Question about Canon XH A1 Mini DV Digital Camcorder
Cannot digitize to Final Cut Pro from Canon XH-A1
When I try to digitize HDV footage at 1080i60 from my Canon XH-A1 I get the box saying: "Unable to Initialize Capture Device. Device is not
connected or the capture preset is not setup correctly. You may still log offline clips. This might also happen if you play DV footage in an HDV device."
I've tried all the AV settings in FCP for HDV...HDV firewire basic, etc. and I've used 2 different firewire cables which I know both work. I have FCP 6.0.1 on my G5. I've checked forums on-line, taken all the recommended steps such as opening FCP after the firewire is connected to the Mac and xh-a1. Whatever anyone has suggested, I've tried. Does anyone have a solution?
SOURCE: Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Posted on Dec 04, 2007
vac8
  • 15 Answers
SOURCE: when I capture HDV footage
Make sure the properties for the project you start after the ingest match the frame rate you used to record. Reads like 29.97 speed setting looking at images recorded at 24f.
Posted on Jan 14, 2009
  • 22 Answers
SOURCE: Please help me...When I connect
Try playing the tape before connecting up to the mac with the firewire and before loading FCP up. Usually fixes it for me when using either iMovie to import or FCP
Posted on Jan 21, 2010
  • 22 Answers
SOURCE: MacBook Pro/FCE does not capture video from XH A1
Play the tape on the camera before connecting it to the mac and loading up the software. You could always see if iMovie is giving the same error message too... This usually fixes the problem for me and usually arises when switching between SD and HD on the camera.
Rick Riggins
  • 1812 Answers
SOURCE: Why won't my Canon XH A1 power up
The most likely cause is a component failure in the power circuit. This can be repaired fairly inexpensively. However, it's not really a user serviceable problem and should be looked at by a qualified technician. Here is a link to a repair shop that should be able to help you.
www.discountcamerarepair.com
Posted on Nov 17, 2011
Canon Xh a1 won't turn on, HDV and Power are blinking
It could be the blown fuse that located on the main circuit board.
Dec 18, 2014 | Canon XH A1 Mini DV Digital Camcorder
XH A1
Drivers link
user manual link
After reading you manual you will notice on page 11 it states, that you need to use a P.C.it is not Mac compatable!!!!!
This touch screen will not work with Apple Mac
Dec 03, 2007 | 3M MicroTouch M170 17 in. Flat Panel LCD...
MacBook Pro/FCE does not capture video from XH A1 any more. Message: Cannot initialize HDV deck-please connect camera.
Dec 22, 2009 | Canon XH A1 Mini DV Digital Camcorder
Please help me...When I connect my canon xh a1 to FCP 6.0 it says Unable to Initialize Capture Device Device is not connected or the capture preset is not setup correctly. You may still log offline...
Jul 16, 2009 | Canon XH A1 Mini DV Digital Camcorder
Getting poor quality uploads to my pc from my Canon XH-A1
You need to upgrade you ingest system. Windows Media Player(and your system card) probably can't handle the load. Try "Scenalyzer" it's economical, versatile and stable( http://scenalyzer.com/).
Jan 14, 2009 | Canon XH A1 Mini DV Digital Camcorder
When I capture HDV footage from my XH A1 to Final Cut Pro 5, the footage is out of sync. The video is playing like in 110%, or something like that. The original footage is in 24f mode. It doesnt happen in...
Jan 01, 2009 | Canon XH A1 Mini DV Digital Camcorder
Unable to
HHHhhhmmmm. I'd suggest the DV mode and if you camera has the option to output DV as letter box select this, as it is a faster version to edit with (due to compression of HDV). I don't know the camera but VTR is just the playing mode, so play the file you want while trying to connect. Is the signal coming from tape? If it is catured to the harddrive of the camera you will need to import not capture.
USB does not support video, USB2 maybe.
I
Jan 11, 2008 | JVC Everio GZ-HD7 Camcorder
Canon
You don't actaully need the camera. If the DVD is not copyrighted simply put the DVD disc into your mac and copy the biggrest file (usually marked video.ts) You can then drag and drop this onto your Final Cut timeline.
Dec 24, 2007 | Canon XH A1 Mini DV Digital Camcorder
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Canon XH A1 Mini DV Digital Camcorder Logo
404 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
