I have a hotpoint fdl570 dishwasher, not working, machine pumps out sump water, starts to fill, and all the lights start flashing, and water pumps back out. any ideas?
If you live in and area with hard water, it is entirely possible that mineral buildup is blocking the water fill valve. The easiest way to remedy the problem will b e to replace the valve assembly.
I had an identical problem with the salt and rinse aid lights on the left and the drying and end lights on the right flashing shortly after switching the dishwasher on. When I pulled it out, as this was the only way to look at the pipework, I noticed a big kink in the water hose. Removing this and obviously sorting out the flow problem has resolved the issue.
1)check the blockage in drain.(any block in drain hose)
2)check the drain motor working.
3)remove the water manually and start up.(if it works may be on the drain pump problem)
I had same symptoms on a Hotpoint dishwasher.
Turned out to be a failed water heater.
The logic in this case goes like this:
When wash cycle starts, the first thing the machine does is pump out any water that has collected in the sump since it was last run.
It then allows a small amount of clean water in and enables the water heater.
If heater okay, it then continues with the rest of cycle.
In this case, the control board detected failed heater so pumps out the water and then stops with an error code shown by a flashing lamp.
No simple fix I'm afraid - machine had to be turned on its side, bottom panel removed, several items had to be removed to get at the water heater which was then repalced with a new one.
You dont state what make/model your dishwasher is so maybe worth adding this information as someone else may recognise your fault and have a quick fix.
No solution! tried resetting to factory defaults but ended up that even the drain pump stopped working. after flooding the kitchen (nearly). I decided it was terminal and am loking for a new dishwasher urgently as I type. Cheers.
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem. I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing. Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
I had this problem too, but discovered the cause and the remedy.
The flashing eco light signifies that the drain sump has water in it. Before the machine takes on water it checks a float located in the sump. If the float says that there is water in the sump then the machine presumes that there has been a problem when draining and decides not to take on any more water.
In my particular case, the sump collected extra water after the machine has last drained itself because the bottom spray arm has come off and allowed some water to enter the machine. Make sure that you check that!
The simple solution is to empty the sump of water. Do this by tipping the machine onto its right side. Warning! You will get wet feet! There was about a 1/4 pint of water in my dishwasher.
After that you should find that your dishwasher works perfectly again! Why Hotpoint couldn't include this simple task in their manual I'll never know! Health & Safety I guess...
food stuck in drain pump remove and clean out or scoop out - soak up all water then fill with 3 or 4 hot litres of water . cancel programme , start new one ( first thing unit does is switch to drain cycle ).
Then rock machine back and forth - this sometimes frees jammed debris thus pumping out of machine.
This works for me i have done it several times and it works
