Question about Dynex DX-EF101 (DXEF101) External Floppy Drive
Every time I execute the .exe file, it says "This program could not install USB FDD Driver without Windows 98/ME
  • lkrogers Jul 20, 2009
    I have Vista & the packaging on this product says that Vista is supported. It is still not working.
  • 2,200 Answers
Hi
You need to go to this link. On that page click on USB and firewire - find the driver for the DX-EF101 Download and install it on your computer. Follow the instructions given to enable the drive to work on your computer.
http://www.dynexproducts.com/t-drivers.aspx
Hope this helps. Please remember to rate my answer. Many Thanks.
Posted on Jul 20, 2009
  • Radio Code Pro
    Radio Code Pro Jul 20, 2009
    Additional
    Dynex give additional information regarding common problems installing this floppy drive at this link
    http://www.dynexproducts.com/t-FAQs_Flop...
  • Radio Code Pro
    Hi
    As far as I understand Vista is supported but according to the information from Dynex on the second link I gave
    -When I try to install the drivers for my DX-EF101 in my Windows 2000/XP/Vista I get an error message about Windows 98/Me.
    The drivers that come with the DX-EF101 are only for Windows 98 and Me. For Windows 2000, XP and Vista, the product is Plug & Play (you connect it to the USB port and it's ready to be used).
    You can check for proper installation by going to My Computer. You should have a 3 1/2 Floppy Drive. Just stick a Floppy disc in the drive and double-click the icon.
    According to this under My computer Vista should have recognised the drive through plug and play. If the drive is not showing under My Comuter it is possible that plug and play has been disabled on your machine from opening automatically - therefore you will need to enable it.
    To re-enable the service in Vista press
    windows key+R, type services.msc, select plug and play service and right click, select properties, set service to auto, click start the service or reboot the computer, your choice. Plug and Play will now work automatically and this should help Vista to recognise the drive.
    If you are still having problems - let me know and I will do my best to help.
I am trying to install Printmaster Platinum 10 on a PC with Windows XP wihout any success. In the compatibility mode there is no option for Windows XP.
That program it's not compatible whit windows xp but you can try to install it on a machine whit windows xp whit thi istructions :
  1. mouse r-click on the installer
  2. select properties
  3. select compatibilites
  4. choose either Windows 98 mode or Windows 2000 mode
  5. click ok
  6. start the installation
if the installation process works fine follow this steps
  1. find the program directory under "C:\program files" or under "C:\"
  2. find the program executable (must be .exe )
  3. right click whit the mouse on the executable
  4. select properties
  5. select compatibility
  6. choose either Windows 98 mode or Windows 2000 mode
Aug 24, 2011 | Computers & Internet
Does CAD KEY 19 work in windows 7 ?
If you run it in Windows 7 in Windows 95/98/00 or NT 4.x compatibility mode then there is no reason why it wouldn't work. To do this;
1. Right-click on the executable (.exe) file and click on 'Properties'
2. Click on the 'Compatibility' tab
3. Check the box next to 'Run this program in compatibility mode for:'
4. Select 'Windows 98/Windows Me', 'Windows 2000' or 'Windows NT 4.0 (Service Pack 5)'
5. Click 'Apply' then 'OK'
6. Double-click the executable (.exe) file to open.
Hope this helps!
Regards,
Matt
Mar 03, 2011 | Cadkey Corp Cadkey 19 Full Version for PC
What is a binary file
A binary file is commonly referred to as a windows executable file.
These files are denoted by the .exe trailing the end of the file name.
These two terms "binary" and "executable" can be used interchangeably in this scenario.
An .exe file or executable is a file that launches a program or installation of a program... thusly called executable, as it executes a command.
Hope this helps!
Cheers!
Feb 23, 2011 | Computers & Internet
I need scanexpress a3 usb windows 7 driver pls
I succeeded into installing and using the Mustek ScanExpress A3 USB!
