Change Drum Soon." We have switched the drum with new drum, and it still is giving us the same message!The drum life indicates 0%. Do I need to reset something in order for it to work properly?
This message would continue to appear if the
drum counter was not reset when you replaced the drum. To reset the
drum counter, follow the instructions listed below.
Open the front cover.
Press the Options key on the control panel. The display will show "REPLACE DRUM - 1.YES 2.NO".
Are you sure of the error message? The Brother printers that I have used have Drum Ends Soon and Change Belt messages.
The Brother MFC-9440CN has a belt that can be replaced. The Belt unit has an life expectancy of ~50000 pages. The belt unit is part BU100CL and costs a bit over $150 at office supply stores. Amazon.com and some other stores have the unit for under $100. http://www.amazon.com/Brother-BU-100CL-HL-4040CN-HL-4070CDW-Series/dp/B000SC245E is one source.
When the unit says Change Belt Unit, follow the directions from the manual's maintenance section to replace the belt unit. See page 178 (page 189 of the PDF) http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002252/mfc9440_usa_usr_b.pdf . You have to remove the Drum and then the Belt Unit. Then slide in the new Belt Unit and replace the Drum unit. Then close the printer and turn it on. Finally reset the counter from the Machine Info sub menu (press Menu 8 4 and select the Belt Unit and press OK. Then press 1 followed by Stop/Exit).
If you mean the Drum Unit, that is part DR-110CL and costs over $175 at the office supply stores. Order this part when the Drum End Soon message appears and replace it if the print quality deteriorates (or when you have the new drum). The Drum Life is ~17000 pages. The steps start on page 166 (182 of the PDF). You need to remove the old Drum unit. Then remove the toner cartridges from the drum. Prepare the new Drum Unit, including putting the cartridges in the new Drum. Then replace the Drum unit and reset the counter.
The "replace drum soon" indicater is a warning for you to have a new replacement drum "on-hand". Soon the display will change to "REPLACE DRUM" AT WHICH TIME THE UNIT WILL STOP PRINTING.
When the new drum cartridge is then installed...the REPLACE DRUM indicator will be reset. DO NOT replace the drum before the machine says to.
Open the front panel.Press and hold the clear button.When "Drum replaced"shows on the lcd panel select yes.The message will be reset.If you experiece any lines in the future you will have to replace the drum catridge.
Open the front door and press the options ar menu key, if it doesn't ask you if it's a new drum, then press 3 and 9 together and scroll thru the items to reset and reset the drum.
All you need to do is open the front door and press either the options button or menu button, whichever you have, it will ask you if you changed drum, just answer yes, and you're good to go...
Description: This message would continue to appear if the drum
counter was not reset when you replaced the drum. To reset the drum
Open the front cover. Press the Options key on the control panel. The display will show "REPLACE DRUM - 1.YES 2.NO". Press 1 to reset the drum count. Close the front cover.
I fixed the problem (following the user's guide). 1. After reinstalling the new drum unit into the printer, keep the front cover open. 2. Press "Clear/Back" on the machine 3. Press "1" and when the LCD shows "Accepted", close the front cover.
