SOURCE: Heater blows cold air when idle
Sounds like you may have a partially plugged heater core. You could flush this out separately, from flushing radiator & engine block. Diconnect heater hoses going to your heater core and clamp off, so not to loose coolant from engine. Now hook up separate hose to one side of heater core pipe and flush out with typical garden hose. Repeat procedure on both heater core inlets. Reconnect original heater hoses and test difference. You may have to add an additional litre of antifreeze. If this don't work i suggest changing heater core. Good luck.........Ron.
SOURCE: My heater in my dodge caravan does not blow hot
First of all make sure your anti-freeze is at specification level's as well as make sure With the engine cold start the vehicle remove the radiator cap and make sure you see the flow of anti-freeze while keeping your hands as well as your clothing away from moving parts feel both hoses going into your heater core if the one on top of hot one on the bottom is cold then you have a Clogged heater core in which case you will need to flush the system . a simple garden hose will do the trick simply remove Both hoses to the heater core with the hose at the bottom line apply the garden hose until liquid comes out at the top of the other hose will probably see a lot of gunk. Also ensure that the vacuum line to the round ball under the hood is connected and not dry rotted.this will cause a vacuum leak to not allow the switch to fully engage from cold to hot. I hope this helps you.
SOURCE: 2006 grand prix heater only blows cold air. both
Sounds like the temperature blend door actuator may be bad or the vacuum hose to it is disconnected.
Poor Heater System Performance
CAUTION
Check all fluid levels and adjust as needed, before operating vehicle for extended periods at idle.
SOURCE: I have a 2002 Jeep Liberty Limited, 3.7 L motor.
Jeeps are notorious for having broken temperature control (Blend Air) doors. A malfunctioning Blend Air Door actuator probably caused it to break. The dash will have to be removed to replacethe door and the door actuator.
SOURCE: My 2003 Jeep Liberty heater is blowing cold air
Water level perhaps. When you hit the accelerator the water volume increases. Check your water level and make sure that your thermostat is opening and closing properly. Water level I'm thinking
The blower motor works and the a/c works
