Washing Machines Logo
D
Dan Rinehart Posted on Nov 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore Model 110.2234 top loading wash machine About a year old It is so loud on spin cycle we cant hear each other talk in the other room with laundry door shut What is the problem?
Would a penny and a nickel sitting upright in the space at the bottom of the tub between edge of the agitator and tub cause this noise
Steve F
Level 3:
  • Master 1,361 Answers
  • Posted on Nov 20, 2016
Steve F
Master
Level 3:
Answers
1361
Questions
Helped
566850
Points
3788
Possible bearing failure but if only a year old, it should be under warranty. Check around the spin bowl for any foreign objects sticking through the tub. Perhaps a bra wire or nail , screw etc or something has come out and stuck in the tub.
Testimonial: "Would a penny and a nickel sitting upright in the space at the bottom of the tub between the edge of the agitator and tub cause this"
  • Steve F Nov 20, 2016
    yes, they could. If there are other coins stuck between the tubs, they will rattle around and hit the tub when its spinning. Check your pockets before putting the washing in. To get the coins out you normally have to take the spin tub out. Not an easy job. You may be able to get some of them by removing the agitator. I'm not sure how they come out on your machine.
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
1helpful
Kenmore front loading washer drum is loose and makes loud noise when spinning?
sounds like support springs for the drum have become detached or broken. Do not use, suggest new machine as old ones not worth the investment.
Excessive noise during the spin cycle. we have owned the washer for 16 months. problem started 1 wk. the machine is level.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Tub support broke
POST THE MODEL NUMBER PLEASE
My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
2answers
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Noisy
it could be the coupler between the motor and the transmission
2helpful
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Alexander
vince
