Question about Canon PIXMA MP170 All-In-One InkJet Printer
Change ink cartridge
I can't open up my printer to change the cartridges and I have mislaid the instruction manual. The main part opens ok but the cartridges are tucked away on the right hand side and I can't get to them. Help!!
  • 74 Answers
The printer must be powered ON before you lift the scanning unit.
The cartridge holder will move to the left after you lift the scanner. Pull the scanning unit support down to hold it in place. Now you can replace the old cartridge.
Posted on Nov 19, 2007
How do you change the printer cartridge, please? I have mislaid my manual.
First make sure that the printer is on and the front cover and output tray are open. Next open the paper output cover by rotating it down towards the output tray. The ink cartridge carrier should move to the ink replacement position on the right side of the printer. Push the cartridge lock lever down until it clicks to unlock the cartridge that you need to replace. (The color cartridge is on the left.) Pull the cartridge towards yourself to remove it. Now open the replacement cartridge packaging and remove the protective tape from the cartridge. Push the new cartridge fully into the open spot from removing the old cartridge. (The label should be up and the copper covered sections should be down and facing forward.) Now push the cartridge lever lock up to lock the cartridge in place. If the lever doesn't move, check that the cartridge is fully forward in the slot. Finally close the paper output cover. Wait for the printer to complete the print head clean cycle before using the all-in-one.
Note: only remove and replace one cartridge at a time. Work quickly to minimize the chance of the ink system drying out after removing the protective tape.
Canon has the steps to change any ink cartridge on the Pixma MG4250 support site in the FAQ labeled Replacing an ink cartridge. The full text and pictures are available here: http://www.canon.co.uk/support/consumer_products/products/fax__multifunctionals/inkjet/pixma_mg_series/pixma_mg4250.aspx?type=faq&search=1&searchurl=/support/consumer_products/content/faq/?itemid=tcm:14-1276595 . You can also get the User's Guide and other documentation here: http://www.canon.co.uk/support/consumer_products/products/fax__multifunctionals/inkjet/pixma_mg_series/pixma_mg4250.aspx?type=manuals&language= .
I hope this helps.
Mar 22, 2016 | Canon PIXMA MG4250 Inkjet Multifunction...
Change cartridge before its finished on epson stylus sx100
  1. Do one of the following:
    • Windows: Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Printer Settings. Then click the Maintenance tab.
    • Macintosh: Open the Applications folder, open the EPSON Printer Utility 2, select CX7400 Series, and click OK
  2. Click the Ink Cartridge Replacement utility icon and follow the on-screen instructions to replace your ink cartridges as necessary.
Sep 08, 2014 | Epson Stylus Office Equipment & Supplies
HP 6700 printer change ink cartridge
http://images10.newegg.com/User-Manual/User_Manual_28-415-214.pdf
Open ink access door.
1. Make sure the printer is turned on. Never turn off the printer when ink cartridges are missing.
2. Open the ink cartridge access door. [This is the panel that is to the left of the touchscreen. To open, put your fingers on the upper left hand side of the panel (by the logo: HP OfficeJet 6700 Premium), You should be able to gently pull the panel so that it opens out.]
NOTE: Wait until the print carriage stops moving before proceeding.
3. Press the front of the ink cartridge to release it, and then remove it from the slot.
4. Remove the new ink cartridge from its packaging.
5. Using the color-coded letters for help, slide the ink cartridge into the empty slot until it is securely installed in the slot.
Replace the
Aug 18, 2012 | HP Officejet 6700 Premium E-All-In-One
On Epsom Stylus NX110 I cannot get the cartridges to the change position If I go into cartridge replacement utility I cannot open that and do not have a printer in the lower right hand corner to access...
Here is what I found on Epson Web site. Click on link below. IF YOU FIND THIS HELPFUL PLS RATE ME. THANKS AND GOOD LUCK......
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=128285&prodoid=63083739&category=Products
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Replace Cartridges Using a Printer Software Utility
For best printing results, use up a cartridge within six months of opening the package. If you need to replace a cartridge when the ink light is flashing or off (before the cartridge is expended), you can run the Ink Cartridge Replacement utility.
1. Windows: Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Printer Settings. Click the Maintenance tab.
Macintosh: Open the Applications folder, open EPSON Printer Utility3, select your printer (if necessary), and click OK.
You see one of these screen SEE ATTACHMENT BELOW
Mar 21, 2010 | Epson Stylus NX115 All-In-One InkJet...
Replace ink cartridges
1 - Open the top lid 2 - Open the ink cartridge carrier 3 - Shake the ink cartridges 4 - Unpack the ink cartridges 5 - Remove the yellow tape from each cartridge as you get ready to install it, but not before 6 - Install each color cartridge into its corresponding color slot pressing down all the way until it "clicks" 7 - Close the ink cartridge carrier 8 - Close the top lid
At this point the printer should charge its ink cartridges. Let this finish before using your printer.
Hope this helps!
Feb 18, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How to change ink cartridge in epsonnx110
Jan 01, 2010 | Epson Stylus NX115 All-In-One InkJet...
I'm trying to change an ink cartridge. Cartridges
Usually the printer manual will have instructions on changing the cartridge. If you don't have a manual, there is a chance you can find one online by googling the make and model number. On some printers the cartridges center when you open a door to access them, or lift a lid or a scanner deck, or turn off or turn on the printer.
Oct 03, 2009 | Office Equipment & Supplies
Ink Cartridge
I JUST FOLLOWED INSTRUCTIONS AND IT WORKED THANKS SO MUCH
Nov 20, 2008 | Canon MP610 Photo All-In-One Printer
Canon PIXMA MP170 All-In-One InkJet Printer Logo
97 people viewed this question
old marine
old marine
