Question about Orange PDAs
Orange on unlock mda vario set up
I have unlock my MDA vario with T-mobile and input a orange sim card. I do no receive my voice, my text or picture messages.
I don't want to dial 123 every time to check my voice mail.
Please help.
  • 944 Answers
SOURCE: want manual in eglish language forT-Mobile MDA III (PH20B, HTC Blue angel)
Go to this link and click "user manual" and there are a selection depending which software version you are running; Hope this helps :)
Posted on Mar 18, 2007
SOURCE: MDA Vario 4 problems
It is an registry bug from the t-mobile software..
It has been found on only the T-Mobile branded Raphael's.
How to fix it:
Install an Registry Editor
Go to:
Here is an D-Word registry called: CallIDMatch, the value on my phone was standing on "12". When you edit the value and set it to 8. All of the problems dissappear.
It recognizes every type of storage of contact.
and that is your prob solved ;o)
Posted on Feb 03, 2009
SOURCE: Active Sync. on an MDA Vario 3
i had this problem, everytime i refreshed the mda the pc showed that the phone was connecting then once the mda vario had stopped the connection was lost, what i did notive was that the com port for active sync showed up on my pc as com port 4? which isnt a choice on the mda as there is only 2 ports available com 6 and com 7, what i did was to add new serail services to the pc until i was given com 6 as a choice,(because by default the pc starts off as com 4 then com 5 etc, so goto the bluetooth configuration then click on client apps and keep adding new service until you get com 6 then try and sync via activesync on your phone, if that doesnt work make sure that you have added new bluetooth device which gives you options of what services you would like the phone to use with the pc, click activesync then configure it to connect on com 6 voila that should work fine iv just updated mine to netframework 2.0 and can now run all the apps i want, any problems email me on il be happy to assist any way i can as i was stuck on this problem for ages and ages until i finally solved it hope you succeed.
Posted on Jun 11, 2009
SOURCE: driver mda pu 10 to connect t computer
hello ... plz if any one can help me to get the software of O2 xda exec to connect to my pc ,, plz
Posted on Jul 25, 2009
  • 195 Answers
SOURCE: i need the pc driver for t-mobile mda vario.i lost
you don't need drivers.all you need is activesync.install it before you connect!
Posted on Mar 22, 2010
how to power off
Posted on Apr 10, 2010
0 characters
1 Points
Smashed my screen on my mda vario got a new phone now want to active sync in but cant remember my pssword is there a work around?
Yes, you need to perform a hard reset.
To perform a hard reset
1. Press and hold the Comm Manager button and Voice Command
button on the device. At the same time, use the stylus to lightly
press the RESET button.
T-Mobile MDA Vario hard reset soft reset hardreset softreset
2. Keep the Comm Manager button and Voice Command button
pressed, and the following message will appear on the screen:
3. Release the two buttons, and press the Send button to perform a
hard reset
Feb 05, 2011 | T-Mobile MDA Vario Smartphone
T mobile mda vario 2 of USA and now I want to use it in india so for that i need network unlock code
u can find info via this thread!
Mar 03, 2010 | T-Mobile MDA Vario II 1000 Smartphone
Install Micro SD with MDA
download the manual!
Mar 01, 2010 | T-Mobile MDA Vario II 1000 Smartphone
How do i unlock htc wiza200 mda
There is a very straightforward solution now, thanks to some helpful peeps at xda-developers forum. Simply download a zip file called (Google is your friend).
I used it yesterday and had generated the unlock code within minutes of connecting the MDA Vario with my laptop.
Oct 12, 2009 | T-Mobile MDA Vario II 1000 Smartphone
Window in not starting
Findout from MDA site what is the 'reset to factory default settings' is. Remove the memory card and reset. It will do away with the new SW that you installed. You will loose all settings that you made and the SW that you installed. But your phone will be as good as brand new. In case of Nokia the code is *#7370#. Yours may be different.
Aug 06, 2009 | T-Mobile MDA Vario Smartphone
I need to know how to unlock my tmobile vario device without using the touch screen because it has cracked. I can press a button to 'unlock' then it displays 'tap unlock or press *' However I cannot...
Phone Lock Reset Wizard Mda Vario T Mobile
instructions for
hard resetting a wizard, which is resetting the phone
thus the phone lock as well.
Dead easy really
1. Press the Comm Manager button (top left)
together with the Voice Activation button (top right)
for 2 seconds.
2. Keep holding the 2 buttons above and press the soft reset
(middle right little hole) with the stylus for another 2 seconds.
3. When the black screen appears it'll ask you to click Send
That's it All done !!
The wizard's going to reboot and reset himself.
Good Luck.
May 17, 2009 | T-Mobile MDA Vario Smartphone
MDA Vario died - HELP
hi. i have had the same problem and have had to change the battery twice in the three years i have had it. sometimes the batteries that you can buy off ebay are quite cheap but go off without any warning fairly quickly.last one i have bougt has lasted me 1.5 years without any probs.
my other advice would be to back up your contacts/other sensitive information somewhere safe( your phone SIM for example- which has to be done one at a time for the mda vario)as well just in case.
hope it helps
Aug 16, 2008 | T-Mobile MDA Vario Smartphone
MDA will not charge
dear there is some problems in the pins of ur MDA...squeeze them with something...then it will work...
Jun 22, 2008 | T-Mobile MDA
T-Mobile vario
another problem if anyone can help is how to send contacts from mda vario to mda vario III??????? its getting me down!!!!
also having problems with sync so cant load onto pc then copy but it used to wk!!
Jan 18, 2008 | T-Mobile MDA Vario Smartphone
Pda network unlock
visit and search for the solution to cid/sim unlock the mda.
Jan 15, 2007 | T-Mobile MDA
PDAs Logo
Top Orange PDAs Experts
Cosma Papouis
Cosma Papouis
William Dehn
William Dehn
Are you an Orange PDA Expert? Answer questions, earn points and help others
