I replaced the pwm solinoid on cluch b replaced the wires between tcm and pwm solinoid and I replaced the tcm with one from a tractor that is good. The fault still exists. I placed a multi meter on the lines and when the key is turned on batery volts is seen. Can any one help please??
We completely striped the trans and rebuild it. We could find no fault at all. Whet i swap pwm solinoid b with cluch a the clutch engages. My problem is definitly electrical. There is constant 12volt ont the power lead of cluch b and it should only be 8 volt when engaged. Where else can i look for n short?
