Question about Emerson EWF2004 20" TV
My daughter lost her remote control for her tv. I just connected the digital tv converty box. When I turn the tv on I can't tune it to channel 3 as I don't have a remote. When I push the channel up/down, it goes from channel 2 to 6. Thus I can't get the tv converter box to work. Any ideas.
  • Anonymous Mar 14, 2014
    WHAT CHANNEL DO I PRESET MY TV TO BE ABLE TO WATCH IT WITH MY CONVERTER BOX
    Sergeant:
  • 187 Answers
Hi..
its better to purchase a universal remote...I suggest using the Logitech harmony remote. It comes with all features of any OEM remote Including video input etc.
pls rate my suggestion...
Posted on Jul 20, 2009
Iv tuned in a new dgital tv, but channel 1 and 2 dont tune it, programs start a 3, if u go backwards, its channel 805 i think press the remote button to analauge and u get channel 1 and 2 but not good...
If you've got a digital box from your cable provider, your tv most likely needs to be on channel 3. At that point you would use the remote that came with the digital box to change the channel. (in other words, your tv would always stay on channel 3)
Mar 09, 2011 | Televison & Video
How to setup Toshiba CT824 tv with digibox (I have no user manual)
You can connect the digibox (digital converter box) or DTA to the TV using coax jumpers and tuning the TV set to channel 3 or 4 in some cases.
Connect the input (wire from the wall or floor) to the input on the digital box.
Connect the output of the digital box to the input of the TV set.
Turn on TV and digital box, tune TV to channel 3 using the TV remote or the buttons on the TV itself.
Use the digital box remote to change channels. You may need a code to program the remote to work the TV set.
I hope this helped.
Cheers!
Apr 27, 2010 | Televison & Video
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
Remote to Insignia Digital converter box will not do anything but turn unit on/off, although the light does flash when buttons are push - nothing happens.
Well, try it two different ways, as follows: But be sure that the tv-channel that's selected for tuning will be identical to the "output-channel" which you'll then select for the Insignia converter-box. So, if you first select Channel 3 for tuning the tv set, then you must later select Channel 3 on the "Output Channel" choice for the Insignia "set-up" menu. Similarly, if you first select Channel 4 for tuning the tv set, then you must later select Channel 4 on the "Output Channel" choice for the Insignia "set-up" menu. Be consistent! If you find that the Insignia menu-screen does not subsequently appear after tuning the tv to Channel 3, then start-over with Channel 4 as your proper tv-tuned station to initiate the pop-up screen for the Insignia menu.
Now, here's an example that assumes Channel 3 is the proper tuning-station for your tv-set within your particular region: You will first tune your tv-set itself (by means of its handheld tv-remote) to Channel 3. Be sure, however that your Insignia converter-box is turned-on and properly connected to your tv-set and antenna.
On your tv's hand-held remote-controller, you should find a button that serves as its "input selector" -- with a typical descriptor such as "Input" or "Line" or "Video/Antenna." Press that button, and enter successive channel numbers until you get to Channel 3. You may need to press the digits 03 to signify Channel 3. The tv-screen may be colored bright blue at that point.
Then, as you switch to holding your Insignia remote-controller, press the "Menu" button. (Please note that you will need to press hard and firm upon the buttons of the Insignia hand-held in order to get proper responsiveness; a quick touch of the button will not be effective.) After pressing the "Menu" button, the Insignia menu should now appear on the tv-screen. Now, you need to use your Insignia hand-held remote-controller (not the tv hand-held remote-controller again) to travel through the menu-screen to the "Setup" feature. Then, select "Output Channel." Proceed to select Channel 3 -- which will then be printed for you next to the Output Channel feature. Finally, under the same Setup menu, go to "Auto Tuning" -- which will commence a complete scan of all available channels.
Remember, if tuning by Channel 3 is inappropriate for tv-tuning within your particular geographic region, then repeat the above process by substituting Channel 4.
When you are done, you will rely almost exclusively upon the Insignia hand-held remote controller. You do not especially need to use your tv hand-held remote-controller again.
However, be sure to avoid standing in front of your tv-set to change channels by buttons or knobs upon the tv-set itself. Tuning again upon the tv-set itself will negate your prior tv-setting for either Channel 3 or Channel 4 -- and thereby sabotage your working set-up!
I myself incurred chronic anxiety yesterday (June 13), as I was stunned that the Insignia menu-screen did not appear immediately when I pushed "menu" on the Insignia hand-held.
The only buttons that worked on the Insignia handheld remote-controller were the Power-on for the converter-box and the Power-on for the tv-set.
(continued next page)
Because my expectation had been this process would take just a few minutes, I was deeply frustrated and impatient. However, I recognized that my apprehension of impending loss was absolutely appropriate as emotional "signal-processing" for me personally -- in contrast to my formerly high expectation of immediate fulfillment, completion, and gratification. Instead of my intention for quick success, I faced the stunning dread that the Insignia box had become defective or that I'd fail to ever figure-out the problem. I would not have been so impatient if I hadn't expected immediate success for the set-up.
I rejected the slogan that "I just want to get this over with!" I rejected the option of stomping upon the Insignia box! Amidst my hour-long anxiety, I summoned "Courage" -- a mode of patience to accompany my internal "quivering." I did a Google search.
From this Fix-Ya web-site and other troubleshooting sites, I had strong clues that improperly setting Channel 3 or Channel 4 was a primary culprit for the failure of the Insignia's menu-screen to appear. When I finally succeeded, my anxiety dissipated quickly with a temporary relief. But then came the anger that the Insignia "User Guide" had not been clear to explain the process. From that aftermath of outrage, I decided to promptly compose this protocol to assist others who have been similarly tormented -- perhaps to the extent of incorrectly believing that the Insignia converter-box was a defective product requiring prompt replacement.
