Keyboard shows up in computer. batteries are new. battery light does not come on when power switch is switched to ON. Keyboard does not appear to be functioning. Keyboard has not been damaged in any way.
SOURCE: logitech keyboard won't work
You may need to reinstall the drivers for the keyboard, they should have came on a CD with the keyboard, you may also be able to download the correct driver from Logitech's website. Try searching for 'logitech keyboard drivers' in Google or visit Logitech's own website.
Please rate if at all useful, thanks!
SOURCE: Logitech wireless mouse and keyboard
Normal
0
Press the Receiver button (and the lights will start
flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT
button on the back of the board to connect the keyboard to the
receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button
on the back of the mouse to connect to the receiver. Then they
should work okay.
Hope this helps. Bud
SOURCE: Logitech Wireless CE 0682 Keyboard won't work but mouse does
did this come with software
and you might need to do a uninstall reinstall
if it worked on same pc before it should work now.
if you have a reset button on transmitter try resetting it.
SOURCE: Logitech mouse n keyboard wont connect
whenever you chage the battery you have to syncnonize your keyboard and mouse to sensor of the reciver. you can see on the back side of the keyboard there is connect button just press it and on the recevre side also press the connect buton same setting do with mouse also.
