Question about Whirlpool Washing Machines
What do the F11 and F02 mean?\
Our washer stops after 2 minutes and drains itself and then shows either F11 or F02 warnings.
what do the F11 and F02 mean?
what are the problems and how can they be fixed?
    Sniper:
  • 71 Answers
Hiyas here is the meaning for the codes
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
F11 Means
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
Replace failed component.
I would suggest that you possibly call out an engineer
Posted on Jul 20, 2009
Front load washer, F02 error is flashing on board. What does error code mean?
F02 error means if the drain time has exceeded more than 8 minutes. After four minutes suds will be displayed on the screen and again after 4 minutes the F02 error code appears.
Check the drain line for any clogs or blocks which hinder the draining procedure..Use of more detergent can even cause this condition..Be sure you are using only 2 tablespoons of HE soap and not more than that.
Check your drain filter also and replace them if needed. Remove the 3 Torx head screws (located left, center, and right) from the front bottom kick panel of the washer. The drain/filter/pump is right in front.
Mar 11, 2011 | Kenmore Washing Machines
Display flashes F 2 at the 1:00 minute to finish time and stops and beeps.
Feb 03, 2011 | Kenmore HE2 Plus Front Load Washer
At the end of the normal wash cycle my washer begins to beep repetitively and shows an error code of F 02?. It will not spin and drain. We've began to switch it to Drain/Spin cycle and this works about...
Hi
Error F02 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Jan 30, 2011 | Washing Machines
Keeps showing code f 02 and wont completely empty water it never finishes spin cycle?
Be sure you are using only 2 tablespoons of HE soap and not more than that. Check your drain filter also and replace them if needed.
Jan 18, 2011 | Kenmore Elite 45986 Front Load Washer
During the Normal washing cycle. 02 F appears. and cycle stops. Cycle hasn't finished rinse or spin.
Hi
Daniel
Jan 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F02 error and not draining correctly (pool of water left at the bottom of the washer after cycle has completed). This is on a whirlpool duet front loading washer.
Hi
• Check the drain hose and make sure it is not plugged or kinked.
• Check the drain pump filter for foreign objects.
• If the above does not correct the problem, replace the pump.
Daniel
Jan 01, 2011 | Whirlpool Washing Machines
F 02 is being displayed on washer. Can the washer be fixed from the front of machine.
Hi
Daniel
Jan 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When my washer gets done with the rinse cycle, it stops and reads F 02. Then shuts off. What do I do?
Hi
Daniel
Jan 01, 2011 | Kenmore Elite 45986 Front Load Washer
What does it mean during the wash cycle when it stops during the cycle and says F 02? Thanks!
Dec 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
296 people viewed this question
Dan Webster
Dan Webster
Sal De
