Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
No warning code, green light on but no chlorine produced???????
No warning code green light on and counts down but no chorine generated intex
  • 297 Answers
Make sure your ppm is at least 3000 low salt may not trigger an alarm but is not sufficient for generating chlorine
also make sure you are running the generator for at least 4-6 hours to give the chlorine time to register
the system itself blows out very minute amounts of chlorine but build up after hours of being on
Posted on Jul 21, 2009
Salt water system light green, no error code, timer counts down... but no chlorine... Help!
There is a small wire mesh inside the unit that measures the chlorine/salt ratio. If it is a few years old it will have **** and calcium buildup. Take the end off, and clean the mesh.
Aug 08, 2013 | Intex Automatic Salt Water System for ...
24' X 52" intex pool, I am having trouble with my cholinator not producing chlorine in the water. there are no signals or lights flashing. but when I test for the free chlorine on the strips is do
If you can remove your generator try and bench test it. Fill with pool water and do a chlorine test. Run the generator for a few minutes, unit should produce bubbles when the cells are turned on. Run another chlorine test and make sure it is higher than original test. You should also test your combined chlorines to make sure you don't have excess chloramines in the water. Also check for any buildup on the generator plates which should be acid washed, and verify salt concentration.
Apr 01, 2013 | Intex Automatic Salt Water System for ...
The intex system light is green ,but when i test water no free chlorine is registered
I have an 18 X 33 X 48" oval pool (14000) gallons and I run my pump in the summer months at 10 to 12 hrs and chlorinator at 8 to 10 hrs of those pump hrs and hit a chlorine level at 2.0 to 2.5 ppm.. Green chlorine light means you are generating, it does not mean you have the correct level.. Increase your cycle time and check after 3 days... Please post a comment if this helps! Good luck,,
Aug 08, 2011 | Intex Automatic Salt Water System for ...
We have a 15' by 48 " pool with an Intex saltwater chlorinator.About two weeks ago the low salt light started flashing .We ended up adding way too much salt (160 lbs)because the low salt light kept...
First of all green water can arrise from a lot of different situation.
Low chlorine is one of them coupled with the crappy filter that comes with the intex pools it does not filter enough.
Start with getting your salt level to 3000ppm
any lower than 2700 and you will not generate enough chlorine and any higher than 3500 and you could go cloudy or trigger high salt alarms
you need to get the salt test kit that reads in #'s not color the color ones has to much of a variance
once your salt is at 3000 clean your cell then filter filter filter
I run my filter 24/7 if it is not generating chlorine I am filtering.
Clean your cartridge every few days
I have had the same 2 cartridges for this being my 4th season and have never been green or replaced the filters.
Also I reccomend a non foaming algecide
Just follow directions on bottle
Aug 29, 2010 | Intex Automatic Salt Water System for ...
Intex salt water chlorinator 56602
First of all 91 is low salt content not too much
Are you checking your salt level with a test strip
You need to be at 3000ppm anything under 2800ppm can trigger an alarm and not produce enough chlorine.
Same thing if you are over 3600ppm
all manuals just give you an amount to start with but it is up to you to fine tune it
After adjustments you need to filter only for 24 hours before trying to generate chlorine
Jun 26, 2010 | Intex Automatic Salt Water System for ...
WHAT DOES IT MEAN IF THE GREEN LIGHT IS NOT ON? DOES THE SYSTEM REST AFTER THE TIME HAS RUN OUT, MY SYSTEM HAS 88 DISPLAYED
88 means you are filtering alone no chlorine
Once the generator is set it will run its time like 1-12 hours depending on what you set it at
After this time it will flash 93 meaning it is getting ready for sleep mode eventually it will shut that down and then turn back on at the same time you programed it the time before
There are 2 green lights
top one is that you are filtering
second one comes on about 2-10 minutes after you set the generator time this shows you are producing salt
Jun 14, 2010 | Intex Automatic Salt Water System for ...
I set my hours and it is working but i thought intex salt water
it can take up to 10 minutes for that second light to come on.Until then you are probably not producing chlorine
Jun 07, 2010 | Intex Automatic Salt Water System for ...
Intex chlorine generator no working
check sensor if ok cell or check voltage to cell
Jun 14, 2017 | Intex Automatic Salt Water System for ...
No green light....no chlorine generation
make sure you have at least 3000ppm of salt content'
set your timer for generation - the green chlorine light will not come on for at least 5 minutes sometimes up to ten
make sure you run the generator for at least 4-6 hours the first time
Jul 18, 2009 | Intex Automatic Salt Water System for ...
Intex system not giving chlorine, no errors but no green light
I found I had the same problem. I would set the hours, it would count them down but the green light would NOT come on indicating it was producing chlorine, yet the sleep light would light up after the count down so I knew the light was working. I checked my salt, made adjustments, had to do shock treatments to keep it clean. Today I  found out that the manual is incorrect in how it says to set it. After you set the hours, instead of pushing both the arrows at the same time until it beeps, push the down button until it beeps, and then the up button until it beeps. For 2 months I have fussed with this system, and finally the green light came on and my test strips indicate it is producing chlorine. Yeah! To bad intex does not seem to mention this on their web site.
Good Luck
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
514 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
