Question about Home
My 14 month old boy threw a pen in the toilet when it was flushing it went down now toilet won't flush well
    Novelist:
  • 109 Answers
Pen probably is jammed in the p-trap cast into the toilet and is restricting anything being flushed. This could build up and cause an overflow (yuk!). Worst case is that it went farther into the system and is stuck somewhere "down the line". Easiest way to fix is shut off water to the toilet (small valve on the wall behind toilet). Staighten out a wire coat hanger leaving a small hook in one end. Try snaking it through the toilet bowl where everything goes down and hook the pen and bring it back into the bowl. Proceed gently as you want to try to recover the pen rather than have it go farther into the system. Due to the length of the pen, it is probably not very far up into the trap area. Good luck, and if this has helped please rate it accordingly.
Posted on Jul 20, 2009
  • 653 Answers
Get a long pair of rubber gloves and reach up into the trap area of the toilet (that little squiggly bend you can see from the side) to take out the pen and accumulated TP, etc... If your hand is too big, you could ask your wife to fish it out. The only other alternative is to remove the toilet and try to get to the pen from the other end. Turn off the water, disconnect the water line, drain the bowl and tank (using a large sponge and bucket) undo the two bolts holding the toilet to the floor and lift the toilet off of the flange and set it down on the plastic sheet I forgot to mention earlier. Fish out the pen, and use a putty knife to remove the remains of the wax seal. Put the new seal in place and gently lower the toilet onto the mounting bolts. It helps to have an extra set of eyes and hands right about now. Tighten up the bolts finger tight, then sit down on the toilet seat to firmly bed the seal, then tighten the bolts the rest of the way. DO NOT OVERTIGHTEN THE BOLTS or you could break the flange and have to buy a replacement toilet. Reconnect the water and you should be ready to go (literally).
Is there a way to change the toilet from front flush to top flush to accommodate the button on the top of the unit in the tank?
So did the top not come with the tank itself, is it a replacement? Or is it a tank where you can choose top or front flushing?
In my experience the mechanism for top flush is more complicated than front flush which just lifts the flapper. Take the top off and look. See if there is a link that can be taken from the front and clipped to the top. you state is has a 'self contained unit', so it doesn't sound like a standard lifting flapper, so you may well be able to choose.
Jan 01, 2016 | Home
How do I fix KOHLER Touchless toilet it keeps flushing, it is less than 6 months old
We had a problem with phantom flushing. Call Kholer. They will send redesigned battery holder and top of flush unit for free. Seems to have fixed the issue.
Oct 01, 2014 | Kohler Home
Toilet not flushing completely
Prelude:
My toilet had the same problem a few times. I managed to clean it out because the pipe is somehow connected to the downstairs drainage pipe in my house. What fixed the toilet clog was going to the source of the problem and pouring extremely powerful hair clog remover chemicals in it (I did have to open all the windows and get the pets as far away as possible and wear a mask). After the specified amount of time waiting, I went to go flush and it worked.
**Answer**:
I would recommend doing the same thing but only if everyone in the house is gone for 1 hour. Also I would air it out by leaving windows open, not first floor doors or windows though. It can be deadly if inhaled for extended periods of time. The more powerful the cleaner, the better the results but the deadlier it can be if inhaled. Try this.
My second guess is that it may be the plug inside the toilet's tank. You should check to see if it is working properly. Try flushing with the lid off and watch the plug to see if it is working properly.
Mar 13, 2014 | Kohler Home
Kohler toilet not flushing completely
You have a partial clog, as if someone tried to flush paper towels or something that shouldn't have gone in the drain.
Try plunging, first, then a toilet snake, or you may have to get a pro to pull the toilet off the floor and run a larger snake if it's further down...
Mar 12, 2014 | Home
My toilet doesn't flush every time I flush it! It only flush If I pour a little more water into toilet bowl while water coming down toilet bowl! I've checked water level in tank and it was full...
I think the problem with your toilet bowl is in the tank fitting of it..you better check if the fittings are proprerly working..You also check the flapper and also the fillvalve.
If it is not good already you can replace it by buying the tank fittings at the hardware store..And you better also be check it to your plumber for the second thought..
Jun 17, 2011 | American Standard Home
We bought a Kohler Cimarron complete solutions 2 pc. toilet about 2 months ago and now it doesn't want to flush properly.The toilet fills half way up with water instead of just wooshing down like it...
Before taking it out you need to go back to Lowe's and purchase a toilet auger....
With this you can crank it down through the trap of the toilet and remove the obstruction...there is something in there that a plunger will not remove...example...a pen or pencil... comb...these are commonly removed when I het the symptoms you are giving...
heatman101
Aug 13, 2010 | Kohler Cimarron Comfort Height elongated...
Kohler Toilet year old do not have flapper. It has stright pipe
This is how it is meant to work!
Short push of lever for small flush, push and hold lever for full flush.
Aug 16, 2009 | Kohler Toilet - One Piece with Ingenium...
Sanibest toilet is LOUD when flushed
Shut down the power and pull the pump from the unit and give it a exam. There might be something as simple as a item that was flushed down the toilet (pencil, pens, combs, etc.) or just a hair clump. Check that the float is free to track fully up and down. Good Luck!
May 17, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
Home Logo
1,150 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
