Question about KitchenAid K45SS Classic Stand Mixer
My Kitchen Aid Artisan Stand Mixer only runs on high speed.
It used to run great, until today that is. Now it doesn't matter what speed I turn it to, there are only two speeds - off and bat-outta-hell. The outlet it's plugged into works fine for every other appliance I try. It hasn't been dropped, as a matter of fact it's been in the same spot on my kitchen counter for over a year.
I will try calling the number on the side tomorrow, just wanted to know if there's a trick.
Thanks in advance! :)
  • 398 Answers
You can try to use some oil free contac cleaner on the speed switch. if that don't fix it put a new speed control switch in it.
Posted on Jul 20, 2009
I have a kitchen aid stand mixer. model #rkt2651x. it goes very fast when turned on then shuts off. it will go again but turns right off again. age?
That is indicative of worn motors brushes or a speed regulation circuit board problem. It is worth getting it fixed.
I just checked and my diagnosis is sound :>)
I have a kitchen aid stand mixer. model #rkt2651x. it goes - Fixya
www.fixya.com/support/t26909658-kitchen_aid_stand_mixer_model
52 mins ago - i have a kitchen aid stand mixer. model #rkt2651x. it goes very fast when turned on then shuts off. it will go - Food Mixers question. SOLVED: Mixer goes really fast then stops
29 Dec 2007
Questions, Troubleshooting Help & Support Page 3
28 Jul 2006
More results from www.fixya.com
KitchenAid Classic Mixer K45SSWH Troubleshooting - iFixit
https://www.ifixit.com/Wiki/KitchenAid_Classic_Mixer_K45SSWH_Troubleshooting Make sure the KitchenAid Mixer is firmly plugged into a working outlet and the cord is not twisted or split. ... If your mixer still will not turn on, it might be a problem with the motor brushes. If the brushes are worn down ... The most common sign of a failing hall sensor is if your mixer increases to top speed and then shuts down. Missing: rkt2651x
Stand Mixer Shuts Off During Use - KitchenAid Product Help
producthelp.kitchenaid.com > ... > Stand Mixer Assembly and Operation Jul 12, 2017 - Once the steam has dissipated, the unit should turn on again (about 3 minutes). Resolution: If the mixer could have overheated during use let the mixer cool for at least 30 minutes and try to re-start. If you were making mashed potatoes when the mixer shut off it's possible that with excessive steam the unit ... Missing: rkt2651x
images for kitchen aid rkt2651x stand mixer goes very ...
More images for kitchen aid rkt2651x stand mixer goes very fast when turned on then shuts offReport images
FAQs - KitchenAid
https://kitchenaid.com.au/faqs Explore our range of frequently asked questions to get the very most out of your KitchenAid product. Missing: rkt2651x
[PDF]Classic Stand Mixer Speed Control - KitchenAid
https://kitchenaid.com.au/sites/.../stand_mixer_service_manual_speed_control_6-12.p... KitchenAid®. Classic Stand Mixer. Speed Control. Theory of Operation. And. Troubleshooting Guide. (revision date 6/19/2012). D. Pahl ... Mixer Does Not Shut Off page 6. Mixer Does Not Turn On page 7 ... the motor is not running (OFF) the governor ball plate is at its farthest forward position and when the motor is running at ... Missing: rkt2651x
How to Replace the Speed Sensor and Control Board on a KitchenAid ...
? 6:28
https://www.youtube.com/watch?v=41qTqTWQkMI Jan 15, 2013 - Uploaded by eReplacementParts.com
This video tutorial will show you how to replace the speed sensor and control board on a KitchenAid Pro 6 ...Missing: rkt2651x ‎turned kitchenaid rkt2651x stand mixer goes very fast when turned on then shuts...
Mar 10, 2018 | Food Mixers
I have kitchen aid stand mixer and i can't get the beater to attach because the button is stuck??
The button doesn't move. You must push the beater up beyond th notch and turn it while pushing up.
Jan 14, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
My Kitchen Aid ksm150ps stand mixer mixes only at high speed even on the first setting. What could be the problem?
sounds like the set screw in the back unit is too tight. Take off the back cover with the single screw up top. On the switch assembly that is now revealed, run the switch back and forth to see how it is interacting. The small set screw at the bottom probably needs loosened or tightened to give you the other speeds.
Oct 31, 2011 | KitchenAid KSM150PS Artisan Series Stand...
My wife's Kitchen Aid Artisan 325W mixer has no high end speed. I tried a new set of brushes with no change. Then starting on speed 1 to 2 and from 2 to 4 you get a nice speed increase the speed the...
You need to adjust the mixer speeds. Obtain a copy of the KSM150 Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 02, 2011 | KitchenAid Classic Stand Mixer
Kitchenaid Heavy Duty 325 stand mixer. Making cookies and now the motor runs but it doesn't turn to mix. PLease help/.
kITCHEN AID ARTISAN 325 WATTS TILTING HEAD PIN CAME OF WHILE MIXING DOUGH. HOW IS THE EASIEST WAY TO INERT PIN BACK OR LINE UP THE HOLES TO INSERT PIN?.
FRANKAMOR
Feb 06, 2010 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Mechanical burning smell on kitchen aid stand mixer
i think its time to retire it its has had a good run time to put it to rest and buy a new on it don't sound safe to use anymore
Sep 21, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen aid stand mixer bought in US, moving to Europe, 220v 50hz
I can not respond to the warranty issues. My kitchen aid mixer is past warranty as well. I live in a country that uses 220V and my kitchen aid mixer is 110V. I have been using my kitchen aid mixer for almost 4 years with no problems at all.
The converter boxes are supposed to blow the fuse on the converter before it reaches your appliance and cause any problems.
If you purchase a 220V kitchen aid (although it would cost more money) it would probably have more power because of the higher voltage.
Hope this helps!
Jul 29, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kitchen Aid 10 speed 325watts
Some of the gears may have broken or slipped off. You'll need t open it up to see why the shaft from the motor will not spin or you will burn out the motor with the power on trying to make it go. It might be a DIY job if you can see an obvious problem like a slipped gear, otherwise take it to a repair specialist.
Apr 30, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid K45SS Classic Stand Mixer Logo
710 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
