Question about LG WM2487HWMA Front Load Stacked Washer / Dryer
How do you remove the drawer from the pedestal? I need to wipe up all the water it just spit out????
    President:
  • 1,273 Answers
Either lift on the front of the drawer when it is fully open, or there may be a catch in the drawer.
Regards, --W/D--
Posted on Jul 20, 2009
How do I remove a pedestal drawer on and electrolux dryer
Hello friend, thanks for your inquiry!
I have researched that information for you and was unable to locate steps on how to remove the drawer from your pedestal. I would suggest seeking assistance from a professional for proper removal of the drawer. Hopefully this helps. -Matt
Sep 28, 2014 | Electrolux Washer/Dryer Laundry Pedestal...
Remove washer pedestal drawer Cannot remove drawer to check behind or underneath, please help.
  • Open the drawer fully. Look at the rear of the support slide is there a small, black plastic lever on one side push the lever down, the other side pull the lever up.
  • Remove the small screw on either side of the support slide at the front of the drawer. Lift the drawer and push support slide away from the drawer
Oct 30, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
Aug 04, 2011 | Whirlpool GHW9400 Duet Washer
Wm2277hw is leaking water from the bottom... does not appear to be coming from a hose at the back. The washer is on a pedestal and water was dripping into the drawer, was wet between the washer and the...
Easiest start is to take the top off and check for leaks maybe using a flashlight. Top comes off by removing a couple of screws in back, the sliding it rearward about 3 inches and then lifting up. Good luck. Report back what you find. Use comments.
Jan 25, 2018 | LG WM-2277HW Front Load Washer
MAJOR leak in new JUST installed WCVH6800 front load washer
If you hear of a solution, let everyone know. Our machine did the same thing. From the research I have seen, GE makes **** machines and I will NEVER buy a GE product again.
Feb 07, 2010 | General Electric WCVH6800J Front Load...
How to remove drawer on pedestal
You need to remove the 2 screws holding the black rails on both sides of the drawer. Took us a while to figure this one out also.
Jan 01, 2010 | LG WM2487HWMA Front Load Stacked Washer /...
How can I remove the Whirlpool Duet washer pedestal drawer?
When you look this will not appear to be how it is done but it is in fact the way. Pull the drawer all the way out and then look on the side of the drawer at the very front and you will see a single small screw that attaches the track to the drawer. It would appear this is part of a series of screws and the track itself should seperate but neither side of the track removes. Simply remove these screws on both sides of the drawer with a small hex head socket and the drawer will pull right out. Push the tracks back into the pedestal until done cleaning the drawer.
Jun 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Samsung Pedestal Drawer
If you pull out the drawer (completely) you should find 1 or 2 screws on each side that bolts the slider to the drawer. Remove these, then lift out the drawer. This then gives you full access inside. ...JimS
Jul 31, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Remove pedestal drawer from washer
First remove the top of the washer via 3 tork, 7mm hex head screws (they are hidden located on rear of washer) then you can see to line up the tub with the shipping bolts. Just put 2 in --one lower and upper opposing each other and that will be sufficient. I believe there is two screws holding the drawer in located at the track towards the front of the drawer. Now you can lean it over with no worries to remove pedestal
Jan 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG WM2487HWMA Front Load Stacked Washer / Dryer Logo
857 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
