Question about Electrical Supplies
Genarator runs for short time then shuts down
Genarator runs off motor home diesel fuel tank
    President:
  • 1,723 Answers
Is the generator a disel engine.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 20, 2009
Tahoe 7000 lxr diesel generator starts and runs then 2 min. later it reves up and down then shuts off
indicates insufficient fuel flow through the tap or filter in the tank
all engines will increase in rpm as the mixture leans out from insufficient fuel in the carby then will shut down from lack of fuel
Oct 28, 2017 | Diesel Electrical Supplies
How can water get to the diesel tank from the radiator reservoir?
there is no connection between the coolant reservoir and the diesel tank. However when running diesel fuel becomes hot from the return fuel from the injectors that is used to cool and lubricate the injectors. Diesel tanks are vented to the atmosphere and so condensation forms in the tank when it cools down. This accumulates and is picked up and goes to the filter ( should have a water separator in the system) Left untreated a moss grows in the fuel which blocks filters and injectors Use a diesel fuel conditioner to control the rubbish A method of controlling water in the tank that is used by all long distance operators is to fill to the top every time before shutting down for the night.
Mar 18, 2014 | 2006 Audi A3
What's your problem?my citroen c5 diesel 53 plate 2.0 ltr HDi comes up with, anti-polution fault, on dash, with service and engine management lights on, then it goes into emergency mode, then will
Empty the tank completely. The additive you put in with only a gallon of fuel is not combustible and won't run. Bleed the system, after replacing the filter and refill the tank with fresh fuel by cranking and open all injectors one at a time, starting with the one closest to the injector distribution pump, until you get clean fuel from each injector. It will start and run shortly. Never put any additive in the tank without the tank being full of fuel after the additive is put in. All these additives, like I said, are non-combustible.
Nov 28, 2017 | Cars & Trucks
Buying a 1995 f25 diesel from a frien and he ran unleaded gas in it and now it blows alot of white smoke
blown head gasket an the white smoke is the truck burning off the antifreeze thats leaking into oil big job to repair 1500$at a cheaper shop...bad to run without fixing due to antifreeze thins oil and internal damage to engine will result....thanks for using fix ya.good luck friend never ran gas a diesel will not run on gas and will shut down almost imeditely if clean diesel is dirtied in any way...
Apr 02, 2011 | 1995 Ford F250
Genarator runs short period of time & shut down
What type of motorhome & generator is it. Some generators will shut down (basically run out of gas) at 1/4-1/2 tank in motorhome as a feature, to allow you enough gas to get to a station, in case you forget. The fitting for fuel from tank, for generator is placed that way in tank. Is that not the case? Make sure you have at least 1/2 or more fuel in tank of motorhome just to be sure, as we found many that were supposed to be set about 1/4 tank, but were closer to half tank on motorhome.
Jul 20, 2009 | Electrical Supplies
Diesel generator runs for short time then shuts down. it is a onan 7.5 & runs off of the motor home fuel tank
More than likely a safety control circuit on startup. Either high water temp, low oil pressure, or over rev condition. If not any of the above quite possibly the integratrated generator/engine control circuit board.
Allan
2.8 Diesel Pajero Cold start
Have replaced your glow plugs?They dont cost alot to replace,try this
Jun 22, 2009 | 2002 Toyota Land Cruiser
Electrical Supplies Logo
107 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
