Need to set up wireless for toshiba A105-S-4034
If you have installed the AT&T software, you should be able to use that application to connect to the Internet. Are you using a USB gateway or do you have a stand-alone gateway?
If you have the USB type, install the software first and then connect the USB gateway, Click on the software app to start the Internet connection. AT&T info will show a tab for GSx and one for Wireless. As long as you have a subscription, I would use the GSx tab, otherwise, select the wireless tab and connect to your gateway or any other wireless router that you have access to. Good Luck.
i have the same problem. my sister has the same notebook as i, and has no problems.
