AKAI 50'' Plasma PDP5006H Main Power Supply Board p/n LJ4400057A
I am looking for a main power supply, AKAI p/n LJ44-00057A for my 50” Akai PDP5006H plasma TV. I've looked everywhere but havent had any luck finding one. I was also curious if there might be another ''easier to find'' compatible part. Whatever info anyone could provide, would be tremendosly appreciated. Thanks so much.
    President:
  • 1,077 Answers
I looked around for a power supply for you and turn up nothing. I see your problem. Nobody is selling. Best just to fix the board itself.
What I would do is get a Service Manual over the internet. Nodevice.com is selling the Service Manual. Usually cost under $20. It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part number lists. And most cases the new part cost less than $15 by searching on the internet with the part number.
It's possible that it's just a bad capacitor or transformer on the power supply board. Cheaper than replacing the board.
I hope I solve the problem for you.
Posted on Jul 20, 2009
AKAI PDP5006H Plasma tv
1) Is the TV plugged directly into an outlet or is it plugged into another device, such as a cable box or audio receiver? If it is, try plugging directly into a wall outlet. Sometimes, devices like cable boxes don't provide enough current to power on more powerful newer TVs (like Plasma, LCD, etc) .
2) Check the manual to see if the flashing LED is a code for something you need to troubleshoot. The number and color of flashes may correspond to a problem that may or may not be easily fixed.
Hope that helps. Let me know how you make out.
Jan 15, 2008 | Akai PDP-5006HRB 50 in. Plasma Television
Akai 42' flatscreen i turn the power on the green indicator lights up and in i hear a click but i dont get a picture no other functions work such as volume,input,or channel buttons. is it my main board or...
On the power supply board there is a VA & VS voltage that you need to check to see if they are reading right. On the inside of the panel there is a lable that will tell you what the Voltages should be for VA & VS. If they are ok, they you probabaly have a bad Y board, if the votages are wrong then you need to replace the power supply. And check for bulged caps on power supply too.
Oct 14, 2010 | Akai PDP42Z5TA 42 in. Plasma Television
Part Number for AKAI PDP4206EA
Here are some links for most of the boards for this Akai model # PDP4206EA from a major parts distributor:
Akai PDP4206EA Replacement Part ATSC Digital / HD Tuner Board
Akai PDP4206EA Replacement Part Main Board Assembly
Akai PDP4206EA Replacement Part NTSC Analog Tuner Board
Please note: The X-SUS and Y-SUS boards and power supply board are no longer available and the video board is part of the main board assembly. Hope this information helps.
Feb 04, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Akai PDP42Z5TA
Back of an Akai PDP42Z5TA showing where the Power board is.
Dec 15, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
PDP5016H Akai Plasma TV
is the control board the one with the rca jacks on it,for sound and video input?if so email me at mesa1965@yahoo.com,i need one.
Oct 28, 2008 | Akai PDP-5016H 50 in. HD-Ready Plasma...
Akai
hi there,
you must told to your hubby to check for the continuity on the main power supply of the unit, there's a part that need to be Replaced Small Electros In Main Power Supply.
let me know.
Oct 05, 2008 | Akai PDP4290 42 in. EDTV-Ready Plasma...
Akai PDP4247-L PLASMA main power supply module
Yes there two power supply unit one for the main power supply is used for the plasma screen which helps to display the image on the tv screen ,So you need to replace the main power board did they say they have it??
Sep 08, 2008 | Televison & Video
VIDEO BOARD
Your tv is going into an error protection mode upon startup. The problem is probably not the video board. When the tv starts, it checks with the cpu to confrim voltages, if a voltage is off or there is a short somwhere, it will prevent the tv from starting up by clicking the relays to power off the high voltage of the tv. The problem could be the power supply, zsus board or ysus. Its hard to say without opening up the back of the set and testing some stuff with the meter, but normally its just a shorted cap, worst case you blew out a fet.. But easy to find if you know what your looking for.
Jul 12, 2008 | Akai PDP-5016H 50 in. HD-Ready Plasma...
Help
The Power Supply Board is listed below. Please note, there are 2 models with the same beginning number (PDP4294). Verify your model number before selecting the Power Supply Board as each board is different depending on the model number.
For PDP4294LV use:
Akai PDP4294LV Power Supply Board Replacement
For PDP4294LV1 use:
Akai PDP4294LV1 Power Supply Board Replacement
Apr 01, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Televison & Video Logo
1,523 people viewed this question
Top Televison & Video Experts
Electro Med Services...
