Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
When i turn on my tv it make a winding siren noise but no picture, i replaced the lamp, would it be the colorwheel?
  • Samsung Master
  • 8,617 Answers
Sounds like the color wheel as it can almost sound like a whirling siren or a loud screeching sound
Posted on Jul 20, 2009
No picture makes a siren noise
The color wheel needs replacment. You can get the colorwheel from www.tvrepairworld.com which comes with installation instructions on CD. Its listed under the Color Wheel Category
Aug 20, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
Have sound no picture lamp does not appear to be bad when looking at it yellow light blinks the shuts off tv then tries to start and can hear sound but no picture it will keep doing this till i turn the tv...
listen for the colorwheel noise
you'll recall hearing it "wind up" as the tv came on
many of these will go bad and then it will never fire the lamp because the colorwheel doesn't get up to speed
if you don't hear it, suspect the wheel, its hard to get since toshiba never had it as a seperate part
if you do hear it, its probably a bad lamp driver, but unlikely
let the tv go and go, it will try like 7 or 8 times and then eventually spit out an error. your user manual has the error codes, it will tell you if its the colorwheel i belive.
let me know if you need further assistance
Jun 06, 2010 | Toshiba 56HM195 56" Projection HDTV
The picture come on then goes black and then the television turns off. I thought it might be a bulb problem (4 years old). So I bought a new bulb, seemed to work and then began to go black again with all 3...
when the colorwheels start to go bad this is the symtom that shows up. try this listen carefully to the rear of the tv near the lamp door. as you turn off the tv if you hear a slight grinding noise as the colorwheel slows down that means the bearings inside the colorwheel are dry and you will need to replace the colorwheel.
Mar 21, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
When I try to cut on the TV all 3 indicator light start to blink.
listen to the tv from the rear you should hear a slight wind up of the colorwheel just after the power button is pressed. after that the lamp ballast should attempt to start the lamp . if the lamp is bad you will hear a buzzing and see no light coming from the lamp door. if you dont hear that winding up of the colorwheel its bad and needs to be replaced
Feb 01, 2010 | Samsung 50" Slim-Depth DLP HDTV
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
When I turn it on I get a buzzing whine, picture is fine, and now noise has a rattle to it. Would this be the color wheel or maybe the cooling fan?
could be either. remove the lamp. you'll see on the lamp door a plastic protrusion. this is to press the door switch. find that switch and hold it in with a screwdriver. now turn the projector on and look inside the lamp housing in the direction that the lamp would be pointing. do you see the colorwheel spin? it should spin with a high-pitched whir. if you hear the bad noise when it starts up, replace the colorwheel. otherwise, locate the bad fan and replace it.
Oct 17, 2009 | Optoma EzPro 732H Multimedia Projector
Color issues with tv after replacing lamp. Tv
no this is a main board problem you would need to replace the main board of you tv
Oct 02, 2009 | Samsung HLT-5075S Television
Poor Quality HD Picture
The lamp would make you picture dark.The colorwheel will affect color quality.If brightness is an issue = lamp.If color is the issue = Colorwheel.
Jan 12, 2009 | Samsung HL-S4666W Television
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
445 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
