Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Lamp light is red. TV will not turn on.
The lamp light is stuck on red. Nothing will happen at all. If I unplug it when I turn it back on I can hear noise in the background but the screen is still black. No fans come on at all. nothing happens.
  • 4 more comments
  • remedyrestor Jul 20, 2009
    Light is solid.
    Do I have a big problem?
    Well?
    Hello
    Thanks, I hope it is that simple.
    Thanks I will give it a try. Better than buying a new tv.
  • 3,037 Answers
Is the light blinking or staying solid as this can indicate an error code with the tv.
Benjamin
Posted on Jul 20, 2009
  • Benjamin Patri
    Benjamin Patri Jul 20, 2009
    If unplugging the TV for 4 hours doesn't work, then the constant red light is an indicator that your lamp has burned out and this will keep the tv from turning on.
    Just replaced one myself, it's simple-4 screws. If that doesn't fix it then I would look into the power supply or the DM board as being the culprits. You can order a new lamp from Mitsubishi or various online stores. Let me know how this turns out.
    Benjamin
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
The television will not turn on. Initially, when the remote (or button on tv) was used you would hear it turn on and hear some volume and then it would turn itself off. A red light would flash, stop...
You did not specify the brand and model of your tv but based on experience the red light indicator flashing means a projection lamp problem. Check the lamp and lamp doors if properly secured. If symptom persist you need to replace the lamp.
Aug 10, 2009 | Televison & Video
My infocus IN1 projector won't turn on anymore.
It may be the lamp is out. Normally a projector will try & fire the lamp 3-5 times then shut down with a different color light like amber or red. If the lamp doesn't light then it could be the lamp or perhaps the lamp ballast that starts the lamp has failed. A stuck fan also causes similar symptoms. There's 2-4 fans in the projector if one is stuck or bad it will turn off within 5 seconds or so after the lamp lights.
Does your lamp light at all? Are the lights a different color after it shuts down? Answers to these questions help figure out what's wrong though it's impossible to say for sure without looking at it. I service almost all Infocus projectors if you would like a quote please reply with your email address or write me at prmhelp@earthlink.net
Good Luck,
Jim
Jul 24, 2009 | InFocus Televison & Video
TV won't turn on
you need to replace the lamp in your tv, it is easy and you can do it. Look on the sides of the set for a door labled lamp, with the set unplugged open it up and remove the lamp, if the bulb is out it will have lots of glass in the lens
Jul 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tv won't turn on red lights blinking
You are hearing the spark gap mounted on the lamp ballast board. If you can hear that sound, that means everything in the lamp driver circuit is working except the lamp!
Get a new lamp.
michtech
Jan 31, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
STATUS LIGHT SOLID RED ON 73 DLP MITSU MODEL WD73735
The colorwheel is your problem. To confirm this, unplug the tv, then listen thru the air vents in the back as you plug the tv in. You will probably hear a ticking sound. If you do, that is the colrwheel. If the colrwheel is working, youwill be able to hear it "spin up". It will be a sudden high pitch whine. Let me know if I can be of further assistance
Dec 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
Sep 13, 2008 | Televison & Video
TV doesn't turn on
You really should give make & model number when posting, it helps us immensely, your lamp and possibly the ballast is bad, start with a new lamp first, odds are very good that it will fix your problem, can`t help more without manufacturer and model number, good luck, ps, order the original lamp, generics are junk and a waste of your money.
Nov 27, 2007 | Televison & Video
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
73 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
