SOURCE: sony kdl-40s2000
I have had an extremely similar problem with my Comcast Motorola DVR and Sony Bravia with HDMI connection. For months I would lose picture/keep sound when changing from a non-HD to an HD channel. The solution that I found is that there is a setting in the cable box setup that will likely fix your issue. Turn off your cable box leaving the TV on. Quickly press the Menu button on your remote to get into the Box setup. Make sure that 4:3 Override is set to "Off" instead of 480i. I believe this will solve your problem.
SOURCE: Sony Bravia KDL-40S2000 40 inch
We have the same problem.. Checked the Sony site after a few clicks got to: http://www.iq.sony.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=966,E=0000000000761838071,K=1708,Sxi=1,Case=obj(460991),VARSET_OBJ=460991,VARSET_TSRC=results,UseTemplate=case.tem,VARSET_TOP=TRUE
We followed the 'simple' troubleshooting tips then called the service center. As mentioned above 4 blinks indicates a bad panel. The repairman that visited said that he is ordering a new power supply (much cheaper than the back panel) for their first try. I will post again when my set is back on.
SOURCE: Sony BRAVIA KDL-40S2000 40 in changing from HD to digital channels
40X2000, both PS3 and DVD player are using a HDMI input and both flicker and loose signal fully, have to turn TV of then back on to get signal back. Sony say they have never heard this problem and replaced board. NOTHING fixed, still same problem.
SOURCE: tv prob
This is the common symptom of defected IC memory 24COxx,replaced this IC so it will works normal again.
Feel free to ask whatever the result...
Hope this may help you;
DON"T FORGET TO RATE:
SOURCE: sony kdl-40s2000 won't stay on and blink red 4 times
That error says backlight failure. It has to be troubleshooted to find out why.
