Question about Toshiba Satellite A215-S4747 Notebook
My Toshiba Satellite A215-S7437 will not boot. Unfortunately by "will not boot" I also mean will not boot to bios, in addition to not booting normally. Essentially, when the power button is pressed, the power light comes on, but the screen does not. I can tell that there is a little hardware acceleration, (HD spinning a little), at first when the power is turned on, but it stops pretty quickly. -I'm assuming this isn't a so much a monitor issue since I never hear any boot noises from the laptop. -Trying to attach an external monitor via VGA does nothing. -The fan that is normally on when the computer is turned on, (the fan over the heat sink on the left side), isn't on during any of this. Is it possible that fan died and the computer won't boot because it checks for that? Or could the fan have died earlier and the heat caused internal damage? It's the only thing I can think of at this point... Thanks for any insight you can give.
  • test65 Jul 20, 2009
    This morning, playing off a hunch, I removed the battery and plugged in the laptop. Oddly enough, it booted up just fine then, screen turned on and everything - though a screen warning that a vague "serious windows error had occurred" popped up.
    Thanks anyway for both of your suggestions.
  • 202 Answers
You should see the post screen if the monitor is working. try hte fn and the monitor or display key. some laptops toggle the display this way. another possibility is the lid switch that shuts off the display when you close the lid. and it could be heat damage.
Posted on Jul 20, 2009
Replace the cmos battery
Posted on Aug 30, 2012
    President:
  • 1,566 Answers
The possible solution is to bring the laptop to the authorized service center.
I have a toshiba A215-S7437 and i get the error message read disk error when trying to boot up
A disk error is a fatal error on the hard drive, SMART monitoring will show you this in the BIOS, restoring to factory settings will not cure it.
You need to get a new hard disk and reinstall your OS
Apr 25, 2012 | Toshiba Satellite A215-S7437 Notebook
Diagrams for Toshiba A215 S7437
The Toshiba Satellite A215-S7437 Notebook PC, is one of the Satellite A215 series of Notebook PC's. It is a fancier version of the A200 series.
Pictorial guide to disassembly of the A200/A205 series,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
[Note* Page 2, 3, and 4, are listed at the top, and bottom of the page.
In white; Page1::Page2::Page3::Page4::Find another model ]
Service Manual for the Toshiba Satellite A215 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Under the main heading - Toshiba, go down to the subheading -
Satellite A10. (A10 in blue)
Go across, and click on A215. (In blue)
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name { A215 }, it may take up to 30 seconds before the first page comes up.
The motherboard diagram follows this diagram,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
The CPU is an AMD Athlon 64 X2 TL-58, (Turion Core ), mobile Processor,
http://en.wikipedia.org/wiki/List_of_AMD_mobile_microprocessors#.22Tyler.22_.2865_nm.29_2
Processor has two processor cores that can operate up to 1900MegaHertz, or also stated as 1.9GigaHertz.
(1900MHz/1.9GHz)
Does Not mean a total of 3.8GHz.
Total is still 1.9GHz. It's just two processor cores teaming up on the same task.
Chip and Chipset denote I.C.
Integrated Circuit.
The motherboard chipset is an ATI RX-690 (Southbridge chip is ATI SB600 )
http://en.wikipedia.org/wiki/AMD_690_chipset_series
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 15, 2012 | Toshiba Satellite A215-S7437 Notebook
My toshiba laptop is asking for a password it will not boot without it as soon as you turn it on it wants a password
BIOS is set to password on....
did anyone make changes to ur laptop....
if so then only he can unlock it....as BIOS passwords cannot be unlocked....they are embeded in the BIOS microchip...
only a BIOS update can undo it...and that's very RISKY...
Oct 31, 2010 | Toshiba Satellite A215-S7437 Notebook
Toshiba Satellite A215-S7422 won't boot-up stuck with boot screen the bios is ver.1.00 need help how to make it boot up again,
My Toshiba A215 starts up but won't boot from any source_CD,external floppy, hard drive,etc.. I swap memory,CPU,hard drive ,nothing works,have any one got any solution?//
THANX
Sep 17, 2010 | Toshiba Satellite A215-S7422 Notebook
Toshiba A215 doest boot at all( screen empty) tried removing the CMOS battery but no change at the moment
that happened with me once , i solved it by separating the laptops battery for 8 Hrs to let the mother board discharge and cleaning the mother board and memory slots and cpu socket with the air blower.
good luck
Feb 19, 2010 | Toshiba Satellite A215-S7437 Notebook
I need the bios reset password for a toshiba laptop
there is no actual password. you need to remove the ram and short out two pins underneath the black plastic they look ike two E's connected like E3. use a flat blade screwe driver. do this while powered off!
Nov 04, 2009 | Toshiba Satellite A215-S7437 Notebook
System corrupted and would not boot during installation of sp 1
Try cheking the Bios Settings Before Runing the Recovery CD.
Is your computer's bios set up to boot from the cd rom or hard drive first?
If so, try changeing the setting so the computer boots from the CD Rom.
Mar 22, 2009 | Toshiba Satellite A215-S7437 Notebook
Toshiba Satellite A215-S7437 Laptop Password Problem?
You should first check if the pasword is set on the hard drive. If so you can simply change the hard drive and it will then boot and ask for the operating system disk. If not, you should try by removing the cmos battery and waiting at least 10 minutes. (this works on older laptops) however, the laptop's power suply cable and battery should be removed prior to performing this procedure.
Jan 10, 2009 | Toshiba Satellite A215-S7437 Notebook
Toshiba Satellite A215-S4747 Notebook Logo
1,932 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