Jun 02, 2009 | Insignia Digital-to-Analog Converter for...
Problems with insignia remote control on converter box
Well, try it two different ways, as follows: But be sure that the tv-channel that's selected for tuning will be identical to the "output-channel" which you'll then select for the Insignia converter-box. So, if you first select Channel 3 for tuning the tv set, then you must later select Channel 3 on the "Output Channel" choice for the Insignia "set-up" menu. Similarly, if you first select Channel 4 for tuning the tv set, then you must later select Channel 4 on the "Output Channel" choice for the Insignia "set-up" menu. Be consistent! If you find that the Insignia menu-screen does not subsequently appear after tuning the tv to Channel 3, then start-over with Channel 4 as your proper tv-tuned station to initiate the pop-up screen for the Insignia menu. Now, here's an example that assumes Channel 3 is the proper tuning-station for your tv-set within your particular region: You will first tune your tv-set itself (by means of its handheld tv-remote) to Channel 3. Be sure, however that your Insignia converter-box is turned-on and properly connected to your tv-set and antenna. On your tv's hand-held remote-controller, you should find a button that serves as its "input selector" -- with a typical descriptor such as "Input" or "Line" or "Video/Antenna." Press that button, and enter successive channel numbers until you get to Channel 3. You may need to press the digits 03 to signify Channel 3. The tv-screen may be colored bright blue at that point. Then, as you switch to holding your Insignia remote-controller, press the "Menu" button. (Please note that you will need to press hard and firm upon the buttons of the Insignia hand-held in order to get proper responsiveness; a quick touch of the button will not be effective.) After pressing the "Menu" button, the Insignia menu should now appear on the tv-screen. Now, you need to use your Insignia hand-held remote-controller (not the tv hand-held remote-controller again) to travel through the menu-screen to the "Setup" feature. Then, select "Output Channel." Proceed to select Channel 3 -- which will then be printed for you next to the Output Channel feature. Finally, under the same Setup menu, go to "Auto Tuning" -- which will commence a complete scan of all available channels. Remember, if tuning by Channel 3 is inappropriate for tv-tuning within your particular geographic region, then repeat the above process by substituting Channel 4. When you are done, you will rely almost exclusively upon the Insignia hand-held remote controller. You do not especially need to use your tv hand-held remote-controller again. However, be sure to avoid standing in front of your tv-set to change channels by buttons or knobs upon the tv-set itself. Tuning again upon the tv-set itself will negate your prior tv-setting for either Channel 3 or Channel 4 -- and thereby sabotage your working set-up! I myself incurred chronic anxiety yesterday (June 13), as I was stunned that the Insignia menu-screen did not appear immediately when I pushed "menu" on the Insignia hand-held. The only buttons that worked on the Insignia handheld remote-controller were the Power-on for the converter-box and the Power-on for the tv-set. (continued next page) Because my expectation had been this process would take just a few minutes, I was deeply frustrated and impatient. However, I recognized that my apprehension of impending loss was absolutely appropriate as emotional "signal-processing" for me personally -- in contrast to my formerly high expectation of immediate fulfillment, completion, and gratification. Instead of my intention for quick success, I faced the stunning dread that the Insignia box had become defective or that I'd fail to ever figure-out the problem. I would not have been so impatient if I hadn't expected immediate success for the set-up. I rejected the slogan that "I just want to get this over with!" I rejected the option of stomping upon the Insignia box! Amidst my hour-long anxiety, I summoned "Courage" -- a mode of patience to accompany my internal "quivering." I did a Google search. From this Fix-Ya web-site and other troubleshooting sites, I had strong clues that improperly setting Channel 3 or Channel 4 was a primary culprit for the failure of the Insignia's menu-screen to appear. When I finally succeeded, my anxiety dissipated quickly with a temporary relief. But then came the anger that the Insignia "User Guide" had not been clear to explain the process. From that aftermath of outrage, I decided to promptly compose this protocol to assist others who have been similarly tormented -- perhaps to the extent of incorrectly believing that the Insignia converter-box was a defective product requiring prompt replacement.
Feb 22, 2009 | Insignia Digital-to-Analog Converter for...
DTV converter box INSIGNIA
However, be sure to avoid standing in-front of your tv-set to change channels by buttons or knobs upon the tv-set itself. Tuning again upon the tv-set itself will negate your prior tv-setting for either Channel 3 or Channel 4 -- and thereby sabotage your working set-up!
From this FixYa web-site and other troubleshooting sites, I had strong clues that improperly setting Channel 3 or Channel 4 was a primary culprit for the failure of the Insignia's menu-screen to apprear. When I finally succeeded, my anxiety dissipated quickly with a temporary relief. But then came the anger that the Insignia "User Guide" had not been clear to explain the process. From that aftermath of outrage, I decided to promptly compose this protocol to assist others who have been similarly tormented -- perhaps to the extent of incorrectly believing that the Insignia converter-box was a defective product requiring prompt replacement.
Dec 03, 2008 | Insignia Digital-to-Analog Converter for...
Universal remote control
What is the make of your universel remote control.
Mar 14, 2008 | Televison & Video
Orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
Turn the set on, hook the cable directly to the TV, take the remote control and press 1 - 1 and if the TV tunes in channel 11 then your set is fine. If the TV was autoprogrammed when hooked to a cable box then the only channels that will be stored in memory are 3, maybe 4 and AUX. To correct this simply go back into the menu and look for the "autoprogram" option and perform the autoprogram while the cable is directly connected to the TV, without a cable box.
Jul 29, 2007 | Orion1934 19" TV
Emerson EWF2004 20" TV Logo
243 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
