Question about Acer Aspire 5100 Notebook
Hi, i have an Acer 5100 and the screen is really dark... can only just make out the screen. I have tried the fn key trick with no luck. I have replaced the inverter and also the screen.... again no joy. I'm running vista 32bit Can someone help me please :)
  • duck86 Jul 20, 2009
    Hi thanks for you fast reply :) where abouts do i find the CCLF lamp on the laptop?? i hope i have already ruled out the lcd screen, inverter as both have just been replaced :)
  • Acer Master
  • 32,281 Answers
The fault could be a faulty video cable or connector or CCFL lamp or inverter.
Try reseating the video cable/connector that connects to the motherboard first.
If this doesn't work then to determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jul 20, 2009
  • Chris Hingee
    Chris Hingee Jul 23, 2009
    The CCFL lamp is located on the bottom edge of the LCD screen.
    Have a look at the WEB site I suggected.
How do I darken my screen ..it is to bright - acer -aspire 5100. Where is the Fn key located on the keyboard?
Hi
Fn key at the bottom left between the Ctrl and Winkey
To adjust the brightness, hold the Fn key and press the cursor key - down darker, brighter up
Sep 20, 2010 | Acer Aspire 5100 Notebook
Screen to dark
Hold Fn key and tap the up sun key.looks like a small sun.
May 20, 2010 | Acer Aspire 5100 Notebook
The screen on my aspire 5100 is so dark i can hardly see it
hi mary welcome to the forum! 1)you have an Fn key bottom row left, hold down while also pressing right arrow, bottom right. Each press increases brightness. Each press of left arrow decreases brightness. 2)go to the manual of Aspire 5100 that you there is the option "AcerClearVision" in the software "AcerArcade". See manual:"Acer Clear Vision is a video enhancement technology that detects video content and dynamically adjusts the brightness/contrast/saturation levels so that you do not need to change the color settings if the movie you are watching contains scenes that are overly dark or too bright." So you opened "AcerArcade". There you take: "movie or cinema--> settings -->display settings" en there you change in the option 'color profile' 'ClearVision' to 'Original'.
May 21, 2010 | Acer Aspire 5100 Notebook
My laptop comes on everything lights up except the screen
it would be the blue lettered fn and f6 keys, hold fn key-then hit the f6 key to toggle display. otherwise try and reset the notebook- take out battery and unplug the unit. then push and hold the power button for 60 seconds. then put the battery and plug it back in, and try and see if that works. this has worked on my acer 5100 several times! the screen could have a problem also. this is what i worry about every time this happens 2 me. good luck! if i can help more reply.
Sep 02, 2009 | Acer Aspire 5100 Notebook
LAP TOP SHINE
look where you fuction keys are is ther a symbol like a sun with up/down arrows on it.if so press up arrow to brighten or use Fn and the up arrow key together.
Jun 30, 2009 | Acer Aspire 5100 Notebook
Keyboard and mouse pad on my laptop. Acer 5100 vista
On an Acer, the Fn key plus F7 will turn the touchpad on and off.
Try that to see if it works.
Mar 22, 2009 | Acer Aspire 5100 Notebook
I have an acer 5100 and I need to know how to adjust the brightness of the screen. It is really dim. how do I brighten it up some?
hold down the FN key thats to the left of the space bar and use the up and down arrows to the right of the space bar to raise and lower brightness
Dec 10, 2008 | Acer Aspire 5100 Notebook
Laptop's dark screen is pissing me off
Hi, i have an Acer 5100 and the screen is really dark... can only just make out the screen. I have tried the fn key trick with no luck. I have replaced the inverter and also the screen.... again no joy. Can someone help me please :)
Jul 28, 2008 | Acer Aspire 5100 Notebook
Monter is too dark
should be a Fn key with F5..
Apr 28, 2008 | Acer Aspire 5100-5022 Notebook
Acer Aspire 5630 screen brightness adjustment...
How do I adjust my brightness or contrast on my laptop? See our brightness definition for a visual example. Finally, most laptops only enable users to adjust their brightness of their screen.
Click on the above Link, Good Luck, Please dont for get to Vote.Thank you.
Dec 15, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
386 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
