Question about Sony VAIO VGN-N220E/W Notebook
Wifi dropping out constantly
The wifi connection connection on my Vaio constantly drops out. This happens every 10-45min and immediately comes back online about 30 seconds later. I have used it with multiple access points with varying degrees of signal strength and have had the same problems. I have Vista factory installed on my computer and have had this problem since day one. One of my co-workers got the same computer at the same time as mine and his has the same problem. When I connect the computer to a wired network I don't have the problem.
  • Dail Apr 03, 2008
    I have a similar problem. I do get dropped at times and have to restart it to get back on line. Another problem is the signal is not constant. I get five green bars easily but then it drops back to one or two green bars. Moving close to the router has no affect on the improvement of the signal
The problem appears to be a faulty/cheap ON/OFF micro switch (on right side of laptop). I solved my problem by setting switch not all the way to ON position and it stays ON unless I "bump" or touch the switch (usually by mistake).
Posted on Dec 05, 2008
  • 84 Answers
Make sure that the firmware of your router is up to date. and always check your computer updates.
Posted on Feb 09, 2008
Keeps dropping WiFi signal!!!!! How can i prevent this from happening?????
Move to a place where the signal is better. WiFi only drops out when the signal becomes too weak.
The other possibility is a break in service from your wifi provider. When the wifi drops, quickly look at the wifi signals available, and if your is not there, take a quick screenshot. When you have 6 of them, contact your provider and complain.*&spf=191
Mar 17, 2017 | Computers & Internet
I already asked the question and then had to get off the computer. The question was how do I stay on the WiFi internet through netgear router. When the WiFi symbol shows I am conneted if I go too Chro
Need to know your signal strength and if you're connected with proper credentials. If the wifi signal is weak, the computer may disconnect to look for a stronger signal. Sometimes ipv6 is the culprit on older computers too. Disable that and use ipv4 only. There are multiple reasons for dropped internet so the more info about your system and the conditions under which the internet is dropped will help in diagnosing the problem without sending you on a wild goose chase.
Dec 15, 2014 | Samsung Galaxy Tab 3 7-inch, white
Nexus 5 drops motorola surfboard wifi with a minute. Nexus works with other wifis
You can check with Arris ( ARRIS for Consumers ) or contact the manufacturer of your Nexus 5 for troubleshooting.
Motorola Mobility Support
Nov 29, 2014 | Arris Computers & Internet
Wifi Keeps Dropping
Dropouts are usually caused by the modem itself and not so much the wifi unit in the laptop. Next time it drops out, try resetting the modem router first. If this fixes it immediately the problem lies there. Next is to identify what wifi card you have in your system. You can find this in Device Manager. Then go to the original manufacturers website and see if there is a later driver for your card. If so, download and install it from there and not the Asus site. Sometimes the laptop manufacturers are a bit slow in keeping individual 3rd party drivers up to date.
Sep 24, 2014 | ASUS Computers & Internet
I own a new Samsung Ultrabook laptop. It constantly drops the wifi connection or takes it back to LIMITED. I know its not my Wifi because other devices don't drop off.
well it depends on range, and near by electrical noise.
are you at home or at startbucks? just a clue?
get a wifi meter, install it to the book.
then see just how good you think wifi , really is.
i use. APP
it's like wifi radar. shows you the signal strength
the neighbors interference.
are you using the same channels as the neighbors.?
yes, well get off that channel and use another.
are you using G/N wifi ? if not why not.
my neighbors all use defaults, so they are on the low channels
im on the upper.
and i have 2 WIFI smart routers, to make all TV and all wifi work
in home, is home large?
i run a Dlink Dap1525 , it sees your moving about and directs the signal so you. true magic here. Love mine.
Wifi is weak, and has very limited range. unless you plan out the system.
Sep 29, 2013 | Samsung Silver 13.3" Ultrabook...
Have Vextra 39280 900Mhz cordless phone, this interupt 2.4Ghz Wi-Fi connection,,, It should not be compatible each other, but when Vextra Phone in use, Wi-Fi connection drops, after hang off phone Wi-Fi...
I have the same exact phone near my WiFi router and it has not dropped my connection. Could there be some other thing that could be the cause of it? Make sure that your WiFi is not dying on you. Check both phone and WiFi by keeping the two far away from each other.
Jul 26, 2010 | Lands Phones
Wifi connection drops after it connects to the wifi
you can make sure your new laptop is on only the g band that should help, cos its trying to go on the n band which is causing it to drop.
Oct 10, 2009 | Linksys Wireless-G Broadband Router
N1 Drops when Mac log onto network
OMG I have the exact same problem. I'll be using the router for a week on wifi just fine, then one time when my mac laptop comes out of sleep and tries to connect, the router drops its Wifi network (making it unjoinable for any device, not just my laptop) and I ultimately have to hard-restart it. SO frustrating, this is on v1 btw.
Feb 20, 2008 | Belkin (F5D8231-4) Wireless Router...
Dropping Connection
This link indicates there may be an issue with hiding the SSID in the wireless router. A security item employed by some users. IF this is the case consider broadcasting the SSID and employing WEP or WPA encryption in the wireless configuration for both the router and the adapter cards to secure the wireless connections..
Dec 11, 2007 | Linksys Wireless-G WRT54GS Router...
Sony VAIO VGN-N220E/W Notebook Logo
183 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
