Question about Toshiba Satellite A55-S106 Notebook
Power supply The laptop refuses to turn on even when it's connected to an outlet. I've taken the laptop to Radio Shack and the man behind the counter told me that it's because the power supply in the laptop is malfunctioning and is not providing the power the laptop needs to function.
  • Carprincess Nov 19, 2007
    please send me a e-mail if a need to buy a new power supply or if a need to take my computer to a professional. thank you.
  • 883 Answers
With little info to go with here, you must start with what is known to be in good working condition. Based on what you said, you must start with a known good power supply connected to a known good outlet without a battery installed in the laptop. Radio Shack may be correct on this one. Alternatively, you can start with a known good and charged battery only. If still no power up, then power conversion inside laptop may be an issue or cpu, or....the list grows from here so best to take the computer to a professional.
Posted on Nov 20, 2007
Jumper box
Go to a radio shack or a place like it, you can buy a charger with universal plugs that will fit in your charger, the other end will plug in your wall outlet.
Jun 06, 2013 | Computers & Internet
I have a Radio Shack regulated 3 Amp power supply (13.8 V DC model 22-504). The circuit breaker keeps cutting out, even when no load is connected. When I turn it off, click the reset button, then turn it...
I assume you have a bad regulator transistor. Check for a shorted transistor out of circuit (disconnect the wires from the transistor before checking for a short). For any further help please email me at
"Original Radio Man"
Feb 12, 2013 | Radio Communications
Acer Aspire 5536 only gives black screen when i connect power supply
  • Nothing is more annoying than a monitor that refuses to turn on. Make sure your Acer monitor is plugged in to a functioning outlet. If it's plugged into a power strip, try replacing it with a new one or moving the plug to a different outlet. Ensure that both ends of the power cable are plugged in firmly and securely, and that the connection to the monitor is not loose.
Cable Issues
  • Your Acer LCD monitor will usually accept DVI and VGA inputs. If you have an older computer, a VGA cable should work fine. If it doesn't have a VGA port, you'll need to obtain an inexpensive DVI to VGA adapter at your local computer store. A DVI cable, however, is compatible with most modern computers and offers superior picture quality over VGA. Make sure you're using the cable that's compatible with your system, and that you have the proper conversion adapter, if necessary.
Jun 19, 2012 | Computers & Internet
Does cq61 laptop works without battery
I would assume that the wire/power supply is more likely to be the problem. Even if the battery is completely shot, most laptops will start if the power cord is plugged into the outlet and the laptop is turned on. You should check on replacing the power supply / power cord. Buy it from a store that takes returns with no questions asked. I've even bought one, tested it in the store, (after asking in advance if I could do so). This is a good idea if you live 40 miles from the place it's purchased.
Feb 21, 2012 | Compaq Presario CQ61-310US Laptop
How do i use my infared headphones and can i use them on my laptop
You should be able to use infrared headphones with your laptop. You don't give a brand or model, but they're all pretty much the same. The transmitter connects to an audio source (and to a power source as well, so you'll need an AC outlet nearby) with the appropriate cable, and you just put the headphone on and turn on the power. Some headphones take regular batteries, while others have a rechargeable battery like a cordless phone; those are recharged when you hang the headphones back on the transmitter.
The couple of infrared headphone systems I've used both had RCA input jacks. The headphone jack on a laptop takes a 1/8-inch mini-stereo plug, so you'll need an adapter with a regular stereo patch cord (RCA plugs at both ends) or a cable with the right plug on the computer end and RCA plugs at the other. Radio Shack sells both.
If you have questions about your headphones, you can usually find a downloadable manual at the manufacturer's website.
Jun 21, 2011 | Computers & Internet
No power
If your radio is powered by batteries, try changing the batteries. If your battery needs to be charged, try that too. If your radio is powered by an alternating current (AC) cable, make sure the plug is plugged into the outlet correctly and that the outlet is not deteriorated. If the outlet that you're plugging the radio into is controlled by a switch, make sure that switch is turned on. If all of that doesn't work, it may be that the batteries contacts are deteriorated or a cold solder joint is causing bad contact with the power supply.
Mar 04, 2011 | Radio Shack 20238 AMFM
I have a 2 wire home portal 1000HW. We recently had a power failure and the unit stopped working. I have checked the power supply with a vom and it is putting out the rated 6V. I have tried multiple...
Check your current rating on the OEM power supply.. I think your power supply needs 2 amps at 6 Volts. The cheap ones at radio shack are usually only 2 ma.
Jul 05, 2010 | 2wire HomePortal 1000HW DSL Modem and...
Dell d600 will not power up. When connected to AC power the green led will go out. Is this a jack problem or a internal supply or what???
well, if you try more than one wall outlet and you have that issue, it is possible that you may have a bad plug. you can always buy a power supply at radio shack or best buy. and test it. or the best solution is go to a local computer repair shop, i'm sure they have plugs to try and see if it powers up.
Oct 17, 2009 | Dell Latitude D600 Notebook
Scanner does not turn on
check your power supply, the transformer that plug in your outlet usually burn out. You can take it any radio shack, and they be Glad to help and assist you especially with their products. they also may have extra plug in laying around and can test it for you, if needing new plug in, you can pick one up right there.
Aug 28, 2009 | Radio Shack Pro-2018 Scanner
Need electrical connection..or diagram
You need a 12 volt DC power cord which is compatible with your unit. I would begin by taking it to a radio shack or even a WalMart electronics department. good luck
Jan 22, 2008 | Farenheit TID-840 6.5 in. Portable...
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
