Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Error 52 brother mfc 240c
Error 52
  • 20 Answers
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
CF
Posted on Jul 20, 2009
Mix-it-up
  • 832 Answers
SOURCE: Brother MFC 240c
Best generic ink(in carts) comes from skyhorse:
http://www.inkhouse.cn/en/
Its better than the original ink!!!!
Search your country for resellers by help of google or ebay.
Posted on Jun 15, 2008
crayzeetrayn
  • 837 Answers
SOURCE: To find user's guide for a Brothers MFC 240C
Here is the link
Give me a FIXYA please .. thanks
Posted on Dec 07, 2008
  • 414 Answers
SOURCE: need a support or operational manual for a Brother's MFC-240C
Follow the kibk for the users guide.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_240C_EN_249.PDF
Thanks for the rating,
Mark
Posted on Mar 25, 2009
pineworks
  • 4041 Answers
SOURCE: Brother MFC 240c error 30 after printer jam.
Several conditions may cause the error message Machine Error 30, 33, 34 or 35 to be displayed on the LCD. This error may be the result of one of the following:
  • The print head carriage is failing to return to its home position to the far right of the unit.
  • Both of the springs located on each side of the carriage is out of place.
  • The cartridge covers may not be locked securely in place.
Please follow the instructions listed below to correct this problem:
  1. Press the INK button on the Control Panel.
  2. Using the dial pad, press 2 (Replace Ink). The display will prompt you PLS OPEN COVER.
  3. Pull the Scanner Cover release lever located under the Control Panel and lift the Scanner cover. The carriage should move to the left in order to replace the ink. If the carriage does not move to the left, your machine will require service.
    If your machine is still within warranty, click here to locate a Brother Authorized Service Center in your area or click here to obtain contact information for the appropriate Brother Customer Service Center. If you are out of warranty, use the link to locate a Brother Authorized Service Center in your area.
  4. After the carriage moves to the left, press down each cartridge cover and remove all ink cartridges from the machine. There are 2 springs located on each side of the carriage that hold the print head against the carriage assembly. They are thin silver springs approximately 2 1/2 inches, set at an angle.
  5. If the spring is out of place, press the spring back into place. You can use the spring on the opposite side of the carriage as a guide as to the correct position.
  6. If the spring is not out of place, reinstall each ink cartridge.
  7. After installing the ink cartridges, close the covers and verify they are securely locked into place. Your machine then prepares for a head cleaning and goes online. The LCD screen prompts you to verify if a new ink cartridge was inserted for each color you removed. For example, DID YOU CHANGE BLCK 1. YES 2. NO.
  8. Press 2 (No).
Note If you decided to place a new ink cartridge in for any of the colors when uninstalling and reinstalling the cartridges in the above process, press 1 (Yes). The machine will automatically go through a cleaning cycle.
Also this might be handy for you. To reset purge counter
1) Enter machine maintenance mode (on MFC240C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine’s log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Please call back and gave us a vote. All The Best: Pineworks
Posted on Mar 02, 2010
  • 48 Answers
SOURCE: Need a free download for brother MFC 240c. I seem
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc420cn_us
Follow instructions and this should help you.
Good Luck...........Leadfoot44
Posted on Apr 15, 2010
Brother mfc 240c machine error 40
Unplug the machine from the AC outlet and if possible cool the room where the machine is located.Still having Problem Then follow Us For Brother Printer Support
Mar 22, 2014 | Brother Multi-Function Center MFC-240C...
Print unable error 52
better enable printer option in your pc or change the printer cable
Aug 01, 2012 | Brother Multi-Function Center MFC-240C...
Troubleshot 46 on mfc-240c
Error code 46 means that your ink absorber pad needs to be replaced. According to Brother, only an engineer can do that, but you can get more information from them by contacting Brother support:
http://www.brother-usa.com/Support/
Click on "Send us an Email" and tell them your printer's model number, the error code, and whether or not your machine is covered by a warranty.
Jun 09, 2010 | Brother MFC 240C All-In-One InkJet Printer
How do i reset a brother mfc 240c
To reset the MFC-240C, hold down the power button for 3 or 4 seconds. The lights on the display should go out and the printer should slowly turn itself off. Once it is off, hit the power button again to restart it.
If the power button does not work (as sometimes happens with paper jams or other error conditions) you can unplug the machine's power cord in order to reset it.
Oct 12, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother mfc-240c and windows vista
Yes you can. Download the drivers from the brother website. brother.co.uk
Aug 21, 2009 | Brother Multi-Function Center MFC-240C...
Brother mfc-240c printer error message unit unable 43
http://support.brother.com/g/b/faqend.aspx?c=gb&lang=en&prod=fax2440c_us_eu&faqid=faq00000168_003
Jan 06, 2009 | Brother Multi-Function Center MFC-240C...
Error code cc3-205-03031f02 will not scan
What model do you run? Is it a brother mfc 240c or something diffrent?!!
I ve never seen such an error code for brother mfc 240c printers!
Dec 27, 2007 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C yellow
Common error of brother mfc/dcp printers.
Unfurtunately there is nothing what you can do.
Call brother hotline ask for service/guarantee repair.
Dec 06, 2007 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
402 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
