Question about Goodman CKL42AR42 Air Conditioner
My Goodman a/c unit will not turn on ..
The outside unit will not kick on. we have heard the curcuit clik and can manually close the curcuit and the unit will work but it then blew a fuse ...
  • 3,361 Answers
You have a short circuit in the outside system. Either a bad compressor,bad fan motor or possibly a bad capacitor. Visually examine the capacitor. If it is bulged out anywhere,replace it. Check for burned wires on the capacitor and all other connections.
Remove the compressors wires from the circuit and restart the unit. If the fan runs the problem is in the compressor. If the fan does not run,the problem is with the fan motor.
Posted on Jul 21, 2009
  • 4 Answers
On this unit you probably have to replace the fuse on the box that goes on to the wall
Posted on Jul 20, 2009
Trying to figure out where the fuse on our outside heating and cooling unit is because the unit won't kick on
Should be a disconnect box next to unit. Heating is you have a heat strip is more likely in the attic close to the unti
Sep 17, 2013 | Goodman Heating & Cooling
I have a 2.5 ton ac outside. the indoor unit downstairs in the basement is a goodman. a new a coil was put in about a month ago. which is a goodman product. ive heard goodman is not a good product. a
the inside coil and outside unit should be matching in tonages another word if you have 2.5 ton outside the inside sould be the same. it don't matter what brand name or who made it.
Aug 04, 2012 | Goodman CKL36AR36 Air Conditioner
Where would the reset switch be located on a goodman ac unit
There shouldn't be a reset switch. The only units I've ever seen or heard of having a reset switch were old Rheem condenser, they had a high pressure switch that you could reset by pressing a red plastic button, but even Rheems no longer have them and I've never heard of Goodman using them.
What problem are you having with your A/C system? And why are you looking for a reset for it? Please repost your question and give us a bit more info so that we may help you with your probelm.
Jun 14, 2011 | Goodman CKL36AR36 Air Conditioner
My goodman central air unit quit working after a storm. The circuit breaker is not blown. The furnace fan kicks on when ac is turned on at the thermostat but unit outside does not operate. Is there an...
1 posible cause.the thermostat supplies 24 volts to the outside unit to control the contactor if you hear a ligth huming on the outside unit this is the being activated. if this is the case then
check to see if any ants are in or around the unit see video, they will usually climb to dry areas before during or after a storm and for some reason they like the contactor if this is the case cut all power to the unit and clean contactor spray the area around the unit with an insecticide ( not the contactor) replace cover and test unit. Best of Luck. raypena_4.jpg
May 30, 2011 | Goodman Heating & Cooling
I have outside Goodman-Janitrol furnace and air unit and
two things to try first to get you pointed in the right direction. First disconnect the R or RH wire from the T-Stat. If the furnace turns off (Stops firing w/ fan to turn offabout 90 sec. later) then you more than likely have a bad Thermistat. If it continues to run Pull the R wire from the Furnace circuit board. put door back on furnace if it stops you have a short in the wire. Still Running? Most likely a bad curcuit board. Hope this helps.
Oct 12, 2009 | Goodman GMS90703BXA Heater
Goodman outside unit not kicking on after power outage
If the outside fan works ,try to put a booster cap. in parallel with the capacitor , but if nothing works check the outside power supply box (or discennect) to see if a fuse is blown.
Sep 27, 2009 | Goodman CLQ36AR49 Air Conditioner
Outside unit kicks on but inside fan sometime works and sometimes won't and i have replaced thermostat to get to work i have to turn the fan to on and back to auto several times and finally the fan inside...
Goodman air handlers (inside unit) fan have a delay timer that turn on the fan ,sometimes up to 3 minutes after the outside unit is on,this makes the a/c more efficiency.
Sep 19, 2009 | Goodman CKL36AR36 Air Conditioner
I have a Goodman ckl49-1 airconditiong unit that
Check for burned wires at the outside unit and if the fan doesn't work could be the capacitor or the fan motor itself , i would try replacing the capacitor first is no more than $25.
Aug 27, 2009 | Heating & Cooling
Goodman CK36-18: Outside fan kicks on, but
Sounds like a bad capacitor. They can be bad and the fan will still run. Turn off power and check for burnt wires on the top of the contactor going to the capacitor or on the top of the capacitor.. Check terminals on the compressor also. When capacitors go bad they are slightly swollen. They can also look good and be bad . Could be compressor but start with capacitir and wires. IWork on a lot goodman units. Most of the time it is the cap.
Jun 03, 2009 | Heating & Cooling
Goodman heatpump. Crazy pressure in heat mode
Check the TXV valve on the outdoor unit, it could be stuck closed. We have been experiencing the same problems with the 410 systems and the TXV was the culprit. Good Luck
Dec 19, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman CKL42AR42 Air Conditioner Logo
1,660 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
