Question about Philips Audio Players & Recorders
Philips HTS8100 not working after non use of 1 month
Unit was left unplugged for about a month. when hooked up again, soundbar would turn on, but go straight to 'disc source' and not be able to switch to any other source. even the disc source didnt function. the only things i am able to do are adjust volume related things on the remote (which doesnt do anything since none of the sources are functioning), and when the power is pressed down, 'entering low pwr' would show on the soundbar and will display that until unit is unplugged.
SOURCE: Low Volume from right speaker of entertainment center - turntable only
Hi There thanks for your very good desctiption of the problem it really helps to have a lot of detail...
There are Mono and stereo types of stylis cartridges and it sounds like you have a mono equipped into a stereo amplifier..
If there are 4 small coloured wires visible under the stylis then
its a stereo stylis and should work, have a close look and maybe one of the small wires has dropped of the small pins on the back opf the stylis cartridge.
If there only two wires visible then its a mono cartridge and this is why you only have sound from one channel..
So answer is wires dropped of the stylis.
or
Wrong type of stylis cartridge.
or
if there are four wires and thay all look connected then perhaps the stylis is faulty and you need to replace it...
Cheers from YU BEUT
Posted on Feb 03, 2008
  • 97 Answers
SOURCE: I recently bought a Philips
low power is just another word for standby, when doing this press the power on button again, or press something on the unit to power it up. if it still does not work you might have a power issue on the power board. call your manufacturer or ceck your manual.
Posted on Jul 22, 2008
namizhka
  • 148 Answers
SOURCE: my philips hts3154 home theatre
How to Remove a Stuck DVD From Your DVD Player
  1. Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
  2. Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It’s the part that holds the DVD loader in place.
  3. Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don’t want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
  4. Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn’t quite finished yet.
  5. Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD players will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center.
  6. Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you’re careful. You should be able to access and remove the disc.
Posted on Sep 19, 2008
SOURCE: RCA 27' tru flat sdtv- power light comes on- no display,no sound.
How do you unlock your TV from Protective Mode? There is a certain code that you need in order to unlock the Television. The technicians are saying that it went into Protective Mode, when it umplugged all by itself. I need the code so I can watch my TV again.
Posted on Nov 24, 2008
dj x
  • 61 Answers
SOURCE: put in new car battery, now can't get aux to work
Hi there
hold down the source button to turn off the unit (unit must be off)
now hold down the function button till it beeps once it has done this press the function button i think 3 or 4 times and you will get a message on your deck unit saying (aux - on,off) turn on and press the source button to turn the unit back on to the CD or radio now press source button2 or 3 times till Aux shows up (press means push it let it go) (hold means don't take your finger off button)
hope this solves your problem
Posted on Mar 05, 2009
Philips Soundbar
Why can't you turn it down? For more information, or should you have more questions, please visit my website at audioserviceclinic.com. You may contact me directly through the website. Thank you.
Dec 19, 2013 | Philips Hts8100 Home Theater System...
After the soundbar has been running for awhile the sound disappears. At that point I have to turn it off for a few minutes and turn it back on. After another period the sound will disappear again. This...
Hello, that sounds a power supply problem, maybe a bad capacitor or the amplifier chip is overheating, basically the board inside needs be checked and fixed.
Thanks
Nov 22, 2013 | Philips HTS8100 AmbiSound Soundbar DVD...
How do i repair low audio on my philips soundbar hts8100/37. All connections are correct. I have to turn sound bar up to max volume to hear it. The problem is intermittent. Could it be a software problem.
My HTS8100 2 yrs ago stopped working properly, sound was on its max and little was heard. Well after searching for solutions and took it for repair which was a waste, my brother came from Australia for a holiday who is a technician and fixed it for me. The problem is in the subwoofer, I am uploading a photo where this part is , STRX6759 SANKEN INTEGRATED CIRCUIT STRX6759. Its behind that capasitor. When I changed it the sound worked. Hope you will find it useful.
Feb 01, 2011 | Philips SoundBar DVD Home Theater with...
Philips HTS8100 owner. Have ben using the soundbar since Decembr 2007 with no issues. it is intgrated with a sony bravia tv. tried to turn on sound (tv input) and have very limited sound. Turned up to...
Same problem with my HTS8100. Little-to-no sound. Sometimes sound comes on very intermittently. I downloaded the software patch from the Philips website and installed it. This fixed the sound problem for about a week, then the problem came back. I'm not sure what else to do.
Dec 22, 2010 | Philips SoundBar DVD Home Theater with...
My soundbar (Phillips hts8100) freezes on low pwr standby.
hi
i have also same problem, by that time i am pressing tv/ disc button then it should be okay
Oct 11, 2009 | Philips SoundBar DVD Home Theater with...
How can I reset my Philips Soundbar system
You just remove batteries , unplug all cables, then put everything back together. This will reset the unit to factory settings.
May 15, 2009 | Philips SoundBar DVD Home Theater with...
I own a HTS8100 SoundBAR. A friend stepped on the remote control and it doesnt work anymore. How and where Can I get a new one. The local Philips supplier in Botswna has failed to get me one for the last 9...
You can order it directly from Philips.
http://philipsparts.fox-international.com/PhilipsConsumerModelDetail.aspx?&hlt=Link_PartsAcc_Home_Portable_Entertainment&scy=US&model=HTS8100/37&slg=AEN&mid=Link_PartsAcc_Home_Portable_Entertainment&session=20090603003207_72.73.160.138&ctn=HTS8100/37
Apr 11, 2009 | Philips SoundBar DVD Home Theater with...
Dvd unlocking for brand new Philips Soundbar HTS6100
Figured it out unlock for HTS6100, it's the same as for HTS8100
1. Turn on
2. Press Eject
3. Press 9, 9, 9, 9, 0
4. Swtich it to standby
5. Turn the player back on & it should now be region free.
Jan 04, 2009 | Philips Code Free DVD Player
156 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
