hi....take it to a tech to check about the system control chip... the control chip would have gone bad... and they will replace u with a new chip.. or else Try manually moving the head carriage back and forth a few times! Also check, if there isn't some piece of paper lodged inside, if yes try to remove it carefully!..
these are the possible solutions u can try out... thank u rate me
I assume you have removed the plastic cover from the new ink cartridge.
New Ink cartride should work immediatly if it doesn't I would say that the ink cartridge has dried out. Ink cartridges that stand for a long time even when completly closed has the tendency to dry.
Messing with the Ink is a constant battle, thats way I moved to simple only black laser printer . laser printer today are that expensive and if you print in black only or even most of the time consider moving to laser printer.
Hi, I have Epson C43SX printer; I did not use the printer fro sometime. I changed the Cartridge; but...
(More)
Hi, I have Epson C43SX printer; I did not use the printer fro sometime. I changed the Cartridge; but the printing is not clear; sumdged?? how to solve
Epson Styus color 440 i just replaced black ink cartridge, printer goes thru all the motions but...
(More)
Epson Styus color 440 i just replaced black ink cartridge, printer goes thru all the motions but does not print.