I downloaded the driver for Windows Vista from the Mustek website, then did the following steps:
1. left mouse click on the web.exe downloaded file and choose Properties;
2. in Properties I checked "Execute this program always as Administrator" and "Execute in compatibility mode for Windows Vista";
3. without any scanner connected I executed web.exe, gave the authorization even if recognized certificate;
4. allowed the system to restart;
5. connected the scanner;
6. directly used it into any program.
Please let me know if these instructions was useful!
Regards and good luck.
Sandro from Italy!
Apr 13, 2010 | Mustek A3 USB Flatbed Scanner
Error code 2352
http://service1.symantec.com/SUPPORT/nav.nsf/pfdocs/2003020714354306?Open&docid=2003020714354306&nsf=nav.nsf&view=pfdocs
To run the Microsoft Windows Installer if Norton AntiVirus was installed from the CD
  1. Insert the Norton AntiVirus CD into the CD-ROM drive.
  2. Do one of the following:
    • If the installation program appears, then click Browse the CD
    • If the installation program does not appear, then double-click the My Computer icon on the Windows desktop, and then double-click the CD-ROM drive icon.
  3. Double-click the MSI folder.
  4. Do one of the following:
    • In Windows 98/Me, double-click the WIN9x folder.
    • In Windows 2000/XP, double-click the WINNT folder.
  5. Do one of the following:
    • In Windows 98/Me, double-click the Instmsi.exe file.
    • In Windows 2000/XP, double-click Instmsiw.exe if you have Windows 2000/XP.
  6. In the next dialog box, click Yes.
  7. After the rollback has finished, then reinstall Norton AntiVirus.
    Follow the instruction in Reinstalling your Symantec program after a failed installation or after you see error messages to start the computer without any programs running on startup and then reinstall your Norton program.
If these steps do not fix the problem, then go on to the next section.
To run the Microsoft Windows Installer if Norton AntiVirus was installed from a downloaded version
  1. On the Windows taskbar, click Start > Find (or Search) > Files or Folders.
  2. Ensure that "Look in" is set to the drive where you downloaded Norton AntiVirus, and that "Include subfolders" is checked.
  3. In the "Named" or "Search for..." box, do one of the following:
    • In Windows 98/Me, type the following:
      instmsi.exe
    • In Windows 2000/XP, type the following:
      instmsiw.exe
  4. Click Find Now or Search Now.
    You might see many files with this name. Look for the file with this name that is located in either the Symantec_Norton_AntiVirus_2003 or the your Windows temporary file location depending on your version of Norton AntiVirus.
  5. In the Search Results window, do one of the following, depending on your version of Windows:
    • In Windows 98/Me, double-click Instmsi.exe.
    • In Windows 2000/XP, double-click Instmsiw.exe.
    This will undo the changes that were made to your system during the first failed installation.
  7. After the process finishes, then reinstall Norton AntiVirus.
Apr 22, 2009 | Microsoft Windows Vista Home Premium...
How to install java games directly on M8800 without OTA? CAN ANYBODY TELL ME HOW TO INSTALL JAVA GAMES DIRECTLY ON SAMSUNG PIXON (M8800) WITHOUT GOING TO OVER-TO-AIR (OTA) INSTALLATION?
. Download Driver & File Explorer. ici
2. Uncompress SAMSUNG_Composite_USB_Driver_4_34_WHQL.zip and execute Setup.exe.
3. Connect F480 to PC. First time you should be prompted with a 'device installed and ready' message.
4. Execute TkFileExplorer_2.2.exe
5. Go to Settings - COM.
6. Scroll down Port window: You should get just one COMxx option. Choose it and press OK.
7. Go to File - Connect. You should get the F480 File System Tree at TkFileExplorer bottom half side.
8. Go to /Exe/Java/Games
9. Create a New Folder for your game
10. At TkFileExplorer PC upper side select game JAD/JAR files and copy to F480 created folder using drag&drop or right button menu Download option.
