Question about Polaroid TDA-03211C 32 in. LCD HDTV
Red light turns on, But not television
The red light on my LCD is on, signaling it has power yet when I used the remote and the power button on the side of the television it just won't turn on!!!!!!!!!
    President:
  • 1,077 Answers
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. It maybe something simple like a blown fuse inside the TV. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15 by searchingon the internet with the part number.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 20, 2009
  • 744 Answers
HI
MOST TV'S HAVE A SMALL FUSE INSIDE TO PROTECT THE CIRCUITS.
OPEN THE BACK CAREFULLY AND LOOK FOR A GLASS SEE THROUGH TYPE FUSE ABOUT 5 AMP SIZE.
REPLACE THIS AND TRY YOUR TV
thank u
rate me
    Scholar:
  • 120 Answers
This model has a problem with the main board. Which has you processors and logic chips. (bottom middle that all your inputs connect to.) In my experience with this model if you have and LED the power board is most likely working and you need to replace your main board about 150
www.RNS-Systems.com or E-bay
Posted on Oct 16, 2009
Philips LCD TV Red Light Stays On, TV won't turn on or respond in any way
Could be power supply failure or you may not be using the "hospitality" remote.
Aug 13, 2014 | Televison & Video
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
Samsung LN46D630 Wont turn on
http://www.tvrepairdoctor.com
Oct 26, 2012 | Samsung LN46D630 LCD TV
Tv won't turn on
Replace the power supply board the blinking power indicator is usually indicating the power supply needs replacement or repair. You can get the replacement power supply boards from www.tvcircuitboards.com
Oct 20, 2012 | Samsung LN-S3241D 32 in.LCD HDTV
The red light on my t.v. is flashing but my t.v. wont come on
I would try unplugging everything, then plug back in. Try new batteries in remote if there is one. This sounds like TV is not getting signal to turn on, so I would look carefully at remote power and 'eye' and power button connections. Good luck!
Aug 13, 2012 | Akai LCT3285TA 32 in. LCD Television
Hi I have a vizio tv control with the key board and it all just stopped working so I thought it was the batteries changed them still not working ????? Help Please
Test ur tv remote control first see,if it is working,malfuctions or completely dead?U have a Digital Camer wright?Yes.Digital Camera can read Infer Red signal Output by the tv remote.Yes?Turn the Digital Camera on and take the tv remote point it at the Digital camer and pushes all the remote buttons the Infer Red signal will read all buttons Infer Red signal flashes u can see on Digital Camer viewing screen.Pushes all remote buttons see flashes of white lights.Mean the tv remote control it it good or not.Take some cottons ball soak it with some rubbing alchachol clean the tv Infered Red sensor on the tv frame near the power LED incation light.Might be dirty,Still not reading the Infer Red signal.If 100% it is the tv remote control is the cause,it CPU is dead.Try website like Remotes.com to buy another the tv original remote.
Jul 29, 2011 | Vizio VO47L 47 in. LCD TV
My sony grand wega kdf e55a20 power light keeps blinking red. what can the problem be?
Red is an indication signal for power connectivity. Recent devices have two power functionalities. Using the remote control would turn off the display of images to power saver mode. A red power light imiting diode display is indication that requiring display of images is achievable by pressing on the display mode button once more. NOTES; Powering on the device may be achieved with the same function buttons as shutting down the entire Device to least communicate with the power supply circuity from outlet sources. The device is in power off mode ready for repower on with the remote control. Requesting the TV to shut down completely would require to press on the TV button firmly until power cuicuit are disbabled completely. Refer to the TV user guide to ascertain fucntionaility modes usual during operations. Goodluck
Jan 08, 2011 | Sony KDF-E55A20 55 in. LCD Television
My 32" Samsung lcd tv won't turn on, led is solid red
The Main bd is bad. It is not sending a turn on signal to the power supply.
Apr 09, 2010 | Samsung LTM1755 17 in. HD-Ready LCD...
Sky remote code fo LCD LE40A456 TV
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Jan 26, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Flashing red light
Same problem with my Sony. Unplugging for 36 hours solved the problem
Oct 05, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Polaroid TDA-03211C 32 in. LCD HDTV Logo
640 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
