Question about Samsung Remote Control
Blue turns to green, faces turn pink.
I have had a 23 inch Samsung lcd hdtv for about 2 years, It was working well, but, suddenly, the colors change, as described above. So far, it is intermitent, but I'm concerned that it will become permanent. Anything I can do to correct the problem or is there a reliable service center in South Florida?
  • 1 more comment
  • shirjon1 Jul 20, 2009
    The problem is with the tv, not the remote control.
    The model number of the tvv is LN-82341W. The code is LN82341WX/XAA
  • shirjon1 Jul 22, 2009
    This is a flat screen tv. There is no picture tube.
    I have already replied to you.. The model number is LN82341WX/XXA. It is a flat screen lcd tv.
    Brigadier General:
  • 7,191 Answers
Please check the model number of the TV, the nearest match is: LN-S2341W.
Please reply and provide your ZIP code so that we can direct you to the nearest service center.
Thanks.
Posted on Jul 22, 2009
  • 11,896 Answers
This is the convergance board in the tv, or the color picture tubes failing. There is not much you can do to help it except wait until they go and then replace capacitors on circuit board or picture tubes.
Posted on Jul 20, 2009
What is the model number of your 23" inch Samsung LCD HDTV?
There is green and pink on color on half of my lcd
I did some research and I found this link that will should you the schematic of the LCD technology,It sounds like one of you LCD color ships is not working properly,your TV has 3 ships (BLUE,GREEN,RED)
you can see how it work; http://www.oerlikon.com/ecomaXL/index.php?site=OPTICS_EN_lcd_projector .Whay happening is that due to the high density the lamp this ships tent to wear out and the three major color don't mix properly causing the color discoloration on your picture.You can find the parts you need at DM http://www.discount-merchant.com/?click=52978 (The correct diagnostic can only be made be a tech) I hope this info helps you please keep us posted .
Sep 25, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White has turned pinkish
sounds like the linear adjustment is out of whack.....most projection type tvs, projection, lcd, plasma, have to be correctly aligned so that the color grids overlap each other to properly display the correct hue being created. you'd need the service code to re-adjust it, or have it serviced. also possible that one of the color grids is bad, but if you have all three (red,blue,green) colors showing on the entire screen area i would doubt it
Jul 24, 2009 | Vizio GV42L 42 in. LCD Television
Change in color, computer problem inside TV
For "thechances", The LVDS cable has gone bad. This cable connect between the mainboard and the panel. The replace the cable will fix the problem.
Feb 17, 2009 | Vizio L32 32 in. LCD HDTV
Pink shadows
you need to get the HDMI cord.
Jul 21, 2008 | Sony Playstation 3 (PS3) Console
Pink highlights on LCD screen
IT SOUNDS LIKE THE MAIN BOARD IS BAD. THERE IS 2 DIFFERENT VERSIONS FOR THIS SET .AM02 UNITS OR VERSION 0001 UNITS. THE PART NUMBER IS BN94-00695E. THEY BOTH ARE ABOUT $210 + $50 CORE.
DON..
Jun 02, 2008 | Televison & Video
Samsung 61" DLP TV color issue
The color wheel is either defective or needs to be re indexed.
May 18, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Picture turned pink
This all of the sudden happened if so you may have lost the green alot of times yoiu can fix the CRT drive Brd there is a video amp ic and a resistor that can be replaced or yo can replace the whole Brd a little harder to do than just replacing the parts on the Brd
Oct 17, 2007 | Samsung HC-P5241W 52" Rear Projection...
Sony bravia lcd tv-
If you are using a HD cable box or satelite with component outputs, be sure that all 3 cables ( green, red, and blue ) are making good connection.A loss of red or blue will cause color shift. Usually,if the tv menu comes up as the correct color but the picture dose'nt, it is most likely a signal problem.
Jul 01, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Samsung LN-S2641D 26 Inch Wide LCD HDTV w/ Integrated ATSC Tuner Color Issue
if your tv is on warranty take it back to the agent who you buy it from.if it is out of warranty have a tech look at it for repairs.goodluck.
Apr 03, 2007 | Samsung LN-S2641D 26 in. LCD HDTV
Samsung Remote Control Logo
131 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
