do the same with power supply
Jul 21, 2009 | Refrigerators
Lamp warning lit ~1200hr NO warning & new bulb SAME! so ideas?
maybe your power supply could be the problem or check the cable that link to the power supply to dc output.check with multi tester if there is power coming from the power supply .be careful with the ac input of the power unit.tq
Nov 14, 2008 | BenQ MP610 Multimedia Projector
No power
no power, 1st you need a tester tester (range 1000vac) first the convinience outlet if there a voltage 2nd test the power cord if there a continuity(range your tester into resistance x10) put it in to the tip to tip of the C.O power cord of your turntable(the reading will have contunuity) if still no power check the fuse inside the turntable" remove the platter and the plastic be carefull trace where the power cord connect inside the circuit(maybe the fuse blown) if the fuse is still ok 4th check the contunuity of the transformer the input and output line(in tester there will have a reading supposed to be) after all if theres still aproblem just email me..hope i can help that way..
Aug 10, 2008 | Technics SL-1200MK2 Turntable
Logitech Z340 Power speaker problem
yeah you can fix that one into your own. first thing that you do is get a multi-tester and put the two terminal the red one and the black into the tip of male plug of you wire. then set your multi tester into the ohms selector any ohm selector which found at the right side of the multi-tester. if the arm of multi-tester was moving it means OK... if not open the speaker carefully and reconnect the wire by using soldering iron & lead.
Nov 04, 2007 | Logitech Z-340 Computer Speakers
No raster no audio,Zenith SJ 2065S5
as horizontal transistor gets very hot so no eht so no raster &no sound due to nosupply to vif & tuner. as hor output is getting hot please isolate supply to hor. section & check power supply output is ok as due to high voltage h/outout may get hot & demaged. if supply is ok check for leaky or short parts in hor output. 1 hor. output transistor itself if it is replaced that may not be of proper matching. 2 diode& cap.in eht section. 3 clean print near eht. 4 moisture near yoke due to rain in rainy season only. so keep it hot for few hours. 5 at last if all are ok eht or fly back transformer. re connect power to hor output after rectification
Sep 18, 2007 | Televison & Video
Computers & Internet Logo
372 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