11. Repeat steps 9 & 10 for all games you want to install at a time.
12. Disconnect USB cable
13. Dial *#6984125*#
14. Go to Internals (Master Key: *#9072641*#)
15. Go to Storage Settings and select Update Java DB and java app
Mar 22, 2009 | Parrot Par Ck3000 Evolution Ck3000...
I don't have driver of pen drive in windows 98
Let's check your Windows 98 Version first :)
  • Right click on My Computer and select Properties
  • On the System Properties page that opens up click on the General tab, if it is not already on that page.
  • Under the System heading, look for the version number (see right)
    • Version 4.10.1998 is the original version of Windows 98 (98FE)
    • Version 4.10.2222 is Windows 98 Second Edition (98SE)
  • Click the link below for the download and installation instructions for your version of Windows 98
Fo Windows 98 FE:
  1. Download and install the Windows 98 Service Pack (35.5Mb)
  2. Download to your desktop the driver file from the Download section below
  3. Remove ALL drivers for USB flash drives in Device Manager (Optional)
  4. Remove ALL drivers for any USB 2.0 controllers (many have an uninstall option) (Optional)
  5. Remove ALL unknown devices from Device Manager
  6. Run the exe file you downloaded, and follow the instructions, rebooting after installation
  7. When the computer boots up again, it may detect new USB 2.0 controllers, in which case you may need to reboot again
The drivers can be downloaded from the following link:
Windows 98 FE Generic USB Mass Storage Device Drivers v3.20
For Windows 98SE:
  1. Download the exe file to the desktop
  2. Remove ALL drivers for USB flash drives in Device Manager
  3. Remove ALL drivers for any USB 2.0 controllers (many have an uninstall option)
  4. Remove ALL unknown devices from Device Manager
  5. Run the exe file you downloaded, and follow the instructions, rebooting after installation
  6. When the computer boots up again, it may detect new USB 2.0 controllers, in which case you may need to reboot again
Windows 98 SE Generic USB Mass Storage Device Drivers v3.3
For detail explanation, please visit http://www.technical-assistance.co.uk.
It's help for me :)
Thanks
AkulahPathub
Mar 13, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
3D mazeman
The game was released in 1998, and was developed for Windows 95/98.
To make the game run on Windows XP, try the compatibility for the installation and after it is installed use the same steps for making the game executable file compatible.
Note: Some game ".exe" file (executable file) would let you make changes in the Compatibility option, whereas older games might not give that option at all.
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows 98/ Windows Me" and then click on "Apply". (You can also try "Windows 95")
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
You can delete all the files copied from the CD after completing the installation
After the game is successfully installed right click on the game shortcut or the game ".exe" in the root folder of the game and click and click on "Properties".
In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows 98/ Windows Me" and then click on "Apply". (Again, you can also try "Windows 95")
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
There are lot of files that need to be changed in order to get full functionality and to communicate with operating system and the hardware, hence there is no guarantee that the game might run even in cases where you will successfully install an older version of the game with the above mentioned steps.
Oct 24, 2008 | eGames 3D Mazeman Amazing Adventures for...
Installing jetflash 2 windowsme
Download and install the following files and try again. The should also work with Windows ME as it is just a dressed up version of Windows 98.
For Windows 95, 98 and NT VBRun60.exe - VBRun60.exe installs Visual Basic 6.0 run-time files.
VBRun60sp5.exe - VBRun60sp5.exe installs Visual Basic 6.0 sp5 run-time files
For Windows 98 only DCOM98.exe - Extends the support for Distributed Component Object Model (DCOM) for Microsoft Windows 98.
Apr 10, 2008 | Computers & Internet
D40 Zoom and Camedia Software
Camedia software leaves a lot to be desired. I prefer to use a USB media reader and Google's excellent Picasa software to manage my photos.
Mar 31, 2017 | Olympus Camedia D-40 Zoom Digital Camera
Dynex DX-EF101 (DXEF101) External Floppy Drive Logo
63 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
