Question about Acer Computers & Internet
It will not power on or light up the power supply is good it is an acer aspire 3680
  • 201 Answers
Hi im replacing a dc jack for the same unit
you can check the pin to see if it moves to be sure
here is the part
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=370184604055
Posted on Jul 20, 2009
crashmech
  • 67 Answers
SOURCE: All Drivers for Acer Aspire 3680
here are all the drivers for this model
click here
any more problems email me.
Posted on Sep 27, 2008
  • 244 Answers
you can download from www.acerpanam.com
Posted on Oct 01, 2008
benwabnick
  • 2404 Answers
SOURCE: power problem aspire 3680 acer
you can try replacing the cap inside the power supply but most of the time when a cap goes its because theres a bigger problem inside the power supply. Get a new one cause to troubleshoot a power supply would take much more time to get it fixed (and there could be other underlying problems).
Also getting a new power supply entitles you to warranty that comes with it so if it craps out on you in a certain period of time, you can get it replaced.
Posted on Jul 21, 2009
eagle338
  • 4889 Answers
SOURCE: Acer Aspire 7720 shut down, no power light,
The laptop's AC power jack is probably damaged. All you have to do is put the fork aside :D, unsolder the old power jack and solder the new one in. If you are not good at soldering you can get it done by a qualified professional. Its a 5 minute Job and a pretty inexpensive repair.
Regards,
Sai.
Posted on Oct 24, 2009
  • 8909 Answers
SOURCE: i need the mass storage
If you were to log on to the acer.com web site, I think you will be pleasantly surprised as usually one is able to download if available, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service, Driver downloads and Installation Instructions as required.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
There are no XP drivers to be found with Microsoft as XP is no longer supported.
Some manufacturers may have a limited number of Drivers still listed.
I hope this helps.
Posted on Jan 27, 2011
Acer aspire 3680 does not power up even the batt is fully charged?
There might be a problem on your motherboard particularly on the power supply area. Try to check if the item is still under warranty you can always ship them back the product. Laptop Motherboard problems might prompt you to buy a replacement motherboard.
Pls vist their site:
http://www.acer.com/worldwide/selection.html
Thanks.Cheers!
Apr 21, 2010 | Acer Aspire 3680 Laptop
Power supply jack on Acer Aspire 3680 Laptop not macking connection. checked power supply and it is putting out 19.2 volts. How do I go about changing jack?
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot fix this yourself then I suggest you get a quote first.
Nov 03, 2009 | Acer Aspire 3680 Laptop
Acer Aspire 3680 laptop. Computer is not getting power
If the power adapter light is not on, even when not connected to the computer, you have a bad power adapter.
You can find additional troubleshooting tips here:
http://www.shopbysystem.com/blog/?p=21
Aug 07, 2009 | UltraLast ULAC3660L For Acer Aspire...
I have a acer aspire 3680 that will not charge
The power cube is the problem..lets face it you had a 50/50 chance of getting to the root of the problem..so by replacing the battery that only leaves....
Don't Forget to rate the advice!!
http://www.aa1consulting.com
Jul 27, 2009 | Apevia HQRP Replacement Laptop AC Adapter...
Acer aspire 3680 laptop will not charge while plugged in wall
It appears that you have faulty laptop power connector socket.
This is why it appears to work sometimes when you plug the connector into the laptop in some direction.
To confirm this, wriggle the connector while you look at the charge light on the laptop, if it blinks as you wriggle it then the power socket is either faulty or just needs resoldering so it will make proper electrical contact.
You can get a compute techo to do this or you can do it yourself but it requires dismantling the laptop completely to get at this power socket.
Jun 01, 2009 | Acer Aspire 3680 Laptop
I cannot power on the computer. It is an acer aspire 3680.
the Power supply may have gone bad, worse case scenario, the motherboard died on you
Dec 07, 2008 | Acer Aspire 3680 Laptop
where is ethernet driver for acer aspire 3680
Jul 18, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Can't Power Up
acer aspire 3680 no power on, found 2 short circuited surface mount capacitors on motherboard replaced lapton power on works fine. Edward
Jan 19, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
