Question about Kwikset Locks & Locksmithing
I bought 2 kwikset deadbolts.The first one worked out fine.The second one I turn the original key by accident.Now neither key will work.Is there a way to rekey my original key.
Put the 'dummy key' that came in with it, turn it a 1/4 turn right, put smart key in, pull out smart key. pull out the key and insert the key that you would have as a desired key and turn left 1/4. thats it!!!!!!
Posted on Jul 20, 2009
Just installed keyless entry lock. Lock button works fine, enter code and deadbolt only partially retracts. Worked fine the first time, will not completely unlock since. Key works to fully unlock. Tried...
Your lock is under one year warranty, with a lifetime warranty if the problem is mechanical or the finish.
Here is a link to the website warranty information, and from there you can contact them for technical and warranty assistance:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
Good luck-and please provide feedback if this helps!
Oct 11, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
I forgot the code and I lost the key
The Weiser brand and Kwikset brand Powerbolt are identical, so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Aug 03, 2011 | Weiser Lock ED1460X3VKD Powerbolt 1000...
I need to replace the deadbolt. What item works? Keyless works fine.
Your best bet is to contact Kwikset directly. Here is a link to the contact information that you need:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Feb 14, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
I installed this last night and it was working fine. Tested it several times, showed the family, etc...Everything worked great. My son left for 10 minutes and came home and it no longer worked. The keypad...
Kwikset's warranty covers one year electronics defects and lifetime coverage for the mechanical movement and finish.
Here is a link to it:
You can contact them from there for further assistance.
Oct 11, 2010 | Kwikset 907 907-15 Satin Nickel Smart...
Exterior key for deadbolt just turns around and around.
It sounds like the exterior tumbler is bad, it is less expensive to just replace the whole deadbolt than to have the tumbler repaired.
Jun 15, 2010 | Kwikset Professional Door Lock...
Kwikset Smart Key Deadbolt Won't Unlock
Kwikset Smart Key locks are complete junk. I am a locksmith and I am constantly going from house to house replacing these "dumb key" locks with original kwikset pin tumbler locks. What happens is either your key or the wafers inside the lock wear slightly, slightly enough to cause your keys to not turn, and since these locks cannot be picked due to a side bar system, they must be drilled off and thrown away when this happens Unless you have another access point to get in the house. If you do remove lock from the inside, throw it in the trash, buy original kwikset and replace.
Dec 13, 2009 | Kwikset Locks & Locksmithing
Key won't turn deadbolt
Try using your smartkey to "rekey" the lock to the original key... there's really no reason to buy the smartkey system unless you change locks alot... they are meant for the apartment industry more than anything I believe... in any case, the smartkey system allows you to rekey the lock without removing it from the door... so, use the original key and use the smartkey to rekey it or select a different cut and key it to that key... should solve your problem.
Last resort... take it back to HD for replacement.
Sep 09, 2009 | Kwikset Locks & Locksmithing
My key is stuck in my Kwikset deadbolt door lock
spray a little bit of oil where you insert the key turn it a couple of time to make sure it is lubricated then turn to correct location to pull out key hold cylinder in with finger key should pull out
Mar 26, 2009 | Kwikset Locks & Locksmithing
Kwikset smart code touchpad electronic deadbolt
I have the same problem, electronic locking system went dead but still beeps, stuck using keys now...according to the kwikset website though it says "Warranties cover the original residential user of Kwikset Products against defects in material and workmanship as long as the original user occupies the residential premises upon which the product was originally installed." so hopefully they will fix the problem
Oct 12, 2008 | Deadbolt PFK Touchpad Electronic Lockset
Lost keys to my Entry door lock
Visit your local Home Depot and purchase a Kwikset re-keying kit. They're inexpensive and work fine but stay alert and follow the instructions properly. This kit comes complete with proper pins as well as new keys. Good Luck!
Mar 07, 2008 | Kwikset Professional Door Lock...
Locks & Locksmithing Logo
835 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
