Question about Mitsubishi VS-60803 60" Rear Projection Television
Our picture shows double. The repair man came out
Our picture shows double. The repair man came out and said we need to replace the IC's and wanted $500 just to start...??? Can we replace the IC's ourselves?
    President:
  • Mitsubishi Master
  • 1,779 Answers
Not advisable. $500.00 is way over board what we charge for that repair. 250-300 max. I don't know of any shop or with our tech web site that charges that kind of money. I would still shop around.
Posted on Jul 20, 2009
The top 2 inches of my screen appear to be folded behind or in front of the rest of the picture. This randomly happened one day and I am curious if it is an easy fix or if my T.V. is done for. It was...
You have a bad capacitor in the vertical deflection. I have not repaired this particular model. I'm aware of this happening in many of the Magnavox brand. You will have to locate the vertical IC. It may have seven or nine pins (remember, I have not repaired this particular TV) and is mounted on an heat sink. You will have to inspect this IC and resolder the pins. Do not use excess solder, you do not want to short the pins together. Next you will need to replace the capacitors that are near and next to the vertical IC. We are looking at about 4 capacitors, two will need replaced. You may replace the other two if feel you need to, or do not have a capacitor checker. Be sure you solder in the correct values and polarity of the caps as you replace these. You may, also look for a bad capacitor near the flyback transformer. It may be a 100 volt 10 Mf capacitor here, that is also bad.For the TV man this is a simple fix. For the average guy, it may be some effort to fix. Thanks for asking and show all hands of support.
Sep 06, 2011 | Philips Magnavox 20MT4405 20" TV
I have an rca 60 inch big screen..it just happen to show double vision looks 3d with out the glasses..lol ....sound is all good just the picture..model number..mm61110 chassis number..mmc102g..i love...
Yes it can be fix, first try to adjust the convergence setting in the setting menu then go to convergence section, adjust the red and blue convergence. You should be able to move the red and the blue convergence up, down and left, right but if you cannot move this far enough the convergence IC is defective and should be replaced. This convergence IC is attached to a large aluminum plate, this is the heat sink and the convergence IC has a marking of STK-#### followed by a number, in order to replace this IC you should have a soldering iron, desoldering pump, soldering lead be careful when pulling out the IC you may accidentally tampered or damage the PCB and caused much damage to the unit. Note before opening the back cover of your tv be sure to unplug it first. But if you are not familiar with electronic parts you can contact a service technician to do it for you and save you from stress good day and best regards.
Aug 30, 2011 | RCA D52W23 52" HDTV CRT TV
The picture is showing a double image and is distored.
The problem you are refering to is more than likely a convergence problem. The convergence circuit in your tv is controlled by an IC (integrated circuit) stk392-110 and it makes the 3 colors (red, blue, green) line up/converge together to create a clear picture. You'll know when this part needs to be replaced because the picture you see is 3d looking and possibly bowed on the top or bottom or on the sides in any or all 3 colors.
Jan 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
DOUBLE IMAGE ON SCREEN. tOP OF PICTURE LOOK LIKE A
That symptoms are due to failure of convergence out ICs in your TV that will be replaced to get correct converge picture on front screen.
There are 2 big black IC mounted on big aluminum heat sink and number would be written on as STKxxx, these 2 ICs will be replaced.
If you want to repair TV by yourself then confirm model number of TV to provide you more info or call local tech to replace said ICs.
Thanks.
Dec 21, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Double Blue Halo Effect and Blurry Blue Picture
thats a problem with the Blue CRTs coolant needing replacement. If you look directly into the blue and green CRTs while its playing you should notice a bunch of crud inside the lens indicating that the coolant needs replacement. You can get the coolant replacement kit for a phillips at the following link which includes the coolant and instructions
http://servicemanuals.vstore.ca/
Aug 05, 2009 | Philips 60P8341 60" Rear Projection...
Toshiba 60HX70 distorted picture, blinking red light
You could have a Power Supply Regulator Problem. Many times these sets will not hold Horizontal sync when there is excessive High Voltage or a problem with the High Voltage Regulation. This is not a problem you want to deal with yourself. I would recommend a Toshiba Repair Facility to come out and diagnose it.
Hope this helps,
Skyassoc
Jul 22, 2009 | Toshiba 61HX70 61" Rear Projection...
My tv is showing a double picture in red
You have convergence problem in your tv . You need to replace convergence IC . YOu can get from the link below .
Convergence ICs
You need to replace both convergence ICs .It will cost you around $30 .
The IC number is STK392-110 .
Hope this helps .
Mar 03, 2009 | Apex Digital GB4308 43" Rear Projection...
Red is out of convergence
I would stay away from that repair man. That model has just one Convergence IC number STK393-110 and it takes about 45 minutes from start to finish to remove the old IC and install the new one. You can get the replacement IC at the following link and they provide free instalation instructions with pictures so you can do the repair yourself for less than 30.00. Heres the link. You need just 1 STK393-110 Convergence IC they have free shipping as well.
Jun 19, 2008 | Toshiba 42H81 42" Rear Projection...
Big screen TV
chances are the repair man wanted to sell you a whole board because with mitsubishis this problem is amost always the convergence ic's also in that model very seldom the resistors burn out in that unit its almost always the IC's that do that. I looked for you information you have an old chassis but I think its similar to the Vz2 I believe you need IC number STK391-020 thats based on theVz2 chassis but pls double check and you need 2 of them you can also save yourself if you know how to solder a lot of money by replacing them yourself its about a 45min job if I can help you any further pls let me know or if you would like a link where you can buy your parts very reasonable with tech online support let me know
May 08, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Televison & Video Logo
85 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
