Question about Panasonic TC-P50S60 50" Plasma HDTV
Tc-p50s60 Panasonic plasma tv has no video or audio. Solid standby light, no blinking. Think it might be the power supply card?
SOURCE:
  • 8457 Answers
SOURCE: plasma 50 inches dont turn on
The power supply board is dead.Tries the websites like Shopjimmy.com,Ebay.com to buy the refurbish power supply board for the replacement.
Posted on Jun 22, 2010
  • 8457 Answers
SOURCE: I turned on power and red light is blinking but tv
Tries unplug,replug the tv back like an hour later.The tv now,should resetting itself back to the factory setting.The tv should work now.Not,than the tv power supply board have problems,not giving the tv it wright voltages anymore.The tv power supply board that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Nov 06, 2010
walesarumi
  • 6993 Answers
SOURCE: My Panasonic TH-50PZ800U plasma TV
This is not video board problem. It is actually a power supply problem.
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Feb 02, 2011
SOURCE: i have a panasonic 50 inch tc-50px24 plasma tv. i
blinkin de red led tv panasonic plasma
Posted on Feb 13, 2011
sodeep
  • 3267 Answers
SOURCE: I have a Panasonic Model TC-P50S1 plasma TV and
Panasonic utilizes the blinking light as a form of self-diagnostics, similar to the "check engine" light in your car. If you've ever experienced that, you know that a check engine light could indicate anything from a loose gas cap to a major failure.
Panasonic uses the number of times the light blinks, to aid the technician in trouble-shooting the problem. The blinking light indicates an area of concern and helps the technician to isolate the problem and order the correct parts. This in turn speeds up the repair process, keeps parts cost down, and helps both you and the servicer by allowing the technician to complete a repair in one trip in most cases.
So contact an authorized service center.
Posted on May 28, 2011
Panasonic plasma TC-P65VT50-2 wont turn on. Stuck in standby mode with red light on. Clicks ever few minutes but no picture.
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Feb 07, 2017 | Panasonic Televison & Video
My panasonic TC-P50S60 power led is blinking 3 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 07, 2016 | Panasonic TC-P50S60 50" Plasma HDTV
Panasonic Plasma TV TC-P50S2 10 blinks
Sounds like main digital board fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Sep 11, 2016 | Panasonic Viera TC-P50S2 50" Plasma TV
I need help trouble shooting what's wrong with my TV. Panasonic plasma TC-P50S60
Jun 20, 2016 | Panasonic TC-P50S60 50" Plasma HDTV
Panasonic tc-p50 two clicks but no no power
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 23, 2015 | Panasonic TC-P50S60 50" Plasma HDTV
I purchased a Panasonic TC-P50s30 50" Plasma TV
You did a good thing; really!! Keep that TV aside you always.
Jul 11, 2017 | Panasonic 50 in. Plasma TV
Panasonic TC-P50S60 50" Plasma HDTV Logo
69 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
