Question about Zenith A27A23W 27" TV
Hooked to cable...says no channel found
Hooked to cable..says no channels there a place on the menu where one can auto set the channels or could it be the cable tv not working?
  • 50 Answers
How old is this set? there were some certain years the auto matic scan didn't work, you must enter them under the manual way.
Posted on Nov 20, 2007
I have lost the manual how do i tune it in
On the remote, there will be a menu button. Make sure that the antenna or cable is hooked up to the connector in back which will be a metal circle sticking out the back. When you have your menu options, go to the settings or options and select the Auto-Channel or Auto-Tune function which will automaticaly pick up and save found channels.
Mar 18, 2011 | Televison & Video
Olevia 232 s12 Accidentally hit factory reset. now no channels in list. how do I get my channels back?
You'll need to reprogram the channels.
Typically this is found under the settings in some sort of auto program section of the menu.
On most newer televisions, the setting is found under a 'Channel' section.
Just select auto program and your source, whether it be an antenna or a cable source.
When the auto program is completed, you'll have your channels back.
Mar 05, 2011 | Olevia Televison & Video
There is no local channel,cable only international..i lost my manual,
Here is the procedure for auto tuning. Pleas go through it. Connect the antenna to the rear antena socket marked as &% ohms antena and continue.
If you have already run the Auto Tuner as part of the quick setup earlier in this guide, please
skip ahead to "Channel Summary" to continue setting up your television. In Auto Tuner Setup,
the TV automatically scans through all available channels, memorizing the active ones and
skipping over blank ones or channels with weak signals. This means you scan using the
CHANNEL +/- buttons), you will receive only clear active channels.
Press the MENU button
?® To operate
?® To choose CABLE or AIR
Press the OK button to start
Initial Setup
Auto Tuner Setup
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen.
Channel Summary
Channel summary allows you to customize the line-up of channels received by your TV. You
can add or delete channels from the line-up or prevent any unauthorized viewers from watching
any or all 181 channels.
?® To operate
The Channel summary screen will now be displayed with
the channels set to scan marked with an "?". You can delete
channels from the scan by removing the "?". If any channels
were missed during auto tuner setup and you wish to add
them, you may by placing an "?" next to the channel number.
?† ?® To the SCAN column
Press the OK button to include or delete from scan
Press the MENU button when finished
You can block access to a channel by activating the channel lock.
?® To operate
?† ?® To the Lock Column ( )
Press the ZERO button to lock or unlock that channel
If you wants any codes, contact me through Fixya. Ok
I'm quating these procedure from the manual I've with me, and it is for JVC AV32S565.
Nov 08, 2010 | JVC AV-32S575 32" TV
I don't know how to set the tv to receive all of the channels
Enter the "menu" and select auto program. This will allow the set to search for all available channels. There is also a possibility that when you hooked it up the little wire center conductor in the cable might have been bent over when you hooked it up. Check that first.
Apr 16, 2010 | Sharp 19R-M100 19" TV
Auto search through
Tested and verified solution:
  1. Set Tuner Mode to "antenna".
  2. Run a channel scan. Should get zero channels found.
  3. Set Tuner Mode to "cable".
  4. Run another channel scan.
  5. Celebrate!
Aug 16, 2009 | Vizio VX37L Television
Hook a VCR to it with a tape playing and make sure the VCR RF switch is set to channel 3. Then do the auto search. If it still does not find channel 3, then your TV has a bad tuning circuit.
Aug 08, 2009 | Zenith C27A24T 27" TV
I just got cable and I cant get the channels to come in as cable channels. I lost my manual and have a universal remote?
Hi gail dahl,
I am happy to help.
From the Video Menu the Tuning Band must be set to Cable and not to AIR or Antenna. You will nee to run Auto Scan for channels from the Menu also.
I have provided a link to download the manual.
Let me know if you need further assistance and please rate this solution. FixYa.
Jan 31, 2009 | Sony BRAVIA KDL-40XBR2 40 in. LCD HDTV
Orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
i have the same model, so try going to menu and doing the add/delete channel thing....also i found that i only get all my channels if the tv is set to catv instead of tv
Feb 22, 2008 | Televison & Video
Black borders
Check the resolution settings on your cable box, you may have to call your cable provider to find out how to get into the settings menu, there is a stretch function in the settings that should make all the lower channels auto fit your screen, also see if there's a p=size button on your remote control, try pushing that when on the channels that have sidebars.
Oct 26, 2006 | Samsung SP-S4243 Television
Televison & Video Logo
188 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
