Question about Xerox Office Equipment & Supplies
I restore my xerox dc 12firey now that is asked for password how i reset that
    New Friend:
  • 44 Answers
The default password is "Firey.1"
Posted on Oct 02, 2009
Reset to factory settings xerox 3635 mfp
Solution : Perform a Software Reset The Software Reset utility allows for the reset of the machine software without powering the machine off and on.
  1. Press the [Log In / Out] button on the Control Panel.
  2. Enter the password using the numeric keypad, and then select [Enter] on the Touch Screen.
    NOTE: The default password is "1111". It is recommended that the System Administrator change this password. For additional information, press the [Help] button on the Control Panel.
  3. Press the [Machine Status] button on the Control Panel.
  4. Select the [Tools] tab on the Touch Screen.
  5. Select [Device Settings].
  6. Select [Tests & Resets].
  7. Select [Software Reset].
  8. Select the [Reset System Software] button. A pop-up window will be displayed warning that jobs in the system may be lost, and asking you to confirm that you wish to continue.
  9. Select [Confirm] to perform the reset.
Dec 16, 2014 | Xerox Office Equipment & Supplies
How to reset admin password on phaser 3635
xerox machines come with default passwords.
once that password is changed only the changer knows it.
should he forget or lose the password he flat has a problem.
the reset requires a xerox laptop/tech to reset and they "will bill" you for doing it.
Jul 01, 2011 | Xerox Phaser 3635MFP/X Multifunction...
How to check the meter count on Xerox DC 12 machine? I m asking this as i m buying a used DC 12 machine from a vendor and want to make sure i get wat i am paying for... besides this i am also interested in...
Forget trying to reset the meter. It would be a momoth task to do that even if it was leagle to do it. Xerox engineeres would not do it so don't think of it.
The DC12 has been out of production for several years, it was a good machine and a lot of customers just loved them.
Getting spare parts etc might be a bit of problem. In my opinion look for a later model especially if you want to use it in a pay for print situation.
Cheers &
Good luck.
Dec 25, 2010 | Xerox Office Equipment & Supplies
I have a Xerox dc 3535 that I need to set the admin password on (don't even know what it was) how do i do that?
The default password is "11111", via Workstation CWS the admin password is just blank.
Oct 08, 2010 | Xerox DocuColor 3535 Copier
Code 004 xerox 5750 copier
Code 004 means that the waste toner sump must be vacuumed.After that, reset DC 135 HFSI 9.836, go to DC 131 and reset to 0 positions 6058/6059/6060
The first code that appears is 001. If you had taken the proper actions, code 004 hadn't came.To find this code u should follow ""CALL FLOW" on page 1-3.
Apr 22, 2010 | Xerox DocuColor 5750 Printer
How do I reset a Xerox Phaser 4500 Centreware password to factory default.. or what is the factory default password? I have on which has been changed and nobody seems to know the PW anylonger
this should restore it to default.
By default there is no username or password required to access CentreWare Internet Services. If a username and password have been configured for CentreWare Internet Services and you do not remember the username and / or password, reset the printer to factory defaults (NVRAM reset).
To reset the NVRAM, go to the front panel's Main Menu:
  1. Select Troubleshooting, then press the OK button.
  2. Select Service Tools, then press the OK button.
  3. Select Reset NVRAM, press the OK button.
  4. Select Reset NVRAM and Reset Printer NOW, then press the OK button to reset all the settings to their factory default values.
Mar 03, 2010 | Xerox Phaser 4500 Printer
Lost my password to our xerox 460st. and We can
If you had not changed originally, it should be 11111, or 1111.
If you changed it, you need a laptop with diagnostic capabilities.
Jan 15, 2010 | Xerox Document Centre 420 DC Laser Printer
Password Problem Phaser 6120
Unfortunetly, you will have to reset the printer. Using the control panel go to the default setting and scroll to reset to factory settings. Then select yes and that should take care of it. If not, then in the rear of the printer under the cover, upper left side you will find the memory button battery. Remove the battery, unplug the unit, and turn it on for about a minute. Turn it off and put it back together and you should be ok. Good luck.
Feb 19, 2009 | Xerox Phaser 6120/YN Laser Printer
77 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
