Question about Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher
CL error message on Dishlex dx 403
Just stopped working. When you hit the program button it comes up with CL
5 Suggested Answers
SOURCE: I have an Dishlex DX
CL - child lock!
hold the Program butoon down for 15 seconds
Posted on Feb 17, 2011
  • 69 Answers
SOURCE: dishlex dx 403 does not dry dishes - fan dry on red led
Ther have been a lot of complaints about the drying performance of these machines. One solution suggested by Electrolux is to use the "anti bacterial" wash mode, as this is a higher temperature wash, therefore dishes dry better. If you are using Eco wash or Quick wash, drying performance is not very good- Electrolux recommend leaving door ajar at end of cycle to improve drying. Also, ensure your Rinse Aid compartment is topped up, as Rinse Aid greatly improves drying performance.
-Please note: these dishwashers will not dry plastics and other items that do not hold the heat very well!!
-Also, you should be able to hear the drying fan running at the end of cycle- if not, then you may have faulty fan (uncommon), or control board (more common).
Good luck!!
Posted on Aug 12, 2009
  • 457 Answers
SOURCE: looking for a user manual for my Dishlex 500
you can order at sears parts direct.
Posted on Feb 25, 2010
SOURCE: have a dishlex dx302 it
I have a dishlex global 300 and it cuts out and trips our saftey switch after the wash cycle. I turn it back on and then put it on the rinse cycle witch it does fine. Can you please help me to work out how to get it from switching off all the time.
Posted on Aug 29, 2011
Error 50 is coming up on my dishlex dx 301 and it is not working. It is about 3 years old.
A 50 Code means an electrical fault
This is something that is triggering the computer to think a conponant has failed
It could be a faulty motor for eg
Sometimes water in the door or condensation under the unit can cause this
Dishlex suggest you call their service center when this code comes up
hope this helps
Mar 27, 2015 | Dishwashers
Dishlex 403. Error Code 30 is stopping machine from filling
First thing you need to do is Check and make sure the FLOAT is moving inside, once you get this working properly, then it will reset itself. There is not a Clear CODE for it.
Mar 01, 2014 | Dishwashers
Electolux Dishlex DX403
May I ask what the problem is so I can help you more.
If you need the manual it is on the link below. The 301 is the same as the 403
http://www.dishlex.com.au/common/pdf/156987653_DX301.pdf
Apr 24, 2011 | Dishwashers
How do I cancel the child lock on dishlex dishwasher 2005 model
Hi, ours is the 403 model but im guessing it will be the same operation for ur 302 mod, In prog selection mode press and hold start for 5 secs, indicator lights should flash then CL wiil appear to indicate child lock on........ in this mode by pressing and holding any button for 5secs will temporarily give you access to program setting and control an will auto reactivate after 15 secs, ..... too disengage permanently firstly you must temp unlock as above then press and hold start for 5 secs, CL should display with a long beep to indicate CL is off..
Cheers Jeff QLD
Apr 21, 2010 | Electrolux 18 in. ESL4114 Slim-Line...
Hi, My Dishlex dishwasher DX 302WB ia showing 10
check this
1)blockage in boiler tank.(cleaned)
2)water pressure is less.(check solenoid filter)
if it's programmed in timer mode within the period it must reach the water level in the tank due to this also it may happen.
Jan 06, 2010 | Electrolux Dishwashers
Error Message CL in the front panel
Error message CL solved. CL means child lock. To deactivate press two linked buttons (on my machine the right options button and the temp button) together for a couple of seconds.
Mar 29, 2008 | LG WM-12230FB Front Load Washer
CL ERROR
"CL" means Child Lock. Press and hold RINSE+ & PRE WASH Simultaneously for about 3 seconds to de-activate.
Jan 16, 2008 | LG WM-1480FHD Front Load Washer
Error message 714
hi RESET !! first clear all files from the memory cards (if there is) enter "001" and press "set" to delete all files enter "1" (page 143 ) http://service.us.panasonic.com/OPERMANPDF/DX2000AU.PDF take the battry out (page 196) unplug the device for a day and assemble it hope it works good luck
Apr 04, 2006 | Panasonic DX-2000 Plain Paper Laser Fax
Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher Logo
171 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Gerard Curran
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
