Question about Goodman GDS80703ANA Open Flame Mid-Size Heater
Goodman GDS80703ANA Can this furnace be converted to propane? What would it take? cost?
  • 1,420 Answers
Yes, goodman offers a kit. However you will need a gas technician adjust the pressure for you. The whole conversion will take about an hour. The kit may cost $50 and labor is anyone's guess. Call your gas company and give then the model and serial nimber. They can order it and install it.
Posted on Nov 20, 2007
New furnace, Water In Induction Motor, Yellow Flame
The problem is too much gas as opposed to not enough air. It is still running rich. Did you take into account the elevation of the location your furnace is installed at. The higher above sea level the less air that you have to aid in cumbustion. The condensation is from excess gas being cold and causing water to accumulate. Can you run it like this? Yes but it will cause issues with soot and carbon deposits. It will also cost you more money in the long run.
Dec 23, 2013 | Goodman Manufacturing Goodman GCH950453BX...
I HAVE A 1999 GOODMAN GMT070-3B FURNACE I PURCHASED USED MUST CONVERT TO PROPANE ,BUT I CANNOT FIND ORIFICE LOCATION
it will be in the combustion chamber on the burner bar you will have to remove the burner to get to it .
Sep 04, 2012 | Goodman GMS90703BXA Heater
New GMH80703AN two stage convertible.converted to LP. regulator on tank and a low pressure regulator next to furnace .I can hear and feel the furnace gas valve but no gas coming Thur to orifice
1.You could have a empty propane tank. 2 The regulator could be frozen. Has it rained or snowed recently? If so there is a vent on the regulator that could be plugged. I have had to thaw out 4 of these in the past week. Its simple unhook it and it bring it in the house and warm it with a heat gun or blow dryer for about 5 minutes.
Dec 18, 2010 | Goodman Heating & Cooling
My furnace blows cold air constantly even in heat mode. It's led light flashes 4 times in a set, what could it be?
On Goodman furnaces, 4 flashes usually means open high limit. Look for any burnt or loose wires or any resettable limits, they should have a red button that clicks when you push on it and wire going in and out of it with spade clips. If the open limit is not resettable, jump it out to verify its open and if that fixes the problem, replace the defective limit. Best of luck.
Mar 18, 2010 | Goodman GDS80703ANA Open Flame Mid-Size...
Goodman GS9 propane furnace inducer motor runs continuously
it sounds like the low temp limit switch, the one that cools the furnace down with the burner off and the thermostat open, when it cools to a point the fan stops, the other switch in burner area turns burner off/on, hope this helps
Jan 31, 2010 | Goodman GMS90703BXA Heater
Goodman furnace new in 07 flashed three code..It
you will neede to defrosted the flue clear any bushes or trees from flue if there ther eshould be a window on the front where you can see the lights hope this helps
Jan 10, 2010 | Goodman GDS80703ANA Open Flame Mid-Size...
Furnace Ignitor
At what point does the pilot blow out? Within 5 seconds after it lights or when the room air blower turns on?
Dec 03, 2007 | Goodman GDS80703ANA Open Flame Mid-Size...
Heating & Cooling Logo
147 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
